Old 02-24-2011, 05:29 PM   #1
mfoster670
mfoster670 is on a distinguished road
Roll Eyes 2000 Saturn SL1 High Idle
I have a 2000 Saturn SL1 that just recently started idling high (around 3000 RPM). Someone mentioned to me checking the idle screw... Not sure if this car has one, or if that is even a possible solution.
Any help or suggestions is greatly appreciated!
-Mike
Add to mfoster670's Reputation
Rate the quality of this post and help mfoster670 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mfoster670 is offline   Reply With Quote
Old 02-24-2011, 06:43 PM   #2
Default Re: 2000 Saturn SL1 High Idle
There is no idle screw. Idle is set by a solenoid controlled by the PCM.
Most common high-idle cause on a third-generation SOHC engine is a vacuum leak via the intake manifold gasket. Characteristic flaw. Start the engine and spray something like brake cleaner along the joint between the intake manifold and the cylinder head. If the "idle" changes, that indicates it's sucking in the sprayed substance through the leak. IM gasket replacement is the fix. Doable "in-frame", with hand tools.
Add to madpogue's Reputation
Old 02-24-2011, 06:50 PM   #3
mfoster670
Thank you very much for your reply! I'm not a mechanic; do you think this is something I should even attempt on my own?
Thanks again.
Old 02-24-2011, 08:12 PM   #4
DrGonzo
DrGonzo is on a distinguished road
most of the people on here aren't mechanics either, and i'm definitely NOT one, but I can tell you that changing the intake manifold gasket is a daunting, but simple, task. I just did mine one week ago. The biggest key is to make sure you have all the needed parts and tools to make the job easy. THIS thread will tell you everything you need to know about how to do it, and what you need and what to expect.
You might also try THIS thread to see other possible culprits of a high idle.
Mostly likely it's the intake gasket though.
2000 SL1 164k
Add to DrGonzo's Reputation
Rate the quality of this post and help DrGonzo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DrGonzo is offline   Reply With Quote
Old 12-16-2013, 08:13 PM   #5
skygoin
skygoin is on a distinguished road
I had the same problem it turned out to be carbon build up in the throttle body. I found the following youtube helpful.
Saturn Idle problem.mov
Add to skygoin's Reputation
Rate the quality of this post and help skygoin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skygoin is offline   Reply With Quote
Old 12-16-2013, 09:18 PM   #6
SL19302
SL19302's Avatar
2002 SL1
-Mike
Racing at 3,000 RPM is most likely the intake gasket has failed at the number one cylinder intake runner, You can verify this by simply spraying carb cleaner right where the intake manifold bolts to the cylinder head, The area of interest is located just below the power steering pump, If you spray that area and the idle changes or the engine stumbles the gasket is bad.
CHECK YOUR OIL!
Add to SL19302's Reputation
2000 Saturn L high idle Maxine L-Series Tech 1 02-27-2010 09:55 PM
car idles high, 2000 rpm idle pimpin88 S-Series Tech 7 12-11-2009 05:49 PM
2000 SC1 High Idle & Misfire Gold Saturn S-Series Tech 4 06-01-2009 09:27 AM
2000 SL1 high idle amory S-Series General 3 03-06-2006 08:35 AM
high idle on sl 2000 vitali-k S-Series Tech 16 08-02-2005 10:03 PM
