Old 04-26-2011, 10:26 AM   #1
Medic6758
Medic6758 is on a distinguished road
Default Power door locks wont unlock
Hi, I hope someone can help me. I have a 2006 Saturn Vue. The power door locks only unlock when the key is not in the ignition but when I start the car the the power locks work fine.
I checked the fuses and they are fine. I hope someone can help!
Add to Medic6758's Reputation
Rate the quality of this post and help Medic6758 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Medic6758 is offline   Reply With Quote
Old 04-26-2011, 10:49 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Power door locks wont unlock
Is this something new or a feature you just detected?
Do you have manual or automatic transmission?
If manual - see 2006 Vue owners manual (page 2-9) for instructions to program unlock when key is removed from ignition.
Repost if you have auto or don't have the manual.
Old 04-26-2011, 11:06 AM   #3
Medic6758
Sorry, it is an automatic. That feature you are describing works fine, the doors lock when it goes into drive and unlock when parked. But as soon as I pull the key out of the ignition I cant lock the doors with the button.
Old 04-26-2011, 11:20 AM   #4
far2grumpy
far2grumpy's Avatar
Are you trying to lock the doors using inside door switch or keyless entry button?
If using inside switch - have you tried using pax side switch to lock doors?
If pax side switch operates normally it could be flaky drivers side lock switch, loose wire, or something more sinister.
Old 04-26-2011, 11:52 AM   #5
Medic6758
I am using the switches on the doors and none of them lock unless the car is running.
Old 04-26-2011, 12:08 PM   #6
far2grumpy
far2grumpy's Avatar
I'm checking the schematics ... can you advise (with key removed):
--do doors lock and unlock using keyless entry?
--if doors are locked with keyless entry will the inside switches unlock doors?
--do you notice clicking noises when moving the inside door control to lock?
Old 04-26-2011, 12:31 PM   #7
Medic6758
I do not have key-less entry. when I open the door with the key and I try to lock it using the switch, nothing happens, no clicking. If I hit the switch the other way to unlock, it works fine.
Now if I start the car and it is running, the switch locks and unlocks fine. I can put it in drive and the doors lock automatically.
Old 04-26-2011, 01:50 PM   #8
far2grumpy
far2grumpy's Avatar
More questions:
-- you mention door switch not working when key's removed from ignition - does this mean key only has to be physically in ignition or must be turned to ACC or ON?
-- is the failure to lock a recent development?
-- did you check both fuses in center console ... 10 amp (LOCK/MIRROR) fuse and 20 amp (DR LOCK)?
While in center console - use the fuse/relay map to find how many door relays are used. If two - or possibly three - swap any of the relays with the one plugged into door-lock position (if any). See if this makes a difference.
Old 04-26-2011, 01:57 PM   #9
Medic6758
I checked the fuses the are on the passenger side of the center console, I swapped them and nothing changed.
Old 04-26-2011, 04:15 PM   #10
far2grumpy
far2grumpy's Avatar
Are you interested in other questions and comment regarding relays?
Old 04-26-2011, 04:56 PM   #11
Medic6758
Where are the relays? in the center console?
Old 04-26-2011, 06:15 PM   #12
far2grumpy
far2grumpy's Avatar
Yes - relays are in center console - and see questions in post # 8.
Old 03-18-2015, 09:58 AM   #13
ji6z
ji6z is on a distinguished road
2006 VUE 2.2L
Need help! My 2006 Vue Manual 5 speed will not lock using both dr and pas button inside. But it will unlock! I have a key fob and it works fine in locking and unlocking. Its just the locking part using the button inside does not work. I check all the relay and or fuse inside the center console and the are all fine. The automatic locking feature works though.
Add to ji6z's Reputation
Rate the quality of this post and help ji6z reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ji6z is offline   Reply With Quote
Old 03-18-2015, 10:54 AM   #14
far2grumpy
far2grumpy's Avatar
Would be very unusual for door lock switches to fail on both sides.
You could check LOCK/MIRROR 10A fuse but a bad one should also affect unlocking function.
According to wiring diagrams - lock signals from both switches are combined in IP fuse block (next to front pax left foot) and then sent to BCM on one wire.
I've attached two diagrams in case you have a voltmeter or test light and want to check at fuse block - or best idea is cut to chase and check at BCM input (BCM is beneath radio - remove the HVAC controller to access).
One diagram is for door switch lock/unlock path and the second identifies the BCM connector.
There'll be four connectors but only one will be gray with 16 contacts ... and you're interested in C3-A8 with RED/BLACK wire.
Fuel Door wont unlock Timothy343 Astra General 36 04-24-2015 08:55 PM
Power door locks lock, but won't unlock itsnotme1988 S-Series Tech 7 05-12-2008 09:01 PM
power locks...passenger door unlock? markymarkmark12 L-Series General 4 02-18-2007 12:11 AM
Power Door Locks Don't Unlock with Key Removal Glasact L-Series Tech 6 08-21-2006 09:24 PM
PWR Locks wont lock but will unlock Fenaleyess S-Series Tech 8 03-24-2004 09:10 AM
