Old 06-08-2011, 03:28 PM   #1
alil2cul4u
alil2cul4u is on a distinguished road
Default L200 Fuel Tank Pressure Sensor
We are trying to fix a Saturn L200 we have a CEL P0442. The Fuel Tank Pressure Sensor has been replaced, so has the gas cap. We was told by someone that they could not get a response from the sensor before it was replaced... Has anyone else had any problem like this? If so, how did you fix it?
Thanks,
Julian
Edit: The car is a 2003 L200
Add to alil2cul4u's Reputation
Rate the quality of this post and help alil2cul4u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alil2cul4u is offline   Reply With Quote
Old 06-08-2011, 10:30 PM   #2
Default Re: L200 Fuel Tank Pressure Sensor
P0442 Evaporative Emission System Leak Detected (small leak)
Usually caused by a loose gas cap. Try wiping the cap seal and filler neck clean and use only an OEM cap. Here are the diagnostic steps if you avoid the simple things to try;
Diagnostic Aids
An EVAP canister purge solenoid valve or EVAP canister vent solenoid valve circuit fault may have caused this DTC to set.
The PCM uses the FTP sensor to detect the amount of vacuum pulled on the EVAP system during the leak diagnostic tests. Ensure that the fuel pressure sensor is not skewed by verifying the FTP sensor on the scan tool is between 2.35-2.85 volts with the ignition ON and the fuel cap removed.
Locate the small leak with the Evaporative Emission System Tester (EEST).
The following are possible causes of a small leak:
  • The fuel cap is leaking.
  • The EVAP canister vent solenoid valve is not seating correctly.
  • The EVAP vent hose is loose or damaged.
  • The EVAP canister is leaking.
  • The fuel sender assembly O-ring is leaking.
  • The fuel tank or filler neck is leaking.
The small leak diagnostic can detect a leak greater than 0.020 of an inch in diameter.
A condition may exist where a leak in the EVAP system only exists under a vacuum condition. By using the scan tool Purge/Seal function to create a vacuum, seal the system and observe the FTP parameter for vacuum decay, this type of leak may be detected.
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
Old 12-01-2011, 11:29 AM   #3
rsaturn2011
rsaturn2011 is on a distinguished road
Dizzy Re: L200 Fuel Tank Pressure Sensor
Thanks,
Julian
Slightly different but related: Is it necessary to remove the fuel tank on a 2000S model to make this test ? Or any related code p0442 repairs?
Thanks for your expertise...
Add to rsaturn2011's Reputation
Rate the quality of this post and help rsaturn2011 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rsaturn2011 is offline   Reply With Quote
Old 12-01-2011, 01:39 PM   #4
No tank removal needed. All tests are done automatically by way of OBD II - every vehicle in this country must have its own emission self test done at every engine start up and during a drive. No time limit as OBD II runs self tests continually by first testing things like vacuum or pressure in the sealed fuel system, coolant temperature, every sensor and catalytic converter. If any sensor fails, shorts, opens, leaks vacuum or doesn't measure pressure, OBD II flags it for display as an error code to turn on the SES/CEL/MIL indicator.
A fuel pressure error code may mean a fuel cap is loose as tank pressure is monitored; the fuel cap is similar in construction to radiator/coolant caps - both have a built-in pressure and vacuum relief valve. A failure in one valve or poor seal between the cap and tank can cause either a vacuum or pressure sensor to detect the fault. Its recommended that only OEM fuel caps are used for replacement as aftermarket caps may not have the same ratings as OEM caps. Most errors are with the cap or filler neck causing a leak. Be sure to check cap and neck sealing before embarking on a tortuous route to check every fuel vacuum/pressure line and solenoid valve related to the fuel system. It will not be a walk in the park.
Old 12-01-2011, 10:45 PM   #5
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
The most common cause of a P0442 code reported on this site is corrosion of the fuel filler and vent pipes near the right rear wheel, causing perforation and a small vacuum leak. I had this, and replaced the filler neck assembly - code gone.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2003 L200 fuel leak from top of tank flash1605 L-Series General 5 10-09-2015 08:12 PM
Widow in need - L200 will not start - fuel pressure grover L-Series Tech 11 10-08-2013 02:29 PM
L200 won't start, full tank but guage reads E lyneday L-Series Tech 7 12-08-2006 11:01 PM
How to make a surge tank cap to help pressure test your coolant system Grandpa Joe S-Series General 2 06-30-2006 12:30 PM
Static fuel pressure and modifying it (also 02 sensor) Sony S-Series General 2 02-11-2006 04:27 PM
