Old 04-22-2011, 06:07 PM   #1
Chadd.Lackey
Chadd.Lackey is on a distinguished road
1997 SC1
Default Headlight Harness Issue?
The passenger side headlight is not working. I changed the bulb and fuse, but the problem persists. Interestingly, according to my connectivity tester I have power to the socket, but the bulb won't light. I am assuming I have a problem with a ground. The ground is a rusted mess; the bolt the secures the ground is very rusted and virutally impossible to unscrew. I am at a loss. How do I fix this problem? Thanks in advance for your help. This forum has been a Godsend!
Add to Chadd.Lackey's Reputation
Rate the quality of this post and help Chadd.Lackey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chadd.Lackey is offline   Reply With Quote
Old 04-22-2011, 07:18 PM   #2
Default Re: Headlight Harness Issue?
Grounds are switched on/off by the headlight switch. Power is constant. Rather awesome system for trouble shooting isn't it? lol
Which bulb isn't working? There's 2 (1 high on end, 1 low in middle,turn/park on other end). You also don't have a separate headlight harness from what I've seen.
Unless you actually have a '91-'96 SC2, with only 1 sealed beam bulb & separable headlight/motor harness.
Old 04-22-2011, 08:47 PM   #3
Chadd.Lackey
1997 SC1
I have high beams but no DTR lights or low beam headlights.
Headlight Wiring Harness Recall quint9 Outlook General 36 08-07-2012 10:13 AM
2001 saturn sc2 burnt headlight harness, oil loss alex2210 S-Series Tech 0 03-07-2011 12:32 PM
heavy duty headlight harness fetchitfido S-Series Tech 4 11-17-2010 02:06 PM
Radiator fan won't come on; harness issue? tls246 S-Series Tech 11 04-07-2010 07:02 PM
I want headlight bulbs that will MELT my harness! project_sl-2 Miscellaneous Tech 5 12-19-2003 12:05 AM
