Old 03-07-2011, 08:22 PM   #1
Bealson Wheels
Bealson Wheels is on a distinguished road
1993 SW2
Default Diff pin went, put JY transmission in, only have park and neutral
1993 Saturn SW2. Differential Pin went about a month ago. Got a new transmission from local junk yard. Swapped VB from my old transmission into new because mine was rebuilt by Special Forces, Put JY transmission in. Broke shifter cable in process. Got a new cable from Advanced Auto. It is the Dohrman part. Car only has Park and Neutral. Any ideas?
Here is a video, I just uploaded it, may be a few mins till it is up.
http://www.youtube.com/watch?v=NsGhRzn475Y
Add to Bealson Wheels's Reputation
Rate the quality of this post and help Bealson Wheels reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bealson Wheels is offline   Reply With Quote
Old 03-07-2011, 08:39 PM   #2
Default Re: Diff pin went, put JY transmission in, only have park and neutral
Cable adjustment. Range switch adjustment. With luck that will fix it.
http://www.saturnfans.com/photos/sho...hp?photo=49744
http://www.saturnfans.com/forums/sho...d.php?t=144909 post #9
Old 03-07-2011, 10:09 PM   #3
Bealson Wheels
1993 SW2
Thanks will try that! Let ya know what happens.
Old 03-07-2011, 10:49 PM   #4
Yes, if that does not fix it check the 3 fuses.
Old 03-09-2011, 01:21 AM   #5
Bealson Wheels
1993 SW2
That did not fix the problem. I got continuity, but still only park and neutral. Will try the fuses tomorrow. Thanks for the help Oldnuc!!!
Old 03-09-2011, 11:34 PM   #6
Bealson Wheels
1993 SW2
No luck with the fuses either. Guess I gotta take it out and back to JY for exchange. Unless you know of something else that causes park and nuetral?
Old 03-16-2011, 03:02 AM   #7
Bealson Wheels
1993 SW2
Took the transmission back to the junk yard. They tried telling me that the car needs to be taken to a Saturn dealer for them to do a reprogram/relearn for the transmission. I put up a big fuss and they eventually gave me my money and core back. Was wondering if there is any truth to what they said? I know our transmissions are electronic, but I didn't think they were that advanced. Went to another junk yard and ordered another transmission. Will be putting it in tomorrow, thought it would be nice to know, if I need to go to GM. I figured OLDNUC would have said something if that was the case. Thanks in advanced.
Old 03-16-2011, 05:55 AM   #8
The later gen-2 and gen-3 trannies "learn" a little about driver habits; that's why they don't have the PERF/NORM switch. But your '93 doesn't, and moreover, all the "memory" is in the PCM, which didn't change. Members here swap auto trannies all the time, and the only "learning" going on is the neighbor kids learn a few new curse words...
What model of tranny was it?
Add to madpogue's Reputation
Old 03-16-2011, 10:27 AM   #9
No program required. The J/Y was wrong on that one. I do wonder if it was the wrong type of trans. When you switch the MP6 and MP7 into the incorrect car/PCM they usually shift once and then come up with a long list of codes.
Old 03-16-2011, 11:10 PM   #10
Bealson Wheels
1993 SW2
Well the new transmission went in without many problems. The new shift cable is complete junk and is the only problem I have now. I have adjusted it 2x and it keeps coming undone. I got it from Advanced and will be taking it back and going to Junk Yard to get a new/OLD (as OLDNUC suggested in another post) one from another S!2. I appreciate all the help and figure that the other tranny was just junk. Esp. since they told me it needed programmed. The new trans is from a 1993 and shifts well. I drove it about 15 miles with the cable messed up. I wasn't messing with it again.
Thanks again
Old 03-16-2011, 11:13 PM   #11
93 is a tough year to find a good trans for as there is an early one and a late one. Late you can use up to 97 IIRC but early you are stuck with a 93 and maybe a 92.
Old 03-19-2011, 02:22 AM   #12
Bealson Wheels
1993 SW2
Update
Drove the car about 120 miles today. At about mile 90, check engine light came on. Got home and used my jumper to read codes. Got a trans code 25 No TCC. How can I correct this?
Old 03-19-2011, 07:09 AM   #13
First thing to do is figure out if the TCC solenoid failed. Check the fuse and then if it is good check the solenoid resistance. There is a trans top plug pin diagram in my gallery that lists the 2 pins to check and shows the location.
Old 03-19-2011, 10:50 AM   #14
Bealson Wheels
1993 SW2
I checked the fuse, was good. I checked the resistance in the plug. I got a .56 and continuity sounded when I tested. I hope it's just the solenoid. I don't want to have to take trans out again. ::CROSSES FINGERS:: VB is not hard to R&R.
Old 03-19-2011, 11:53 AM   #15
Chazberry
Chazberry's Avatar
Maybe some help here . . .
http://i814.photobucket.com/albums/z...g?t=1300553511
http://i814.photobucket.com/albums/z...g?t=1300553564
Add to Chazberry's Reputation
Old 03-19-2011, 12:07 PM   #16
Check your range switch setting on the ohmmeter, 4.5 to 5.5 ohms is the nominal resistance of the solenoid. Check resistance at the connector on the trans pins E and K, and not at the plug/cable. http://www.saturnfans.com/photos/sho...hp?photo=52369
If this is where you checked and the resistance was actually 5.6 ohms the solenoid is good, then refer to the charts above.
If not a solenoid that would point at an internal VB problem.
Old 03-19-2011, 01:12 PM   #17
Bealson Wheels
1993 SW2
I changed the range switch on dvom and it was 5.6. So in those charts it says to do actuator test, but does not say how. Where can I get test info?
This is a rebuilt VB from Special Forces. It was in my old trans that the diff pin went in. I put it in new one to prevent the reverse slam issue in new junk yard trans. (Also I paid $200 for VB and knew it was good so figured why not?) Although I think the junk yard trans may have had the reverse issue. I was going up a steep hill and heard the sound of input/output shaft nuts being loose. I plan to get new nuts and install as soon as possible.
Old 03-19-2011, 01:22 PM   #18
Chazberry
Chazberry's Avatar
http://i814.photobucket.com/albums/z...g?t=1300558852
Old 03-19-2011, 01:37 PM   #19
If the nuts are loose that may be your actual cause. Does it set this code every time you drive or just every so often? Foreign material from the last transmission diff pin failure may have fouled your good VB also.
Old 03-19-2011, 02:00 PM   #20
Bealson Wheels
1993 SW2
Thanks for the actuator test. I have not drove it since the light came on. Did not want to cause any damage. I will drive it and see if it comes on again.
The diff pin went and car was not driven far, maybe 1/4 mile before stop. Towed it to place where we took trans out.
The nuts aren't that bad, only noticed it 1x and hill was very steep. Before I got new VB and tightened my new input/output shaft nuts, my old trans slipped a lot. It almost sounded like a supercharger whine. It would slip on level ground if enough gas was applied. It had a nice groove in the end cap cover. Not sure in this one. The slip happened at the start of my 120 mile trip (about 5 miles in). The check engine light did not come on until the end of my trip. About 13 or 14 miles till home.
High idle in park and neutral blakerybob03 S-Series Tech 4 03-03-2011 08:50 PM
Park Neutral Position Switch SaturnC1 L-Series Tech 2 05-01-2010 08:13 PM
rough idle in park or neutral... mlc5 Vue Tech 16 12-12-2009 06:13 PM
Transmission Issue and High Idle in park/neutral jamieg1984 Ion Tech 1 01-26-2007 08:59 AM
Tranmission Issue and High Idle in park/neutral jamieg1984 Ion General 3 01-19-2007 03:40 PM
