#1 | ||||
![]() Join Date: Dec 2008
2001 SC1
The rubber fuel line is leaking in near the engine, this is the fuel line to the injector rail, not the anti aeration line. I don't know if I can just use fuel injection hose and try to reuse the quick connect ends, or if I need to replace it as an assembly.
Thanks.
#2 | ||||
There is no return line from the rail. That line is the 50psi fuel supply line and a direct replacement is a dealer only or junkyard item. If the leak is in the flex portion and you are properly skilled you can replace it but a leak under the hood can result in a Saturn fambe.
#3 | ||||
2001 SC1
Well not exactly what I wanted to hear, but its what I expected. I was hoping maybe the aftermarket made a good replacement. I know there is no return from the rail, its the supply line that's leaking. Something must've come up and hit it because it has a nasty gash in it.
Guess I'll be calling the dealer tomorrow, I wonder how much that bad boy is gonna set me back...
#4 | ||||
It is most likely no longer available, depends on the dealer and how hard they want to look. There are 2 lines and 1 is the fuel supply and the other is the canister purge line. If it is the rubber flex line that is cut I would go buy 2 spring constant tension clamps and 2 worm drive clamps and a double barb connector. IIRC 3/8 is the close size.
The part number is 21015026 00-02 all DOHC and you can check the following sources. GM Parts Giant- http://www.gmpartsgiant.com/ GM Parts Direct- http://www.gmpartsdirect.com/ Get Saturn Parts- http://www.trademotion.com/splash/in...?siteid=214643 Price looks like a nice crisp steel engraved picture of old Ben Franklin.
#5 | ||||
2001 SC1
It is the fuel supply line and it looks rubber and says DO NOT REPAIR right on it. haha.
It comes up the firewall a little bit and then curves down towards the VSS and then curves back up to the Intake Manifold. Right at the lower curve near the VSS is where its split. I worry that if a repair failed it would spray on the exhaust and catch fire. Get Saturn Parts lists it for $125.93 so if they have it in stock I will order it for peace of mind. Thanks Old Nuc!
#6 | ||||
Yes, I would replace it. Or go hack one out of a junker if it was not the right model and splice it into the hard line.
Those warning labels are a code requirement for high pressure fuel in vehicles. They are to try and prevent the local redneck back yard repairer from trying to patch a leak with duct tape and string. They can be fixed with no risk if you pay attention.
| Thread Tools | |
| Display Modes | |
| Fuel line specs on a 1998 Saturn Sl 1 (fuel injected) | WadeNKC | S-Series Tech | 9 | 01-07-2010 04:42 PM |
| Fuel line/connection issues...2000 SL2 1.9L DOHC | mjm | S-Series Tech | 6 | 05-27-2009 12:14 PM |
| What happens if you kink/bend a fuel line during fuel filter installation? | Dingo Warrior | S-Series Tech | 4 | 05-31-2008 09:43 PM |
| 1998 Fuel Filter - (Fuel line retainers) | Jeffsimpson | S-Series Tech | 3 | 01-30-2008 07:42 PM |
| Uh Oh! VUE Red Line Fuel Line Recall | CanVueYes! | Vue Red Line | 6 | 06-26-2004 04:03 PM |
