Old 04-04-2011, 08:38 PM   #1
collmm
collmm is on a distinguished road
Default 1997 SC2 Key Issue
Hi Everyone! I am so happy to find the forum. We just purchased a 1997 SC2 as our teenage son's first car. It's a terrific little automatic in excellent condition with only 75,000 original miles...hard to believe but true! This is our second Saturn as we also purchased an SC1 several years ago for our daughter...years of trouble free driving!
Our "new" SC2 only came with one original key and fob. The fob opens the doors, locks the car and honks on the second press of the lock button, opens the trunk, and the panic button works. I had an extra key made at the hardware store and when we unlocked the car and opened the door, the horn honked repeatedly and the car wouldn't start. Pressing the panic button stopped the honking. I then tried the "real" key and the same thing happened...the horn honked, horn became louder when the key was placed in the ignition, and the car wouldn't start. The GM dealer has no idea (wish there were still Saturn dealers).
I have searched the web but am unable to find a similar problem but was hoping someone on the forum could help. Thanks so much!
Add to collmm's Reputation
Rate the quality of this post and help collmm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
collmm is offline   Reply With Quote
Old 04-04-2011, 08:51 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: 1997 SC2 Key Issue
...by any chance, did you forget to disarm the alarm (unlocking it via the RKE) before trying to open the door using the key and starting the car?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 04-04-2011, 09:40 PM   #3
collmm
No, although my son is a responsible kid, I'm just wondering what we'd do if he lost his keys or if we needed access to the car while he's at school and he has his keys with him. It seems like we MUST use the fob...should I order another and program it/have programmed as a back up?
Old 04-04-2011, 10:02 PM   #4
If it's locked & armed with the fob you have to unlock it with the fob otherwise your breaking into it
eBay usually has fobs for under $30 shipped and there's directions in the How-To section on how programming the fobs is done.
Old 04-04-2011, 10:09 PM   #5
You don't need a "Saturn" fob, just a GM one with four buttons and an FCC code of AB01502T. Search also on "ABO1502T", as that's a common listing error. Programming 411 here: http://www.saturnfans.com/forums/showthread.php?t=59192 . One of the options is "no security"; you can lock the car with the remote, unlock it with the key, and it'll start without incident.
Add to madpogue's Reputation
Old 04-05-2011, 12:06 AM   #6
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
Also look at Junkyards for key fobs
My 98 came with none...... picked 2 outa a JY
then 98 was totaled and found another (up to 4 for my 96 SW2)
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Add to Saturninin's Reputation
Rate the quality of this post and help Saturninin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturninin is offline   Reply With Quote
Blower Fan Issue? 1997 SW2 captsam S-Series Tech 2 03-31-2011 01:30 PM
1997 SL Idle Issue rnjj1219 S-Series Tech 11 10-20-2010 07:34 PM
SW2 1997 Starting Issue captsam S-Series Tech 3 07-05-2010 06:46 PM
1997 SC starting issue pyronn S-Series Tech 4 05-04-2009 05:43 PM
1997 SC1 Wiring issue achaiah S-Series Tech 3 01-11-2009 01:45 AM
