Old 01-31-2011, 07:23 PM   #1
raday
raday is on a distinguished road
2006 VUE 2.2L
Default Hub caps
I have a 2006 Saturn Vue with the 4cyl and automatic transmission. I have hub caps on the wheels. I looked in the manual and it does not discuss the hub caps except to say you have to take them off before removing the wheel.
My concern is this. I can move them with my hand, sliding them back and forth. They look as though they are bolted on with the lug nuts, but if I can move them then are my lug nuts loose? I am used to having hub caps that grip the rim from the edge. I have seen on here people talking about them getting put on too tight when rotating the tires. I guess what I am asking is how do they work?
Add to raday's Reputation
Rate the quality of this post and help raday reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
raday is offline   Reply With Quote
Old 02-01-2011, 04:31 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Hub caps
raday ... I don't have a 2006 and am not sure I understand what sort of wheel cover you have.
I checked the 2006 owners manual which mentions a wheel cover held in place by captive fasteners which are attached to wheel lug-nuts.
If the plastic lug-nut covers are loose enough to move the wheel cover - it might be a good idea to remove the cover to check torque of the actual wheel lug-nuts.
BTW - the plastic lug-nut covers are captive to the wheel cover so don't try to remove them from the wheel cover.
Old 02-01-2011, 06:22 PM   #3
raday
2006 VUE 2.2L
So if I understand you the hub caps have covers built into the wheel cover that clip over the lug nuts?
Do I then pop the wheel cover off just like the old style wheel covers with a screw driver or lug wrench?
It kind of looks like the plastic caps on the lug nuts are separate from the wheel cover.
Sorry it is kind of confusing, but I just do not want to break them.
Thanks
Old 02-01-2011, 07:08 PM   #4
far2grumpy
far2grumpy's Avatar
Thanks
The lug-nut covers (on my 2005 Vue) screw on ... they are same size as lug-nut.
My lug-nut covers are loosely attached to the wheel cover so once all five are loosened the wheel cover should be removable. You may have to use a screwdriver or other flat tipped tool to "gently" lift the cover for removal.
For installation - manual indicates fasten each plastic lug-nut cover to a lug-nut by hand and then use lug wrench to turn slightly to fasten (1/2 turn).
Plastic Hub caps?? What the @#%%?? davesaturn Ion Tech 7 05-03-2010 08:52 PM
lug caps JC2002SILVERSC2 Classifieds 14 08-11-2006 02:55 PM
peeling hub caps walt Vue General 11 07-05-2005 03:35 PM
Hub caps SoUp S-Series General 3 09-19-2003 11:17 AM
Gas Caps skijay Miscellaneous Tech 5 09-10-2002 11:30 AM
