Old 03-16-2011, 02:00 PM   #1
jwmeyers623
jwmeyers623 is on a distinguished road
Dizzy engine swap computer question
Donor car:
1996 SC2 w/ manual (major body damage)
Going into:
1993 SC2 w/ auto (bad engine, says seller)
I want to swap the entire front engine/ manual trans/ suspension assembly from my wrecked 96 SC2 into a 93 SC2 with auto.
Will there be computer issues with the different transmission? OBDI/ OBDII issues? Should I use my PCM from the 96 car?
thanks for any help,
-Josh
Add to jwmeyers623's Reputation
Rate the quality of this post and help jwmeyers623 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jwmeyers623 is offline   Reply With Quote
Old 03-16-2011, 04:50 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: engine swap computer question
You'll need a PCM for a 1993 DOHC (SL2, SC2 or SW2) with a manual transmission. If you the automatic PCM you run the risk of over revving the engine and blowing it. You'll also have decreased performance.
OBDI/ OBDII issues?
No such thing as an OBDI or OBDII engine or transmission.
Nope. It wont plug in. You'll need the PCM I listed above.
You also have to swap a few of the sensors/solenoids from the 1993 engine onto the 1996 engine. Another thing you'll need to swap from the 1993 engine onto the 1996 engine is the intake manifold, throttlebody, fuel rail, injectors and vacuum line assembly. Basicall unbolt the intake manifold with everything still attached and swap it over to the new engine.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
engine swap question cognomen62 S-Series Tech 4 12-16-2010 11:45 AM
engine swap question 1993 S-Series Tech 2 02-08-2010 08:21 PM
engine swap question rudedog23 S-Series General 2 01-23-2010 10:19 PM
SL2 engine swap question tealsaturn S-Series Tech 1 02-19-2007 03:59 PM
Engine swap - 99 SC2 to 2000DOHC engine - Question Anjey S-Series Tech 10 07-06-2005 10:11 AM
