Old 04-28-2011, 10:52 AM   #1
Bear
Bear is on a distinguished road
Default A/C problems
I replaced the compressor and the receiver/dyer (aftermarket), refilled the system and the a/c doesn't turn in. The A/C light on the dash turns on, there is power. I remember when I replaced the condenser in my other Vue there was some kind of trick to get it to turn on. Any help would be appreciated. The Vue is a 04 V6.
Add to Bear's Reputation
Rate the quality of this post and help Bear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bear is offline   Reply With Quote
Old 04-28-2011, 11:27 AM   #2
Default Re: A/C problems
Although what follows doesn't prevent any compressor from running once a system is filled with R134a, was this system properly evacuated after the replacement or was this simply recharged? And how much was put in?
Old 04-28-2011, 12:51 PM   #3
Bear
It was evac'd completely. 16.2oz
Old 04-28-2011, 01:29 PM   #4
Check the main a/c fuse then the compressor relay (for swapping if necessary). I don't think you can wire a bypass on the pressure switch connector (if that's what you're describing). All you can do is check the main fuse, relay, and measure for 12v on the compressor connector.
Old 04-28-2011, 01:52 PM   #5
TheVue
TheVue is on a distinguished road
TheVue's Avatar
1. Was the a/c working, at least was the old compressor turning on before you changed it out?
2 When you press the a/c button on the dash, you say the little light comes on. Do the radiator fans come on? I have an 07 Vue with two fans at the radiator, does the 04 have two? Both fans come on when the a/c button is pressed on mine.
My a/c was not working recently. The light would come on when the a/c button was pressed, both radiator fans would come on but the compressor would not engage.
It turns out the 40 pin connector near the foot well on the drivers side had the problem. The purple wire on the plug came loose. After reconnecting that everything worked fine. Just a thought, check that out...... Good Luck
Add to TheVue's Reputation
Rate the quality of this post and help TheVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheVue is offline   Reply With Quote
Old 04-28-2011, 02:14 PM   #6
Bear
The A/C was working, but the compressor was leaking and it was starting to take a little longer to get the car cool. Both fans do turn on. The compressor clutch doesn't spin.
Old 04-28-2011, 05:54 PM   #7
far2grumpy
far2grumpy's Avatar
Do you have an multimeter?
You could check for +12 on vehicle side of two pin connector on compressor clutch (with HVAC configured for AC operation).
If voltage is present - unplug connector from compressor, set meter for resistance - measure between two pins on compressor-clutch connector for continuity ... you'll see a few ohms if good.
If you read an open between the two pins you might have a problem with the compressor thermal protect switch (TPS). This switch is not depicted on drawings but if open - or not installed - will prevent +12 from reaching compressor clutch. Or, worse-case - the clutch winding might be open.
Old 04-28-2011, 08:51 PM   #8
Bear
A/C is working great now. It is kind of weird though,it is working with the A/C diode out of the fuse box. With the diode in, nothing. Weird but, hey it is working. Thanks everyone for your help.
Odometer problems or other problems? wishihadacamaro S-Series General 2 09-01-2008 06:48 PM
A/C and enginge problems, it's known problems? Pega_de S-Series Tech 21 04-16-2007 08:10 AM
97 Saturn SC2 having problems, and me having problems with the mechanic... silkander S-Series General 14 07-20-2005 11:17 AM
Transmition Problems? Lower Gears giving problems Juba310 Ion General 17 11-29-2004 04:04 PM
A/C problems? preduck Ion General 9 07-12-2003 09:34 PM
