Old 01-30-2011, 06:20 PM   #1
chingondearmona
chingondearmona is on a distinguished road
chingondearmona's Avatar
Default Leaking Water Door
So its sunday, started out with a beautiful day but suddenly clouds moved in and brought heavy rain, i am having a leak through the top of the driver side door, i had this problem for the last couple of years but suddenly it just started to get worse, i was wondering if anywho else had this problem before and if its just a door seal issue or something is loose? and if its a seal issue how do you go about getting a replacement. i was looking at the seal and it looks like its attached somehow to the door. any help please!
1995 Saturn SL2 DOHC 1.9 L
Add to chingondearmona's Reputation
Rate the quality of this post and help chingondearmona reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chingondearmona is offline   Reply With Quote
Old 01-30-2011, 06:49 PM   #2
PlasticCarsRock
PlasticCarsRock's Avatar
Default Re: Leaking Water Door
The door will leak if it's not closed all the way, but you would have noticed that, I'm sure. Check to make sure the latch is adjusted properly (does the door take about the same force to close as the passenger side front door?).
If it's a seal, they're relatively easy to replace. You can get a replacement for a few dollars from a junkyard. The one that goes all the way around the door is the one you'll probably need. I believe it just kinda presses in, so you should just be able to pull it out (if you get it from a pick-n-pull style yard, you'll see how it goes back together).
Old 01-30-2011, 07:00 PM   #3
Unless your careful & slow with a pair of pliers and/or flat tip screwdriver I don't recommend getting a used seal from a junkyard. Freaking annoying & the rubber tears very freaking easy. Somehow the passenger door seal on my not very rusty, in decent shape '96 SC2 was in much worse condition then the one on a '95 SC1 I had for parts so I swapped 'em.
The top just presses in (mines caulked in because they changed shape or something '95-'96) & the rest (parts that aren't around the window) are held in with plastic purple tabs every 3" or so.
Old 01-30-2011, 08:42 PM   #4
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Post Re: Leaking Water Door
Reseal drip rail where roof meets moulding above door. Search for wolfman in How To library. I had the same problem sealed both sides and still dry since 2005.
1995 SL1 177,800 and go'in strong!!
CHECK YOUR OIL!!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-30-2011, 09:45 PM   #5
SL19302
SL19302's Avatar
2002 SL1
Thats correct the drip rail that runs along the roof ends up loosing its adheasive over the years and separates from the roof panels, the usual fix and this I know sounds cheesy but if you put a small bead of clear silicone sealant along the drip rail on the roof line it will fix all your water problems with the front doors when it rains.
Add to SL19302's Reputation
Old 04-25-2013, 12:42 PM   #6
trottida
trottida's Avatar
http://www.saturnfans.com/forums/sho...fman+drip+rail
Current rides
2001 SL1 MT (410,500 km @ 11/2017)
1999 SL2 MT (251,500 km @ 11/2017)
2011 Suburban LT (101,450 km @ 11/2017)
:canada:
Add to trottida's Reputation
Old 04-26-2013, 10:22 AM   #7
Tawnylane
Tawnylane is on a distinguished road
1998 SW2
1994 SW2
Bless you for asking this question! This has been a minor issue for "Charlie" (94 HCE). Had researched and found bending the doors but did not seem to help and it really didn't seem to be the source. but this sounds like our problem. Will do it next week when both the 94 models (car and driver ) get home from college for the summer.
Thanks!
Add to Tawnylane's Reputation
Rate the quality of this post and help Tawnylane reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tawnylane is offline   Reply With Quote
Old 04-26-2013, 10:40 AM   #8
You named your Homecoming car after the founder of this forum? Cool.....
Add to madpogue's Reputation
Old 04-26-2013, 06:14 PM   #9
Tawnylane
1998 SW2
1994 SW2
LOL!
Serendipity!
My son named it for his sister... seems to fit well tho'
Old 04-26-2013, 09:43 PM   #10
off-track
off-track's Avatar
His sister is named Charlie??
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 04-26-2013, 10:06 PM   #11
Tawnylane
1998 SW2
1994 SW2
Yeah after I retread that, it sure came out that way!
SHE could come up with a name, so he did it for her. How's that?
Water Leaking into Door ecbahs Aura General 4 03-11-2008 01:22 PM
Water Leaking Thru The Door - Help!!! yougotit S-Series Tech 0 12-31-2007 01:49 PM
SL1 leaking water spinstylez S-Series Tech 2 09-21-2006 02:30 PM
Water leaking in from passenger side door Lurker1999 S-Series Tech 6 11-23-2005 02:30 PM
Water Leaking Through Top of Door Andy L. S-Series Tech 6 04-09-2003 10:05 PM
