Old 06-05-2011, 12:49 PM   #1
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2003 VUE 2.2L
Default 2001 L300 ignition wiring??
Hi! This is my first L series! It's a 2001 (or 2000) l3000 it's an auto with 111k. I paid $600 up front and another $200 when I get the title. I got this car from a towing company and am waiting (and hoping) for the title...
Anyway, there is a weird wiring harness that's been spliced into a module on the left of the steering wheel. The car won't start with the key, but if you turn the key on and energize the purple wire (that's connected to the yellow wiring on the car), the starter engages and you can start the car. Turning the key back off shuts it off.
My question is WTF is this harness and can I simply remove it and splice the original wires back together? The blue wire on the floorboard is my lead from the battery that I insert into the harness to engage the starter while the key is on..
Also, is there a how-to on the timing belt?
Thanks!
shawn
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 06-05-2011, 01:22 PM   #2
Default Re: 2001 L300 ignition wiring??
Welcome to the dark side. Timing's been covered a few times. You'll find the info by searching past threads by great pictures and write-ups.
I'm studying your artwor...err, wiring...............
If its possible, reconnect all the wiring back, color to color match. My guess is that this cut up was to create an aftermarket harness to use for either a remote start or alarm. If you're familiar with Passlock, this theft deterrent system can be trouble to a few not familiar with wiring in aftermarket alarm and/or remote start systems. Interfering with the factory theft deterrent system caused the system to lock out the driver from starting and driving away.
Old 06-05-2011, 01:43 PM   #3
ShawnV
ShawnV's Avatar
2003 VUE 2.2L
I was wondering if it might have been part of an alarm or remote start that was installed on the car. From what I know of the history, the car sat for a couple years at a rental place until the landlord called the towing company to come remove it.
I did try replacing the module that the wires were plugged into with no change.
Here are a couple more pics:
Old 06-05-2011, 10:24 PM   #4
ShawnV
ShawnV's Avatar
2003 VUE 2.2L
Well whatever that harness was I removed it and spliced the original wires back together. The problem is fixed.
Wiring satellite radio switched to ignition adaml Vue Tech 1 07-16-2008 09:21 PM
97 SC2 Ignition Wiring Diagram Thumbs S-Series Tech 1 04-19-2008 02:26 PM
Ignition wiring question. shortdraw121690 General Saturn Discussion 0 03-15-2007 12:54 PM
Help with ignition wiring kssaturnowner S-Series Tech 3 02-19-2007 10:37 PM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 04-30-2005 11:45 PM
