Old 04-25-2011, 12:02 PM   #1
LotsaMiles
LotsaMiles is on a distinguished road
Default Ground location for SL2 cooling fan?
I have a 1996 Saturn SL2 and the cooling fan has stopped working. I noticed it while driving in town the other day because the temp gauge went above 1/2 which is very unusual for my SL2.
What I've Tried:
I pulled the cooling fan from the car this past weekend and bench-tested it and the fan works fine (thanks RichPin for the YouTube videos on removing the fan and testing it). With everything back in the car, I tried jumpering the cooling fan relay port (pins #30 to #87, if I remember right), but the fan did not start. I made sure the A/C was turned on. I Ohmed out the ground at the fan connector to the battery ground and there is no continuity. Looks like I have a ground missing.
What I Think:
I just had the clutch replaced in the car about three weeks ago. My suspicion is that the service folks didn't re-attach the ground for the cooling fan, where ever it exits the wiring loom. Unfortunately, I can't seem to figure out where it exits the wiring loom either. According to the wiring diagram, it should be a black wire roughly 12 gauge in size, and attaching to the engine block somewhere.
My Question:
Does anyone have a picture of where this specific ground exits the wiring loom and attaches to the engine block?
There are several grounded wires attaching to the block that I could see from the top of the engine, but none appeared to be the same gauge as the black wire that plugs into the cooling fan. I figure I am looking for a wire that is not attached (otherwise I have a wire break inside the loom).
Thanks so much.
My Saturns:
1996 Saturn SL2 - 205K miles
2004 Saturn VUE - 120K miles
Add to LotsaMiles's Reputation
Rate the quality of this post and help LotsaMiles reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LotsaMiles is offline   Reply With Quote
Old 04-25-2011, 12:26 PM   #2
Default Re: Ground location for SL2 cooling fan?
2 grounds on the top transmission mounting bolts (1's straight from battery & fender). Then a 3rd under the air filter box.
Old 04-25-2011, 01:39 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Not sure how helpful al this will be, but here you go.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 04-26-2011, 09:15 AM   #4
LotsaMiles
Thanks guys.
I found the missing ground to the cooling fan. It connects to the upper rear-most ground lug on the back of the engine block (same attachment point as battery ground to the block).
In Low Saturn's attached images, it is the 4th image (motor and transmission image), connection point #3.
On my car, the ring terminal broke at the 90-degree bend, so the wire was there but not connected. I picked up a new 3/8" stud ring terminal this morning. I'll need to remove the old crimp from the ground wire and crimp the new one on (not enough wire to cut the old crimp off and re-strip the wire).
Thanks again for the help!
My Saturns:
Old 08-02-2011, 02:45 PM   #5
rjwgump
rjwgump is on a distinguished road
Great pics low saturn. Do you have the same for a 02 vue 3.0?
Add to rjwgump's Reputation
Rate the quality of this post and help rjwgump reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rjwgump is offline   Reply With Quote
Chassis ground location sat-vic S-Series Tech 10 12-19-2008 02:49 PM
Cooling fan relay location tgaff L-Series General 6 06-21-2008 09:08 PM
Ground Strap location?? 2001 SC2 Notopher S-Series General 4 05-03-2005 02:50 PM
Ground location in center console SlimSaturn Ion General 6 04-19-2005 07:39 AM
Where does the Cooling Fan Ground Terminate? zPacKRat S-Series Tech 10 12-12-2003 04:36 PM
