Old 05-18-2011, 10:42 PM   #1
thebeek
thebeek is on a distinguished road
Sad bad idle, dies....HELP!!!
ok, i have a 1999 sc2. it has some modes, but i dont think it would afect whats going on. but i know people will ask.
intake,full exhaust system,flywheel,short throw shifter,TB,and clutch...i think thats it...yeah..oh, and it has 142,000 miles on it.
first off, i have replaced the iac and the tps.
at start up it idles rough, or it takes forever to start, and then it idles rough.
ones it calms down, it idles about 1300-1400 rpm. driving it seems normal...except for the fact when i push in the clutch (im rolling,) the rpm stays around 1900-2000 rpm...?WHAT!!
And occasionally, when going from a stop, the rpms drop almost to 0.
So basically when i let the clutch out and add the gas in, the car sputters and kicks.
I dont think it could be the MAP. I unplugged the MAP and the motor goes bonkers. so it sounds good. the only thing i think it could be is something with the coils, crap on the wires or the ICM. hope its not the ICM...thats a 130 bucks i would like to save.
PLEASE HELP!!!
oh, i haven't drove it after i installed the tps. but before i installed it, the rpms would bounce between 1300-1400 rpm.i don't think i needed a tps replacement anyways.
Add to thebeek's Reputation
Rate the quality of this post and help thebeek reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thebeek is offline   Reply With Quote
Old 05-19-2011, 08:01 AM   #2
Default Re: bad idle, dies....HELP!!!
it has some modes
Mods, not modes.
First thing to check is if this engine still uses the original faulty round nosed plastic coolant sensor. Remove it for inspection, replace it immediately if it is with the flat nosed brass replacement from any auto store.
Old 05-19-2011, 06:43 PM   #3
thebeek
lol...modes..man i feel like a noob.
man, thats the last thing i would of thought...and i just put a new MAP today.
ok, thanks for the tech......if you dont mined. Do you know why this little thing causes this?
Oh man, i totally forgot to mention that my temp gauge does not work. I thought it was the thermostat, could it be the sensor?....
Old 05-19-2011, 07:06 PM   #4
Temperature gauge n/g and poor erratic idle are from the same faulty coolant sensor. The sensor is needed by the pcm to know what air fuel mixtures are needed while driving the temperature gauge.
Old 05-19-2011, 07:29 PM   #5
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
Use regular copper plugs no fancy crap also.
The ICM's are pretty hardy if they are the origional factory unit. Just need removed and cleaned on occasion.
Old 05-25-2011, 06:00 PM   #6
thebeek
Mods, not modes.
You are the man! The old plastic sensor was cracked!! Well, at least I replaced all the sensors. Only two remain. And i did some much needed maintenance, because the saty has been setting for about a year. Starting it every other day or so. Cleaned out intake and the intake manifold. Compression is good, and runs just like new.
Old 05-26-2011, 04:12 AM   #7
Warshark73
Warshark73 is on a distinguished road
Warshark73's Avatar
What shape was the connector in? When those sensors crack, they let coolant leak into the sensor and, possibly, into the connector and can corrode both. If the sensor is clean, you're good. If it's got a little bit of gunk in it, you can probably clean it out. If it looks really bad, you might have to replace it.
Overkill is underrated
Add to Warshark73's Reputation
Rate the quality of this post and help Warshark73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Warshark73 is offline   Reply With Quote
Old 05-26-2011, 06:01 PM   #8
thebeek
Yeah it good and dry.
Old 05-31-2011, 05:18 PM   #9
thebeek
the problem......
98 SL2 dies at idle when hot 800xl S-Series General 5 05-20-2008 06:35 AM
Strange idle, then car dies!! jpblock82 S-Series General 31 05-17-2008 01:30 PM
Strangely low idle, the car dies!!!!!!!! jpblock82 L-Series General 2 04-29-2008 12:01 PM
97 SL2 Intermitently dies at idle. salemSL2 S-Series Tech 3 06-11-2005 11:19 AM
2001 SC2: Low idle, dies spencerb S-Series Tech 3 08-02-2004 12:18 PM
