Old 04-03-2011, 05:32 PM   #1
Milkman00
Milkman00 is on a distinguished road
Default What size wrench should I use on the tensioner?
I have a friend that wants to replace the serpentine belt on a 98 SW2.
The location of the tensioner makes it almost impossible to reach with a standard length wrench. I want to buy a real long wrench to move the tensioner (assuming I just have to move the tensioner with the wrench to loosen the belt). I just don't know what size wrench I should buy??
Can anyone tell me if this is the right method, and what size wrench I should buy??
Add to Milkman00's Reputation
Rate the quality of this post and help Milkman00 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Milkman00 is offline   Reply With Quote
Old 04-03-2011, 05:51 PM   #2
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Default Re: What size wrench should I use on the tensioner?
OEM 14mm. Many aftermarkets are 15mm. You can tie a piece of clothesline cord to the end of any combination wrench to get the leverage you need to wind up the tensioner from above.
Add to madpogue's Reputation
Old 04-03-2011, 05:53 PM   #3
bigalpha
bigalpha will become famous soon enough
1997 SL1
Can you not slip a piece of pipe over the end of the wrench?
Add to bigalpha's Reputation
Rate the quality of this post and help bigalpha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigalpha is offline   Reply With Quote
Old 04-03-2011, 07:00 PM   #4
alordofchaos is a jewel in the roughalordofchaos is a jewel in the roughalordofchaos is a jewel in the rough
I found it easier to remove the rt frnt tire, splash-guards and get to the tensioner from below (using standard length wrench). Guess I am not coordinated enough to get to it from above
I use my left hand to rotate the tensioner and right hand to lift it off the AC pulley
...Wait, what, I actually won that eBay auction?
Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p
And now (7/2010), a Craigslist 1997 SC2 5 spd
Old 04-03-2011, 09:05 PM   #5
off-track
off-track has a spectacular aura aboutoff-track has a spectacular aura about
off-track's Avatar
The Richpin method..
http://www.youtube.com/watch?v=BdhCz...295EE4B378003F
Although I'm a little hesitant to recommend HF.. it's on sale, and you can use the 20% off coupon from the Sunday paper so it's ~$14 + the freebie of the week. Works well to wedge between WP pulley bolts as well.
http://www.harborfreight.com/serpent...kit-66344.html
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 04-03-2011, 11:16 PM   #6
Signmaster
Signmaster is just really niceSignmaster is just really niceSignmaster is just really niceSignmaster is just really nice
I think this method is easier as well. Even using the stock jack and lug wrench the time removing the wheel is saved in less time playing games with the belt routing and trying to stick my hand in a place too small for it.
I've done it both ways, but removing the wheel seems much easier to me.
Old 04-03-2011, 11:20 PM   #7
DIYguy
DIYguy is a jewel in the roughDIYguy is a jewel in the roughDIYguy is a jewel in the rough
DIYguy's Avatar
Happy Re: What size wrench should I use on the tensioner?
I had my serpentine belt off just yesterday. A standard 14mm box end wrench works. Access it through the right hand wheel well as alordofchaos said.
Remove the wheel and front access panel. Feel up and to the left of the harmonic balancer. Using the wrench remove the tension (rotate the tensioner pulley bolt clockwise) and slip the belt off the balancer first (personally I find it easier than reaching the A/C pulley, but that will work too ).
Takes about 10 minutes. Very easy to do. Be sure to use a jack stand of course.
DIYguy
Condemnant quod non intellegunt.....
97SC2 Saturn, Cruze Eco, Chevy SS P/U, Honda CT200, Honda VT1100C
Add to DIYguy's Reputation
Rate the quality of this post and help DIYguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-13-2011, 09:35 AM   #8
Milkman00
Sorry it has been so long since I replied. My friend hasn't brought his car back over yet, but thanks for all of the great information!!!
Another AC help: Wrench Size? AndreasChen S-Series Tech 6 07-11-2010 08:47 PM
Wrench Size for Oil Pan Plug? 2004 VUE accola0003 Vue General 5 03-11-2010 04:35 PM
what size wrench? saiguanas S-Series Tech 24 11-04-2007 05:13 PM
about to run to store what size wrench o2 sensor irondiezl3 S-Series Tech 12 02-28-2007 09:15 PM
V6 Vue oil filter wrench size? SkyKingAGI Vue Tech 19 06-08-2005 07:48 AM
