Old 02-27-2011, 10:23 PM   #1
jk3028
jk3028 is on a distinguished road
Default Wind Noise Fixed
I was getting wind noise and a buzzing sound on my 2007 Vue at highway speeds on both drivers and passenger doors. Very annoying, especially since it was right at ear level. Somewhere buried in another thread I remembered someone mentioning the Bernoulli effect, so I looked to the pieces of exterior trim on the rear of the window opening at the "B" pillar. As I tapped on them I could hear they were loose. Removing a screw at the top and bottom from the inside of the door / window frame and sliding the trim piece out towards the back of the door, found two molded-in hooks on the back of the trim that clip into the door sheet metal. Took a small piece of adhesive backed felt tape (BSR tape) and put it under each hook so they would be isolated from the sheet metal on both hook surface and part surface. Slid them back in place, reinstalled the screws. Make sure to keep track of which is which when you put them back in. The top one is a machine screw that goes into a threaded insert, the bottom one screws into a plastic boss on the chrome trim below the window...don't over tighten the bottom one. On the passenger side I found one of the hooks was broken, but fortunately was still stuck in the door...I'm guessing bad installation. I was able to super glue it back on, then put felt on those. When reinstalled, there was no movement when I tapped on them. The best part...no more wind noise or buzzing!
jk3028 is offline   Reply With Quote
Old 02-27-2011, 10:41 PM   #2
VTchemist
VTchemist's Avatar
Default Re: Wind Noise Fixed
Welcome to the Boards!
Good post on wind noise!
Old 02-27-2011, 10:45 PM   #3
jk3028
Thanks VT...learned a lot already from reading other posts, and will make sure to share anything else I find works. Much better to be able to fix things ourselves than pay $$$ for someone else to!
Old 03-08-2011, 08:54 PM   #4
RedManWalking
RedManWalking is on a distinguished road
I gave it a shot with silicone caulk. Removed the trim and put a generous amount of caulk under each hook. Happy to report...NO MORE WIND NOISE!!
RedManWalking is offline   Reply With Quote
Old 03-09-2011, 07:58 PM   #5
jk3028
Glad to hear it RedMan!
Old 03-10-2011, 06:25 PM   #6
stbvue
stbvue is a jewel in the roughstbvue is a jewel in the roughstbvue is a jewel in the rough
stbvue's Avatar
I fixed that problem along time ago.....Turn up the radio!
I dont mind things that go bump in the night as long as they arent in my VUE!
stbvue is offline   Reply With Quote
Old 03-15-2011, 12:27 PM   #7
SoCalVue
SoCalVue is on a distinguished road
2004 VUE 3.5L
fixed mine a few years ago using adhesive-backed foam weather-stripping tape... worked like a charm.
SoCalVue is offline   Reply With Quote
Old 03-16-2011, 07:22 PM   #8
onecoolpilot
onecoolpilot is on a distinguished road
I'm having a hard time picturing this. I took the panel off and I see the little plastic hooks. Am I supposed to put the felt or whatever I find under the "hook" part of the hook? or on the plastic part around the hook?
Am I trying to keep the big plastic panel from vibrating against the metal of the door?
Thanks for your help, maybe now I can finally convince my wife that the window IS sealed good...
onecoolpilot is offline   Reply With Quote
Old 03-17-2011, 08:54 PM   #9
jk3028
Put the material under the 'hook' part. If you imagine it as a "C" you want to cover the inside of the "C" to isolate it from metal contact and tighten the hook to the door sheetmetal. The hook then does what it is supposed to do...keep the panel tight to the door and not allow the wind to suck it out and get underneath it.
Old 03-17-2011, 10:30 PM   #10
far2grumpy
far2grumpy's Avatar
jk3028 ... thats a darn good idea - your next mission is to figure out how to fix torque converters, noisy struts and prop-shaft bearings.
Old 03-18-2011, 07:01 PM   #11
jk3028
I hear ya! Now that the weather is warming up I'm on a mission to fix the rest of the noises....only wish the ones you mentioned were as easy!
Old 03-19-2011, 03:56 PM   #12
Chazberry
Chazberry's Avatar
1995 SW2
How about this?
Old 03-21-2011, 10:10 AM   #13
RedManWalking
I put a glob of silicone under each hook and around each slot for the hooks. I did this to a 2003 Vue where all the hooks were broken by putting caulk in the same spots and it worked.
Old 03-21-2011, 06:13 PM   #14
TheVue
TheVue is on a distinguished road
TheVue's Avatar
Originally Posted by Chazberry View Post
How about this?
That is exactly what I did, a little household weather stripping in that same area made a big improvement with the wind noise.
TheVue is offline   Reply With Quote
Old 03-23-2011, 04:30 PM   #15
SoCalVue
2004 VUE 3.5L
... the foam weatherstripping tape expands, and keeps the panels from rattling in the wind.
Old 05-13-2011, 01:07 AM   #16
linx3566
linx3566 will become famous soon enough
2007 VUE Green Line
How about this?
How do you remove the panel?
linx3566 is offline   Reply With Quote
Old 05-13-2011, 12:25 PM   #17
jk3028
See beginning of thread...
Old 05-18-2011, 01:19 AM   #18
Shadow_tek001
Shadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of light
Shadow_tek001's Avatar
Hmm, weird, I just did this about 3 weeks ago, both my clips on the passanger side were broken. But rather then put adhesive or weather stripping on them, I just cleaned them both, glued the clips back on and re-installed them with nice tight screws. viola, no noise.
Edward.
Shadow_tek001 is offline   Reply With Quote
wind noise mrblugil Vue General 15 12-10-2006 12:30 AM
Air or Wind Noise agtaylor Vue General 13 11-03-2006 08:05 AM
Wind Noise, Self Fix? (How?) washamur Ion General 4 05-22-2004 03:14 PM
Wind noise in VUE FIXED!!!!!!!!! dressshop Vue General 10 06-04-2002 05:50 PM
Wind Noise Gone ricksLS1 General Saturn Discussion 0 04-18-2001 01:02 PM
