Aura General Photos |
· · · AURA - Member Photos 588 photos 198 comments |
· · · 2007 - AURA Teaser Brochure 11 photos 1 comments |
· · · AURA - Member Photos 588 photos 198 comments | ||||||||
Thread Tools | Display Modes | |||
#21 | |||||
![]() Join Date: Mar 2010
2009 AURA XE
http://www.jcwhitney.com/5/16-canist...wx?filterid=j1 Last edited by greenman; 06-19-2011 at 01:36 AM..
#22 | |||||
![]() Join Date: Apr 2010
2009 AURA XR
I have no idea if they were drumming up business for their service department or trying to help. I'd like to think the later.
#23 | ||||
![]() ![]() Join Date: Apr 2004
2009 AURA XR
1999 SL1
I think you may have it backwards. Sandard cars can handle up to 10% ethanol, which would be E10, E85 is 85% ethanol. The Ethanol is very easily unmixed with gasoline when water is introduced. If he got some water in the tank, and had a bunch of garbage in the bottom of his gas tank, then ran the fuel level extremely low, and sucked the water born pure ethanol mixed with the contaminates, I could see it going from great to clogged injectors in one tank.
... If it ain't broke it's over designed.
#24 | ||||
2009 AURA XE
You're right. My bad.
#25 | ||||
![]() Join Date: May 2008
2008 AURA XE
Greenman was correct...after changing the sensor and cleaning solenoid contacts to no avail, I actually ended up taking it into the dealer (well...that authorized Saturn service dealer).
The intake camshaft solenoid had failed...here's the good news...covered under the powertrain warranty.
#26 | ||||
![]() Join Date: May 2012
Hello i have a 07 sky 2.4L thats throwing the exact same code P0010, I dont wanna make the same mistake and buy the Connector when its the Solenoid...problem is i cant seem to find the part number ANYWHERE.
Where do i find the Camshaft Actuator Solenoid??? Is it expensive? PS: I already reset the ECM and the check engine light went away and cameback
#27 | |||||
![]() Join Date: Aug 2008
2008 AURA XE
What I noticed though is, after clearing the DTC (Diagnostic Trouble Code), it ONLY comes back if I step harder on the gas pedal, otherwise, it does not. Any P/N or link to that "camshaft position actuator solenoid valve" ??? Regards.
#28 | ||||
2008 AURA XE
Well, here's one that seems to be the right one:
http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
#29 | |||||
2009 AURA XE
#30 | ||||
2008 AURA XE
Hi Greenman, as I quoted before, it is the 2.4 L. one.
Thanks.
#31 | ||||
2009 AURA XE
I must be going blind. Where exactly was your engine information in this thread?
#32 | ||||
2008 AURA XE
Hi Greenman, please see the bold text in post #27 ...
#33 | ||||
2009 AURA XE
OK. How about putting your car details in your profile so I don't have to jump through hoops?
You have an LE5 not an LY7 engine so those won't work.
#34 | ||||
2008 AURA XE
I did, thank you.
#35 | ||||
2009 AURA XE
It's a covered repair under the 5yr/100K powertrain warranty.
#36 | ||||
2008 AURA XE
Thanks for the info, I'll contact them ...
#37 | ||||
hi everybody. How do you purge or reset the code? Kind of a newbie here...
#38 | ||||
2008 AURA XE
I do that using a scan tool.
#39 | |||||
2009 AURA XE
http://www.amazon.com/Autel-MaxiScan...7539472&sr=8-1
#40 | |||||
| Thread Tools | |
| Display Modes | |
| 96 sl1 camshaft position sensor | irondiezl3 | S-Series Tech | 10 | 09-15-2007 06:40 PM |
| Camshaft Position Sensor A | t2oo5 | S-Series Tech | 4 | 03-13-2007 12:42 PM |
| Camshaft Position Sensor on a 96 SC2... | DJboozeAlot | S-Series Tech | 15 | 12-06-2006 06:38 PM |
| Camshaft position sensor SES light | ThePassenger | S-Series Tech | 4 | 05-05-2006 11:01 AM |
| camshaft position sensor | ThePassenger | L-Series General | 1 | 05-05-2006 07:38 AM |
