Old 06-15-2011, 10:36 AM   #1
zero_cool09
zero_cool09 will become famous soon enoughzero_cool09 will become famous soon enough
1999 SL1
Wrench Taking off my SL1 front interior door panels...
Hi guys, I am in the process of taking out the two front door panels, I have removed the screws from all the appropriate places and now I am stuck with getting the window crank and door handle/locking mechanism out of the way (off) so that I can pull the panel out to reach the stock speakers I am hoping to replace with new ones...
any help is greatly appreciated.
Thanks.
Add to zero_cool09's Reputation
Rate the quality of this post and help zero_cool09 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zero_cool09 is offline   Reply With Quote
Old 06-15-2011, 10:43 AM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Taking off my SL1 front interior door panels...
Thanks.
The make a tool for removing the window crank. I bought one twenty years ago and I think they're still the same price.
For the handle/lock rod, I use a long, thin flat blade screwdriver. The first time removing them can be time consuming, but its second nature now. Only takes seconds to remove and reinstall.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 06-15-2011, 10:46 AM   #3
davorocks
davorocks is on a distinguished road
1999 SC1
1999 SW2
i replaced my speaker with the panel still on it. i just rotated it around the crank.
99 SC1 3 door 5 speed-98 C1500 350 not slow-97 K1500 305 slow-96 Camaro 3800 SII-95 Firebird Formula bad mpg
Add to davorocks's Reputation
Rate the quality of this post and help davorocks reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davorocks is offline   Reply With Quote
Old 06-15-2011, 10:51 AM   #4
zero_cool09
1999 SL1
That's an interesting idea... so how did you get out the locking mechanism? did you pull that out and then somehow rotate it? I am pretty new to this, I have only removed the back paneling to get at the rear speakers. This seems a little more complex.
Also, Low Saturn, where could I buy a tool like that? Amazon? I need somewhere that would deliever into Canada (surprisingly for parts its harder than you think/more expensive...)
Old 06-15-2011, 10:57 AM   #5
Low Saturn
Low Saturn's Avatar
2000 SC2
Wow. That must of been funny to watch.
Mike
-2000 Saturn SC2
Old 06-15-2011, 10:59 AM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
Your local autoparts store should have them. It would most likely be next to the replacement generic window crank handles.
Mike
-2000 Saturn SC2
Old 06-15-2011, 11:09 AM   #7
trottida
trottida's Avatar
Richpin has a video on how to make one out of an old CD. You could probably adapt to use another material. There is also a video on how to remove the cranks. Search Youtube for Richpin.
Current rides
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Old 06-15-2011, 11:21 AM   #8
The "replacing the spark plugs through the tailpipe" joke comes to mind.....
Add to madpogue's Reputation
Old 06-15-2011, 11:21 AM   #9
bilzhorse
bilzhorse is on a distinguished road
bilzhorse's Avatar
You should be able to pick that tool up at any local auto parts store. I got one at Autozone for $6.
Oops! Someone beat me to it.
'95 SL-1, 5sp. All stock.
Add to bilzhorse's Reputation
Rate the quality of this post and help bilzhorse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bilzhorse is offline   Reply With Quote
Old 06-15-2011, 11:27 AM   #10
zero_cool09
1999 SL1
I found the video, but I am unable to post the link to confirm.
its by richpin, but he makes the crank remover out of sheet metal. Anyways, sounds easy enough now that I have seen it done...
Thanks for the advice so far. I will update with my success or failure haha
Old 06-17-2011, 02:18 AM   #11
zero_cool09
1999 SL1
So I have a tool that is able to remove the window crank, but I can't seem to figure out how to remove the interior door handle/lock (I have the manual ones, no electrionics ) any pieces of advice on how to get the panel off at this point?
Old 06-17-2011, 06:07 AM   #12
DietCoke
DietCoke is on a distinguished road
DietCoke's Avatar
1998 SC1
I'm in the same boat, and would like this info. Doing speakers this week as well
1998 SC1 - 41 MPG Daily
2011 Camaro SS - 698rwhp/734tq, 11.20@129mph (old times)
Add to DietCoke's Reputation
Rate the quality of this post and help DietCoke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DietCoke is offline   Reply With Quote
Old 06-17-2011, 06:29 AM   #13
Flip the plastic tab off the rods and spin it a bit, then pop the rod's out.
Old 06-17-2011, 08:14 AM   #14
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
I assume you have already popped out the plastic cover (that goes where the pwr lock switch would go).
A small thin flathead screwdriver will snap the pushrod retainers off the rod. then it rotated out of the way so the pushrod can slip out of the control horn.
The hard part is getting them back in there.
Add to caveeagle's Reputation
Rate the quality of this post and help caveeagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caveeagle is offline   Reply With Quote
Interior door panels chillin05VUE Vue Mods 3 08-19-2010 06:59 AM
taking off interoir door panels 03 VUE Janka Vue Tech 1 07-16-2008 09:18 PM
Interior door panels valentahh Ion General 8 12-07-2003 09:26 PM
Taking off door panels Bigbadbert S-Series Mods 9 02-07-2003 12:40 AM
WTB: interior front door panels 97-99 SC importrza Classifieds 0 07-17-2002 10:07 AM
