Old 03-30-2011, 07:12 AM   #1
HRVAT1975
HRVAT1975 is on a distinguished road
Arrow Automatic starting in 2nd gear???
Hello brandnew to the site, and here is my prob:
I have a 97 Sl2 that had a bad tranny, diff pin came out.. so I found a used 1 with 85k miles at jnkyrd, the car just came in as I pulled up. how ironic.
anyway I replaced the tranny thanks to you guys it made it alot easier,
ok every thing runs nice, up and down shifts are good, but my problem is when I accelerate, it feels like it starts in 2nd gear,, could it be electrical like maybe a loose connecter or the tranny itself.. any help would be greatly appreciated..
Thank you!!!
1997 Sl2-4spd-auto-DOHC-
http://www.facebook.com/profile.php?id=683841079
Add to HRVAT1975's Reputation
Rate the quality of this post and help HRVAT1975 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HRVAT1975 is offline   Reply With Quote
Old 03-30-2011, 07:50 AM   #2
Default Re: Automatic starting in 2nd gear???
It will start in 2nd if the fluid is cold. Do you have any codes? As to temperature, check the connector on the temp sensor and if there is oil inside of it clean it and the sensor out with CRC Electronics Connection Cleaner. The sensor is the small sensor close to the fluid filter.
'02 SC2 Automatic High Gear Only dpowell S-Series Tech 8 07-21-2010 10:50 AM
Automatic, second gear - how do you like yours Adam Opel Astra General 8 07-04-2009 07:55 AM
SL2 automatic transmission first gear only gignac02 S-Series General 13 09-05-2007 02:33 PM
03 L series automatic -- 3rd gear issue casterman L-Series Tech 2 06-28-2007 09:26 PM
My automatic don't seem to want to change into second gear... L|oNeL[92`SL2`] S-Series General 9 01-01-2006 07:24 PM
