Old 03-25-2011, 08:12 PM   #1
TylerLee
TylerLee is on a distinguished road
2004 VUE 2.2L
Default trans swap VTI to 4T45E... do-able ?
I have a 2003 Vue with 4cyl 2.2 engine with a bad automatic VTI trans.
I read good things about the 4T45E automatic trans used on 4cyl 2.2's
Does anybody know if they are swapable/compatible ?
thanks
Add to TylerLee's Reputation
Rate the quality of this post and help TylerLee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TylerLee is offline   Reply With Quote
Old 03-25-2011, 10:12 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: trans swap VTI to 4T45E... do-able ?
thanks
Possibly good news ... GM replaced the VTi with 4T45E for 2005 and up Vues.
I don't have a 2.2 so couldn't guess whats involved with a swap - but it they did it - its obviously doable.
I try to visit forum daily but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 03-26-2011, 04:05 PM   #3
Trilo_g
Trilo_g is on a distinguished road
2008 VUE 3.6L
I would expect it will require a computer change out at the very least.
Add to Trilo_g's Reputation
Rate the quality of this post and help Trilo_g reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Trilo_g is offline   Reply With Quote
Old 04-15-2011, 12:15 AM   #4
vue4x2
vue4x2 is on a distinguished road
anyone found out more about this? would be nice to know we could swap out to another auto that would work?
Add to vue4x2's Reputation
Rate the quality of this post and help vue4x2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vue4x2 is offline   Reply With Quote
Old 04-18-2011, 12:06 PM   #5
tiger862
tiger862 will become famous soon enough
2006 VUE 2.2L
Well not exactly same but same techniques. This is on ION forum with CVT to 5 speed auto.
http://www.saturnfans.com/forums/sho...d.php?t=130775
There is a lot of reading but was done. I say get an 06 or 07 wrecked and buy it and then go for it. Still cheaper than CVT and more reliable.
Add to tiger862's Reputation
Rate the quality of this post and help tiger862 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tiger862 is offline   Reply With Quote
Old 04-18-2011, 02:20 PM   #6
Trilo_g
2008 VUE 3.6L
I notice that one post references swapping a V6/Auto for the 2.2 / VTI in a VUE.
Old 04-22-2011, 10:55 AM   #7
psniadecki
psniadecki is on a distinguished road
1991 SL1
2002 VUE 2.2L
My 2003 2.2 VUE with VTI/CVT just died at 112K. I refuse to put another CVT in due to High Cost$$ and unreliability. Has anyone done this swap to a better tranny? I think the mounts should work, but what about the wiring harness and computer issues? Would like some guidance, Please!
Paul
1991 SL1
2004 2.2 VUE, VTI
2002 2.2 VUE, Manual
2003 2.2 VUE, VTI(tranny failure at 112K miles)
Add to psniadecki's Reputation
Rate the quality of this post and help psniadecki reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
psniadecki is offline   Reply With Quote
Old 05-27-2011, 06:15 PM   #8
TonyUFN
TonyUFN is on a distinguished road
We're in the same boat. Fighting with the extended warranty company over it too... worse than pulling teeth. they obviously don't want to cover a replacement of the VT25.
I considered the Ion swap article, but considering he used the mounts from the Sedan's AF23... I'm not sure how either the AF23 or the 4T45 would work out. Maybe some fabrication too.
The other question that I have is the communication with the other systems. I know with other brands, the gauge cluster is tied in there as well. So I wonder about the same issues.
Swap trans, ecu, bcm, wiring(?) and mounts(?)...
Since I'm in this boat, I might as well get to experimenting. Just researching a little more. But I'm thinking the mounts might be the major issue.
Any thoughts?
Add to TonyUFN's Reputation
Rate the quality of this post and help TonyUFN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TonyUFN is offline   Reply With Quote
Old 09-01-2011, 10:58 PM   #9
Saturnanduranis
Saturnanduranis is on a distinguished road
did anyone evr do the swap?
Add to Saturnanduranis's Reputation
Rate the quality of this post and help Saturnanduranis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturnanduranis is offline   Reply With Quote
Old 09-01-2011, 11:24 PM   #10
saturntechdave
saturntechdave is on a distinguished road
1993 SL2
you would have to swap engine cradle with trans mounts, drive axles, wire harness, and TCM. Only FWD with 4T45 no AWD. I would find a 2005 or 2006 with the 2.2 and 4T45 to compare differences before attempting
Add to saturntechdave's Reputation
Rate the quality of this post and help saturntechdave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturntechdave is offline   Reply With Quote
Trans Swap.... jimyoung28 S-Series Tech 3 05-17-2008 08:07 AM
96 SL1 w/ MP7 TRANS??? PLZ HELP!!! SWAP PCM FROM DOHC???? SWAP BOARDS??? randyshear S-Series Tech 20 11-15-2006 05:58 PM
trans swap tech kjr S-Series Tech 3 12-20-2005 12:56 AM
Trans swap Tom Mohr S-Series Tech 11 06-30-2005 09:01 PM
Trans. Swap rrharmon S-Series General 20 05-24-2004 09:19 AM
