Old 04-23-2011, 06:29 AM   #1
dagwood70
dagwood70 is on a distinguished road
Default Brake Warning Light
Now I know that the brake warning light in the cluster is there to tell you when you have a problem, but can it sense anything besides low fluid level or a problem with the e-brake lever sensor? It wasn't on last night, but when I picked up my morning coffee, it was on this morning.
The first thing checked was the fluid level. Same as it was 2 days ago, when I had my rotors replaced. The brakes are as solid as ever, work the same, and when holding the pedal as hard as ever (an old test I was told to use to check for leaks), the pedal does not sink at all. I am hoping it's just the sensor. Anything else I can check?
Add to dagwood70's Reputation
Rate the quality of this post and help dagwood70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dagwood70 is offline   Reply With Quote
Old 04-23-2011, 10:42 AM   #2
Default Re: Brake Warning Light
Indeed it's tied only to the hydraulics and the parking brake switch. Might want to re-inspect all the hydraulic lines, etc., while an assistant hold the brake pedal down; then you might be more likely to see a small leak. Also inspect the parking brake switch.
Add to madpogue's Reputation
Old 04-23-2011, 12:59 PM   #3
adventureoflink
adventureoflink's Avatar
could stuck parking brake mechanisms (like on the brakes, not through the switch) also cause the (!)BRAKE to come on?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 04-23-2011, 04:58 PM   #4
SLCraig
The BRAKE light is triggered by the ebrake handle, so no..
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-23-2011, 05:41 PM   #5
capricess
capricess has a spectacular aura aboutcapricess has a spectacular aura about
2001 SL
you could have a slow leak in on of the caliber or lines
Add to capricess's Reputation
Rate the quality of this post and help capricess reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
capricess is offline   Reply With Quote
Old 04-23-2011, 08:02 PM   #6
dagwood70
Well it just got easier. I checked my brake fluid again tonight and it was down. Maybe I couldn't seebso well this morning. It seems I have a leak. :-( Hunting time...
red brake warning light kaptnjack S-Series Tech 7 09-08-2010 08:01 AM
red brake warning light kaptnjack S-Series Tech 1 09-06-2010 10:08 AM
Brake light warning nicolas_p Astra General 4 05-18-2010 06:12 AM
Service wrench and brake warning light mgordon1100 S-Series Tech 3 02-18-2010 03:26 PM
Brake Warning Light! Diesel_Clatter Ion Tech 2 03-16-2007 03:39 PM
