Old 04-24-2011, 05:17 PM   #1
RGZ
RGZ is on a distinguished road
Default 91 SC A/C Freon
I want to charge my A/C but don't know what kinda Freon to use and how much to use?
Add to RGZ's Reputation
Rate the quality of this post and help RGZ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RGZ is offline   Reply With Quote
Old 04-24-2011, 06:33 PM   #2
Default Re: 91 SC A/C Freon
If it has not been converted it used R-12 and if converted R-134a. There should be a conversion label or you can tell by the charging connections.
Old 04-24-2011, 06:43 PM   #3
The original freon used in '91 was R12 that's no longer used. Change occurred around '94 to R134a and conversions were available to switch over; some oil was injected to allow R12 oil work with R134a, two new R134a service valves are installed so only R134a can be injected. The way to tell is to examine the two fittings; old R12 are externally threaded and these threads are visible, R134a have no threads and use a quick coupler similar to air tools using quick connects. R12 fittings are the same whether on the high side or low side. R134a have two different sized fittings to prevent accidents from anyone trying to feed R134a into the high side. Operating pressures on the high side can exceed 250psi and easily cause an explosion hazard to anyone foolish enough to try the wrong coupling. Industry design prevents this from occurring.
It may be wiser to find the source of the leak before trying to refill a system that may be leaking. Like a slow leak in a tire, refilling a leaking system is just a band aid and not a repair. Perhaps you need to know the basics; http://www.saturnfans.com/forums/showthread.php?t=80107
Old 04-24-2011, 09:36 PM   #4
2NDSOUT
2NDSOUT's Avatar
1999 SL
Yes, the early model Saturns used R12 and then the conversion over to R134a happened in the mid 1994 model year.
If I remember- I believe that if you still wanted to get R-12 before it was discontinued; you had to have a repair shop do the fix because of federal regulations. I don't know what it is now for R-134a... but as FDryer mentions; its better to have system checked over rather then just throwing cans of Freon at the car...
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
How Much Freon and Oil Do I add? easydog L-Series Tech 2 07-26-2009 07:25 PM
compressor or freon? saturnsl293 S-Series General 7 05-25-2009 12:44 PM
A/C Freon Leak? usa4624 L-Series General 11 07-26-2006 02:14 PM
What kind of freon does my 1992 SL1 take?? madhatter256 S-Series General 9 08-03-2005 01:03 AM
How to start Freon Charge on 91 SL2 sl2murk S-Series General 8 04-10-2005 10:57 PM
