Old 03-10-2011, 08:45 PM   #1
redleg23
redleg23 is on a distinguished road
Default 2006 Vue Front wheel bearing HELP!!
I'm will be changing my front wheel bearing on my 2006 AWD VUE. Can anyone forward, the service manual page, regarding this part? I have limited knowledge on changing bearings. I'm fearful this could turn into a nightmare, just from reading other posts. Any helpful suggestions are greatly appreciated!!! THANKS
Add to redleg23's Reputation
Rate the quality of this post and help redleg23 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
redleg23 is offline   Reply With Quote
Old 03-10-2011, 09:59 PM   #2
Chazberry
Chazberry's Avatar
Default Re: 2006 Vue Front wheel bearing HELP!!
Start spraying some PB Blaster into the Hub/Steering Knuckle mating surface ASAP. This can be an easy or difficult job - it all depends on how much corrosion you have between your Hub and Knuckle.
Add to Chazberry's Reputation
Old 03-11-2011, 10:58 PM   #3
izzy3rd
izzy3rd is on a distinguished road
izzy3rd's Avatar
Here's the info from Autozone's repair guides. This is identical as far as procedures to the GM service manual I used.:
Removal
1. Remove the front brake rotor.
2. Disconnect the wheel speed sensor electrical connector, if equipped.
3. Remove the wheel speed sensor electrical connector form the connector bracket.
4. Remove the front halfshaft spindle nut.
5. Support the halfshaft with heavy mechanic's wire or equivalent.
6. Remove and discard the wheel bearing/hub mounting bolts.
7. Remove the wheel bearing/hub assembly from the steering knuckle.
Install
1. Install the wheel bearing/hub assembly to the steering knuckle.
2. Install the wheel bearing/hub mounting bolts. Tighten the bolts to 130 Nm (96 ft. lbs.).
3. Install the halfshaft spindle nut. Tighten the nut to 205 Nm (151 ft. lbs.).
4. Install the wheel speed sensor electrical connector to the mounting bracket, if equipped.
5. Connect the wheel speed sensor electrical connector.
6. Install the front brake rotor.
I had to rent a 7 ton gear puller to get my hubs loose from the steering knuckle. This was an upper midwest owned vehicle before I purchased it so road salt had bonded the knuckle to the hub bearing pretty well. When you get the bearing out clean the surface on the knuckle where the 2 meet. I used WD40 and a scotch-brite pad.
I hope this helps.
File Type: png Screen shot 2011-03-11 at 9.48.17 PM.png (38.2 KB, 128 views)
Add to izzy3rd's Reputation
Rate the quality of this post and help izzy3rd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
izzy3rd is offline   Reply With Quote
Old 03-12-2011, 05:40 PM   #4
DavidBo
DavidBo will become famous soon enough
2002 VUE 2.2L
It seems like the folks with the most problems come from areas where salt is used to de-ice the roads in the winter. If that's your case than you could have issues getting the CV joint out of the hub and the hub out of the knuckle. I did my rear bearings, which have similar sticking issues, and they dropped right out. Maybe living in S. Texas (no road salt) and not taking it to the beach (no ocean salt) made the difference. Keep searching the forums and good luck!
Add to DavidBo's Reputation
Rate the quality of this post and help DavidBo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DavidBo is offline   Reply With Quote
Old 03-12-2011, 06:12 PM   #5
03cobra
03cobra is on a distinguished road
This is so True. Im from Jersey. there's salt on the ground 5 months out the year and the other 7 months when you go to beach there's salt in the air. I just replaced all my wheel bearings. I did the front driver with no problem, the front pass i couldn't get the damm rotor off. So i said screw it and paid the man to work on the car. He also did the carrier bearing. he said it took him 2 hours of hitting, heat, PB blaster and muscle and he finally got the drive shaft apart. so yea the North east sucks lol
He quoted" dang man, did you park this under water for a year, there is so much rust under your car" i laughted and just paid him
Add to 03cobra's Reputation
Rate the quality of this post and help 03cobra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
03cobra is offline   Reply With Quote
Old 03-12-2011, 07:13 PM   #6
GOF
GOF is on a distinguished road
Steel hub/bearing assembly in an alloy knuckle. Toss in some road salt and and it destroys the bearings AND makes it hard to change them.
Add to GOF's Reputation
Rate the quality of this post and help GOF reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GOF is offline   Reply With Quote
Old 03-24-2011, 01:42 AM   #7
Shadow_tek001
Shadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of light
Shadow_tek001's Avatar
from 1st hand experience, it's a pain in the a@@. Get a torch, and a freeze can or upside down compressed air duster. freeze the hub and torch the knuckle *this was the final solution for me. Also, use loads of penetrating fluid (dont cause a fire tho).
The cv should come out pretty easy, but the hub will be really stuck in the knuckle.
I'm pretty sure I used a sledge hammer too, tho I cant remember.
Good Luck!
Edward
Add to Shadow_tek001's Reputation
Rate the quality of this post and help Shadow_tek001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Shadow_tek001 is offline   Reply With Quote
Wheel bearing noise 2006 Saturn Vue AWD wisconsin snowf Vue Tech 2 03-03-2011 04:22 PM
Torque value for 2006 ION front wheel bearing DonLove Ion Tech 1 08-31-2009 11:16 AM
Front Wheel Bearing Help justgiver S-Series Tech 3 05-27-2009 09:23 AM
Front wheel bearing... ym42 S-Series Tech 17 04-16-2006 09:55 AM
2006 Vue front wheel bearing (Hub) with ABS IMkenNY Vue Tech 4 04-15-2006 12:03 PM
