Old 05-30-2011, 03:37 PM   #1
sagreer70
sagreer70 is on a distinguished road
Default 08 Outlook - High Pitched Grind
Hello -
We have an 08 Outlook XR. It is a great vehicle. We have about 50,000 miles on it now, and recently after the car starts, and especially when idling at a red light, you can hear a high-pitched (relative to the engine) griding, or motor noise. I think the noise goes away (is not drowned out) when you start to move.
My wife took it to our local shop for an oil change and check up this past week, and forgot to ask about the noise. You can hear it, but it's not too loud.
Any ideas on what this could be? I thought it might be low fluids, but I checked the power steering, breaks, and oil, and they are all full.
Thanks!
Add to sagreer70's Reputation
Rate the quality of this post and help sagreer70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sagreer70 is offline   Reply With Quote
Old 05-30-2011, 03:58 PM   #2
sagreer70
Default Re: 08 Outlook - High Pitched Grind
Ok - May be the Belt Tensioner. Am checking this.
Old 05-30-2011, 11:09 PM   #3
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
timing chain??? big outlook problem.
Add to onefunkar's Reputation
Old 06-02-2011, 11:49 PM   #4
mdoj
mdoj is on a distinguished road
How about the power steering pump. There is a service bulletin out on them for noise.
Add to mdoj's Reputation
Rate the quality of this post and help mdoj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mdoj is offline   Reply With Quote
Old 06-12-2011, 11:47 AM   #5
sagreer70
I will check that - thanks!
Old 06-20-2011, 12:41 AM   #6
sagreer70
The $5 solution may have worked for once!
It appears that the power steering fluid level "full" marker was set low in some (many?) Outlooks. If you search here for Bulletin #PIT4537 it explains the cause:
Customer comments about a whine noise from the power steering system. This may be caused by the power steering
pump not having sufficient fluid.
That's me! Here's the solution the bulletin gives:
"Check for correct fluid level and adjust to Max mark. Then add additional 1.2 oz (35cc) of fluid. This will bring the fluid level 8 - 12 mm over the Max mark. Some vehicles were built with this overfill condition so always check fluid before adding more."
So I tried it, adding 1.2 ounces of fluid over the max. After about a day or so of driving - Ta da! No whine!
This makes sense to me - - my fluids had always been topped off at the dealer, where I got my oil changed, so they may have known to overfill the power steering chamber. But last time, I took it to a local mechanic (I now have about 55k miles, so no more warranty, no more dealer). The local guy did not know about this.
So, just keep this in mind - - over-add the power steering fluid, and it will be good to go. I think you can over-over fill it though, so watch how much you put in.
Thanks for the input!
High Pitched Whine Sprintst Vue Tech 6 02-09-2009 11:12 AM
Ultra High-Pitched Sound / Outlook BrightOutlook Outlook General 14 04-08-2007 10:19 AM
Low-Pitched Speed Sensitive Grind in Dash R-Rizzo S-Series Tech 4 04-27-2006 04:06 PM
high pitched squeal callmethewander S-Series General 3 05-20-2005 06:57 PM
High pitched whine from front of '93 SW2 jwight S-Series Tech 9 05-02-2002 12:46 PM
