Old 04-30-2011, 07:26 PM   #1
raffmanlt
raffmanlt is on a distinguished road
Default PCM Removal need help
2000 LS, my pcm is located under the dash, on the firewall, the book shows taking out two screws which I have done and then says to use a 90 degree pick to release locking tabs which seem to be right around where the screws went through. For the life of me I can not find tabs and every direction I have pried nothing has happened. Can anyone tell me the secret??
Add to raffmanlt's Reputation
Rate the quality of this post and help raffmanlt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
raffmanlt is offline   Reply With Quote
Old 04-30-2011, 09:00 PM   #2
Default Re: PCM Removal need help
From the factory service manual;
Remove the PCM bracket attachment screws.
PCM (1)
PCM Bracket (2)
Locking Tab - Left Side (3)
Locking Tab - Right Side (4)
Depress the tabs on each side of the PCM bracket using a 90 degree pick tool to release it from the I/P bracket.
Remove the PCM from the PCM bracket.
Is this drawing the same as yours?
Is there a reason for replacing it?
Old 04-30-2011, 09:34 PM   #3
raffmanlt
thanks, yes that is it. I sure dont see the tabs or how to release them yet I will take another shot at it. I have car torn apart and although I had something over it seems water and debris may have gotten down into it since I had the weather cover and the electrical connections loose. So wanted to get it out where I can look at it good and turn it upside down. Plus about to rain again and dont want to take anymore chances. Not where I can put it back together yet and my car new car cover was stolen.
SC2 Oil Pan Removal manassasralph S-Series Tech 1 09-08-2010 07:59 PM
Schematics for door panel removal and radio dash trim removal mangler66 Vue Tech 0 05-27-2007 03:45 PM
tie rod removal 92[SL2] S-Series Tech 7 12-21-2006 10:30 PM
Oil Pan Removal TurboTuna S-Series Tech 10 08-09-2005 02:24 AM
Oil Pan removal 94sc2boy S-Series Tech 17 03-26-2002 11:13 AM
