Old 03-29-2011, 10:46 PM   #1
sattyluvr
sattyluvr is on a distinguished road
sattyluvr's Avatar
2000 SC2
Default Can i save my saturn???
Im to the point where i cant rely on my 2000 sc2 anymore to do the daily commuting. Im getting another car but find myself not wanting to let my satty go.
the parking lights/dash light circuit has a short somewhere so they dont work...and i also have some kind of wiring issue within the air management system as well that causes the car to idle high or stall depending on its mood. Ive tried doing what i can but i need to take it to a professional at this point if i want it fixed.
everyone says just get rid of it but id love to keep it to tinker with as a little tuner car.
i guess my question is if this is even financially worth it.wiring issues are a ***** but how much would i expect to spend to rewire the lights and engine system? and has anyone gone through this before
any advice is appreciated thanks guys
Add to sattyluvr's Reputation
Rate the quality of this post and help sattyluvr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattyluvr is offline   Reply With Quote
Old 03-29-2011, 11:18 PM   #2
Default Re: Can i save my saturn???
What's so awful about wiring issues? WRT the lights, the first thing I'd do is uninstall all the bulbs, and if the fuse doesn't blow, reinstall them one at a time until it fails. Another possible failure point is the dimmer; if you disconnect it, you remove the dash lights from the equation.
The only electrical/electronic "air management" component is the IAC - intake air control valve. It may be working fine, but being directed incorrectly how to set the idle. If you haven't replaced the ECTS and determined that the connector is good, it could be faulty, causing the PCM to create a high idle. The idle issue may not even be electrical; it could be a vacuum leak such as an intake manifold gasket failure.
Add to madpogue's Reputation
Old 03-29-2011, 11:20 PM   #3
It is probably easily fixable but you don't want to contemplate the cost for a pro. So, if you compile a list of all the things that do not work. Another list of what you have done to the car. Then an educated guess of what to ask and what to check and fix can be made. As this will be electrical do you have a DVM?
Old 03-30-2011, 12:09 AM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Do you have an aftermarket stereo? Have you checked the wiring for it? By far the top reason for issues on the circuit with the dash & parking lights is a short after installing aftermarket head units, often from not insulating the two unused wires.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 03-30-2011, 12:43 AM   #5
sattyluvr
sattyluvr's Avatar
2000 SC2
i tried all points....dimmer-each tail bulb. i went through about 20 10a fuses trying each component. i can still drive during the day cause its just parking lights but its still makes it unsafe at night.
ive been getting a tps circuit A low input code on and off for a couple of months. tried a napa replacement but the problem worsened. installed a junkyard tps and it ran good for a while then same bs. also checked iac valve and tried replacement. i also did vacuum leak tests around intake manifold and TB but didnt find one.
its just a extra headache ontop of things right now to deal with but i dont want to give up on it. i love this car
Old 03-30-2011, 12:49 AM   #6
sattyluvr
sattyluvr's Avatar
2000 SC2
NO kidding?! this might be the problem... the car had an aftermarket pioneer head unit without subs just the headunit when i bought it. ive never checked back there cause i thought the stereo system is on a different circuit then the dash/parking lights....am i correct???
i know its a direct ground short cause the fuse pops immediately so it would make sense. il check it for sure and post results thanks!
Old 03-30-2011, 12:56 AM   #7
sattyluvr
sattyluvr's Avatar
2000 SC2
you worked me through the TPS problem a while ago and it was ok for a while but the problem is now back and worse.
i do have a dvm and a father that does electrical work for the school board so he's been helping me in spare time troubleshooting but hes not super thrilled about working on my saturn on his saturday afternoon so ....
good idea to make a list i will and post it up, thats a good start
Old 03-30-2011, 01:52 AM   #8
Think about it - the lighting on the head unit changes with the parking lights (usu. buttons are backlit and the display dims, but they differ), right? That's fed by the parking light circuit.
Old 03-30-2011, 05:13 AM   #9
Depends on the age of the H/U. One's made in the last 5 years or so are lit via the main power and, if your lucky, have a sensor tied to the parking light line. My older Pioneer unit had 1 brightness level for 24hrs a day, no dimmer or illumination connection. My current JVC unit has 2 levels, one fairly bright for park lights off and a 2nd fairly dim for park lights on. That's on top of making a rainbow look like it's got no color options... lol
Old 03-30-2011, 08:01 AM   #10
Hmm, I had some of the first digital-tuned units from Radio Shack in the '80s, and it had some kind of illumination, and it was tied to the dash light feed. Shoot, if I recall, even the old analog Sanyo aftermarket cassette radio (remember when they were actually "pushbutton"?) in my Nova had some kind of lighting tied to the dash light.
Old 03-30-2011, 08:31 AM   #11
Yes, a list of issues and previous repairs will be a big help. If you used an aftermarket TPS previously that is probably your problem with the high idle as the aftermarket parts tend to an early death. The appropriate vintage part from a junk yard is a better bet.
Aftermarket stereo systems cause major problems, sometimes immediately and most times later. That is probably the source of the problems you are having now. If this is the case the permanent fix is not difficult.
Old 03-31-2011, 12:37 AM   #12
sattyluvr
sattyluvr's Avatar
2000 SC2
Found that the dimmer/dash illumination wire wasnt taped off and was touching the radio ground wire....wrapped it up put a new fuse in and it the lights work!
i feel dumb for not checking that in the first place....i had everything from the dimmer switch to each tail light fixture unplugged trying to troubleshoot it lol
now i just need to figure out my idle problem
thanks guys
Old 03-31-2011, 12:48 AM   #13
sattyluvr
sattyluvr's Avatar
2000 SC2
http://www.saturnfans.com/forums/new...newreply&p=172
i do have a similar JY TPS in right now but the OBD still says i have a low circuit "A" input on the sensor. whether its the new autozone TPS or JY ones the problem persists. i was thinking a pinched wire but who knows. The engine and trans have been swapped on separate occasions by a repair shop i know so maybe a pinched wire is causing a false or low reading.
was wondering if my MAP sensor being dirty might be effecting the system without setting a code...ive never cleaned it and the car has 120k
ill also install the factory radio i got with the car and see what happens
Old 03-31-2011, 02:00 AM   #14
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
Definitely replace the ECTS and check the connector for your idle problem.. even if it doesn't fix it, its a good thing to do, and its pretty cheap and easy.
Add to wi111y's Reputation
Rate the quality of this post and help wi111y reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wi111y is offline   Reply With Quote
Old 03-31-2011, 07:07 AM   #15
What is the actual code number for the TPS. The scanner definition has no real value, need the number.
Old 03-31-2011, 07:49 PM   #16
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Yup, sadly I learned about this because I had the same problem. Glad I could help.
Old 03-31-2011, 10:23 PM   #17
sattyluvr
sattyluvr's Avatar
2000 SC2
P0122 - TPS sensor low circuit "A" input
P0507 - high/irregular idle code set has come and gone with the TPS error code
Recently it hasnt been idling high, its been missing or something when cruising at highway and lower speeds. the car shudders and shakes. Because of this i cant rely on it and have had the hardest time figuring it out.
since ive had the car its also had a p0442 which is a small evap emissions leak somewhere... dunno if its related but it came on shortly after i bought the car and it was warrantied. took it into the then saturn dealer and they replaced the gas cap and oxygen sensor but code came back so i dont know...
Old 03-31-2011, 11:08 PM   #18
The TPS code will probably go away by replacing the present sensor with one from your local junk yard. The OEM parts, even when scavenged of of a dead car work better. For your 2000 SC-2 the TPS from any model 2000-2002 SOHC or DOHC car will function properly. Once the TPS is replaced remove the PCM B fuse from the engine compartment fuse box for a couple of minutes and replace it that will reset the codes.
Please help save my Saturn Mamamia S-Series General 9 12-14-2010 12:36 PM
What car will save Saturn? BobbyP General Saturn Discussion 119 02-25-2008 04:00 PM
This will save Saturn DAS General Saturn Discussion 50 06-08-2007 05:05 AM
This Saturn Couldn't Save Her. white95SL1 General Saturn Discussion 2 07-31-2006 11:18 PM
We Can Save Saturn!!!! dennis marshall General Saturn Discussion 59 07-18-2003 09:31 PM
