Old 05-27-2011, 07:47 PM   #1
wulf
wulf is on a distinguished road
Default 2001 SL2 transmission problem
Hey everyone, I'm writing here in the hopes of getting some information or help with my car.
My Saturn has been having problems with it's transmission, initially, it's been kicking when going in reverse, and slightly kicking in other gears as well (can't remember which ones at the time).
I took my car in and had the fluid replaced at AAMCO. they said they found 'clutch matter' and couldn't do a full flush because it might damage the transmission, so they did something else which they explained was basically replacing most of the fluid (if my memory serves me right). This lessened the occurrence and severity of the slamming, but didn't eliminate it.
After awhile (months?) the slamming got bad again. I decided to change the transmission fluid myself. This helped again, but, once again didn't fix the issue.
I decided to check to see if the shaft nut was loose. It didn't seem to be loose much, if at all. Of course, since I had to change the fluid to do this, the transmission started working better...
Now, my Saturn is slamming more often in all gears, sometimes one of the gears will slip instead of slam (one of the lower gears will not engage and the engine will rev before it engages). Now it's even having problems with downshifting....
I decided to call a mechanic and bring it in after memorial day. The mechanic has told me that if it's slamming like that, then the transmission is bad and needs to be replaced.
After searching on these forums, I feel like I should of done wolfman's 'reverse' slam cure (it was slamming hardest in reverse), and maybe checked the valve body solenoids....not sure, I'm not a mechanic, and I'm learning things as I go. Any advice on things to do, or check over the weekend before bringing it in to the mechanic, or is all hope for my transmission lost?
Add to wulf's Reputation
Rate the quality of this post and help wulf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wulf is offline   Reply With Quote
Old 05-27-2011, 07:55 PM   #2
Default Re: 2001 SL2 transmission problem
When was the filter replaced?
Add to madpogue's Reputation
Old 05-27-2011, 08:01 PM   #3
wulf
I had my transmission fluid initially changed at a shop at around 65k miles before my problem started (it's at just under 75k miles atm...)
The filter should of been changed the last time I went to AAMCO. Also, the first time I changed the transmission fluid myself, I changed the transmission filter.
Old 05-27-2011, 08:24 PM   #4
The first linked post will help with the initial diagnosis of what is wrong.
Transmission repair
http://www.saturnfans.com/forums/sho...nput+shaft+nut
http://www.saturnfans.com/forums/sho...d.php?t=112858
http://www.saturnfans.com/forums/sho...d.php?t=164114
http://www.saturnfans.com/forums/sho...d.php?t=164115
Transmission gasket part numbers
21003202 is the valve body cover gasket. This fits 96-02
21001684 is the end cover gasket. This fits 91-02
21001679 is the output shaft nut. This fits 91-02
21001680 is the input shaft nut. this fits 91-02
Saturn OEM Parts Source
GM Parts Giant- http://www.gmpartsgiant.com/
GM Parts Direct- http://www.gmpartsdirect.com/
Get Saturn Parts- http://www.trademotion.com/splash/in...?siteid=214643
Old 05-27-2011, 09:43 PM   #5
wulf
Thank you all for the information.
So, I'm curious:
1. at what point would I have to replace the transmission (via a mechanic) instead of changing the valve body, and tightening the shaft nut? When the transmission completely breaks down and I can't shift? Rather, how do I know that it's too late to fix this?
2. Would the valve body cause shifting problems in all gears or just reverse (and I think 2nd?). Also, when I checked the shaft nut (without changing the valve body) it wasn't loose. Could this imply another problem (besides not doing it properly)?
3. Is my mechanic potentially wrong about the slamming being an indication of needing the transmission replaced?
4. Finally, I remember reading the forums about using sonnax parts for the valve body (rebuild?). I called their sight a while back and was informed that there was a kit with a sleeve and the part without the sleeve. The sleeve kit requires a 'special' tool that sells for about $500. The question that I have is, how would I tell if the sleeve is bad or not (which would mean that I require the sleeved kit) and, is it common for the sleeve to go bad?
2001 SC1 motor mount or transmission problem? lanieanne S-Series Tech 5 08-22-2009 10:04 PM
2001 L200 2.2 Transmission problem fvanhaaren L-Series Tech 4 06-09-2009 04:56 PM
Acceleration problem...gets stuck...possibly transmission? Or a gas problem? Dingo Warrior S-Series General 34 03-29-2009 12:20 PM
auto transmission problem on 2001 SW2 visnew20 S-Series Tech 10 11-06-2007 04:42 PM
2001 SL1-Automatic Transmission Problem??? Saturn Newbie S-Series General 6 09-01-2005 11:54 AM
