Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 03-17-2011, 01:16 PM   #1
ttigger
ttigger is on a distinguished road
Default 2005 vue rl recall beware
This is to reprogramm the PCM to eliminate gear hunting at 25-45 mph.
All well and good--But YOU WILL LOSE YOUR TOP END. It will be governed at 100 mph like the base VUEs. They have reprogrammed mine 3 times and are on line with GM Tech trying to get my top speed back. It came from the factory and would run 120+ mph.
Not sure if this affects newer RLs or not.
Add to ttigger's Reputation
Rate the quality of this post and help ttigger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ttigger is offline   Reply With Quote
Old 03-17-2011, 01:23 PM   #2
Hoagrod
Hoagrod is on a distinguished road
Hoagrod's Avatar
2006 VUE Red Line
Default Re: 2005 vue rl recall beware
I just scheduled mine to get this done next friday. I'd like to learn more about this for sure even though I don't plan on going 120mph anytime soon. Holy neuter!!!
2006 Vue RedLine.
Add to Hoagrod's Reputation
Rate the quality of this post and help Hoagrod reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hoagrod is offline   Reply With Quote
Old 03-17-2011, 06:36 PM   #3
XRL
XRL's Avatar
2004 VUE Red Line
I'm sure it would. It also confirms that the top speed limiter is a simple PCM function that could be flashed over if a company wanted you to pay them to do it.
Hopefully they release another flash for RLs that preserves the top speed limiter and fixes the transmission.
Add to XRL's Reputation
Old 03-19-2011, 11:36 PM   #4
col_dude190
col_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura about
2006 VUE Red Line
2004 ION-3 Quad Coupe
Not sure what's up with your '05, but I had my '06 Redline reprogrammed last Friday and tonight I verified that I do still have my 120mph governor. It flew right to 120mph without a single hitch tonight on my way home from work. It's possible that there is an issue with the reprogramming of the '05's in particular, but it makes me wonder if the wrong version of software is being used by your dealer to reprogram your Redline. Good luck getting your issue sorted out!
Add to col_dude190's Reputation
Rate the quality of this post and help col_dude190 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
col_dude190 is offline   Reply With Quote
Old 03-21-2011, 03:57 PM   #5
ttigger
Can you post the program number that they used. It should me on your service order. Might be a big help if they can use the same one. I can't imagine any powertrain changes between the 05 and 06. (Both Honda)
Old 03-21-2011, 06:08 PM   #6
col_dude190
2006 VUE Red Line
There isn't too much on my service invoice. All that it lists is:
J# 1 48CVZ GM RECALL TECH(S):4028 WARRANTY
RECALL 10285 REPROGRAM POWERTRAIN CONTROL MODULE
JOB #1 TOTAL LABOR & PARTS 0.00
Not very descriptive. Not sure if any of that will help you at all. I'm assuming that the programming they used was based off of my VIN number. What you might have your dealer try is somehow inputing a '06 Redline VIN number and using whatever software version comes up that way. Just a suggestion. Also, my dealership was Classic Chevrolet in Mentor, Ohio. They are the closest SASP to where I live. Not sure, but they might be able to help your dealership out if they are looking for more answers about the programming. They were very helpful and pleasant to deal with (my first experience with a SASP and not a Saturn dealer) and I'm sure that they would help you guys out or at least point you in the right direction.
Old 03-23-2011, 11:46 AM   #7
newbievueowner
newbievueowner will become famous soon enoughnewbievueowner will become famous soon enough
2006 VUE Red Line
Did the reprogramming make a difference, meaning were you able to feel any change with the TC reprogram? Did your '06 have any issues to start with?
Saturn Vue: The 250 HP tupperware
Add to newbievueowner's Reputation
Rate the quality of this post and help newbievueowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
newbievueowner is offline   Reply With Quote
Old 03-23-2011, 02:01 PM   #8
col_dude190
2006 VUE Red Line
I did have the judder between 30 and 50 on occasion when the engine's RPMs dropped below 1500 or so, but it was something that I had always considered a part of how the Honda Transmission operated, as both my '04 and '06 Redlines did it. Everytime that I felt the judder got too annoying, I would always just change the transmission fluid and it tended to go away for awhile. I have found that changing the fluid every 20,000 miles or so has definitely helped with the issue.
The reprogramming has definitely made a difference in the way that the transmission shifts and when the TC engages and disengages. Now with my Vue since the reprogramming, the RPMs very rarely drop below 1500 rpm at low speeds (under 50mph) and the TC doesn't engage until somewhere between 50 and 55, which seems to prevent the lugging and juddering that I had before the reprogramming. I have been very impressed with the reprogramming so far and I am hoping that GM wises up and expands the campaign to include '04s as I now know that it would make a huge difference for my '04 as well.
Old 02-28-2012, 08:58 AM   #9
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Did you ever think to ask your Chevy dealer if they'd upload the firmware for your '04 using the VIN from your '06? I'd be interested to see how that would work out.
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 02-28-2012, 02:09 PM   #10
col_dude190
2006 VUE Red Line
No, I never took my '04 in to attempt to have it updated. My '04 is a very early '04 and it seems to have a very early version of the PCM software as it pulls extremely hard in first gear as compared to my '06. While its governed at 100mph, which is kind of annoying, I get a lot more use/fun out of my tire spinning unneutered first gear, so I have avoided having any sort of computer updates done on my '04.
As I said in the other thread, I have no doubt that the software update would work on my '04 as well because the PCMs are exactly the same. I just choose to keep my '04 as it is with its ancient programming. I just accept the fact that every 20k my Vues need their transmission fluid changed to avoid the transmission judder. Its just one of the many quirks of Vue ownership.
Old 08-29-2015, 10:07 PM   #11
carvinbassplyr
carvinbassplyr is on a distinguished road
2005 VUE Red Line
Need to revive this. I just bought a 2005 Redline and have been experiencing the gear hunting. Will a GM dealership still do this under recall or will I have to pay for the reprogram? Also has anyone figured out the top speed limiter issue?
Add to carvinbassplyr's Reputation
Rate the quality of this post and help carvinbassplyr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carvinbassplyr is offline   Reply With Quote
Old 08-30-2015, 06:22 AM   #12
Ls1 saturn
Ls1 saturn is on a distinguished road
Ls1 saturn's Avatar
2007 VUE Red Line
Recall has lapsed. Try a transmission fluid drain/refill. This should help. Plenty of info on this site about recall and trans fluid.
Add to Ls1 saturn's Reputation
Rate the quality of this post and help Ls1 saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ls1 saturn is offline   Reply With Quote
Old 08-30-2015, 08:59 AM   #13
carvinbassplyr
2005 VUE Red Line
Will a dealership still have access to the software? At this point I wouldn't mind paying for it if I have to.
Old 08-30-2015, 10:26 AM   #14
billysvue
Beware, huh? Horrors, limited to 100 mph! Oh, the humanity
Me thinks this reflash will eliminate some DArwinAward candidates.
Waaaa....
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 12-15-2015, 01:41 PM   #15
AJEsquire
AJEsquire is on a distinguished road
AJEsquire's Avatar
2005 VUE Red Line
Either this is deja "vue" or we had this discussion about a year ago. I will have to go back and search but going from memory I believe the 05 and 04's where affected if ever hooked up to the computer at the shop and a diagnostic was run. Without your permission, they are making changes to your vue putting the govenor on it. When I escalated the issue, they had no answer as to why it just affected two years and not ALL the years...at least the ones with the same motor (like the 06's) It affected me because I would go to the track....but now I have moved and have decided to keep my vue til the wheels fall off...so...no more track wear and tear. Chevy will not take the govenor off. At least not back when it started happening..they played stupid and didn't understand what was going on. But now that it has been a good year plus? Maybe they have enough complaints to where they now can or will? But yeah, performance shops can take care of that issue....
Add to AJEsquire's Reputation
Rate the quality of this post and help AJEsquire reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AJEsquire is offline   Reply With Quote
Old 12-15-2015, 01:57 PM   #16
AJEsquire
AJEsquire's Avatar
2005 VUE Red Line
Found it! Search for Torque converter campaign and it will pull up a nice long thread that will answer most of your questions dealing with the neutering of your RL
Old 12-27-2015, 10:11 PM   #17
jrad
jrad is on a distinguished road
2006 VUE Red Line
keep your trans fluid fresh and all is well.
also if under 45 use I , no more hunting
2006 Vue Redline Laser Blue
1994 Camaro z28 Green Metalic
Add to jrad's Reputation
Rate the quality of this post and help jrad reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jrad is offline   Reply With Quote
Old 12-29-2015, 12:31 PM   #18
carvinbassplyr
2005 VUE Red Line
This really is the best solution. The re-flash was really only a Band-Aid to try to keep GM from having to replace the actual converter under a recall (for free). Not only does it govern you at 100 mph, it also has the computer keep the resting rpm's higher at the trouble area which means you get worse gas mileage. Manually putting the trans into the intermediate gearset is literally doing the same thing, only you have control over when you take it out. So leave it in drive until the gear hunt becomes an irritation then just put it into Intermediate.
Old 12-29-2015, 05:41 PM   #19
Vue6
Vue6's Avatar
2006 VUE Red Line
...Uh , my 06' had the reflash and still does 122, only diff. is the shifts are better and it stays a bit longer in each gear, so the neutering is not in my vehicle, just my.02, DC
Add to Vue6's Reputation
Old 12-29-2015, 08:10 PM   #20
carvinbassplyr
2005 VUE Red Line
As already stated in earlier posts, 04-05 were the ones affected by the improper reprogramming...hence your 06 being fine.
Beware of 2005 VUE RL Recall ttigger Sky Red Line 8 05-26-2011 08:59 AM
beware rinoa1@cfl.rr.c L-Series Tech 1 04-15-2009 08:20 AM
Beware!!!!! SpeedyIon Ion General 27 06-23-2006 04:55 PM
Bucket seat recall 2005 Relay???? NewToSaturn2 Relay General 1 05-26-2005 01:24 PM
Beware the ION ION3mistake Ion General 134 06-07-2003 01:38 PM
