Old 04-18-2011, 08:57 PM   #1
Bernie
Bernie is on a distinguished road
1998 SL1
Default Deburring the clutch?
I have 73K miles on my 98 SL1. The linkage to the trans looks fine and the gear shift is lubed, but shifting is hard in the lower gears when the engine is on. It's the classic worn clutch scenario.
An old mechanic once told me that clutch plates can develop rough spots that can be polished off by intentionally slipping the clutch. Having nothing to loose, I tried it. Although it may be too early to tell, shifting seems to have improved. Could there be some truth to the old mechanic's trick?
Word of caution to those who might feel adventuresome - slipping the clutch can irreparably damage your car, and leave you stranded with very expensive repairs.
Add to Bernie's Reputation
Rate the quality of this post and help Bernie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bernie is offline   Reply With Quote
Old 04-18-2011, 10:52 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Deburring the clutch?
hmm... that's a new one. I would launch my 02 SC2 at 4000 RPM on occasion and it always felt smooth.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 04-28-2011, 10:28 AM   #3
Bernie
1998 SL1
It appears that ease of shifting has improved significantly since I intentionally slipped the clutch (while in second gear with brakes set). This could also be due to the fact that I replaced a badly worn frowny motor mount around the same time.
I'm still having occasional difficulty shifting between first and reverse so a clutch job is inevitable though not immediately. I've also noticed that on a smooth and level surface the car will inch ever so slightly forward/backward when in first/reverse gear with the clutch pedal down and high RPMs. I only have 76,000 miles on this clutch but it has been mostly city driving. My guess is that the pressure plate fingers have gradually bent over, so much so that the disk, which may still have life in it, is dragging. The point is, you might be able to get a few more miles out of your clutch by intentionally slipping it (wearing it down).
94 clutch replacement--must engine be removed to access clutch? agingric S-Series Tech 3 11-11-2010 10:30 AM
2005 Vue Clutch Reservoir Dry = No Clutch. Slave issue??? polycar Vue Tech 1 09-03-2010 01:11 AM
Clutch Fork related to clutch problems? MikeNW S-Series Tech 0 06-25-2008 01:27 AM
Clutch fluid level, clutch pedal vibration, small leak Heartbeat - '95 SL2 Miscellaneous Tech 10 10-10-2003 06:35 PM
difference between clutch actuator and clutch master/slave cylinder geartooth94 S-Series Tech 3 06-10-2003 12:36 PM
