Old 01-21-2011, 06:50 PM   #1
dalamarmoon
dalamarmoon is on a distinguished road
Default A BSTI question/stuck in park
Is the BSTI solinoid the same as park lock solinoid in 95 Saturn sc2? And also can that solinoid cause trans to slip in 3rd and 4th gears? Or do i have 2 seperate problems going on. Car tries to get stuck in park. Which is new problem, slipping is old problem still running down. Both intermintant. But not always happen at same time. Park only gets stuck when very cold. But even cold outside once cabin warm. Shifts fine out of park. Heard BSTI is tied in with park/netral switch. if i unplug switch car doesent slip. Already replaced. Yet car slips. Can a BSTI cause so much trouble?
Add to dalamarmoon's Reputation
Rate the quality of this post and help dalamarmoon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dalamarmoon is offline   Reply With Quote
Old 01-22-2011, 01:05 AM   #2
chingondearmona
chingondearmona is on a distinguished road
chingondearmona's Avatar
Default Re: A BSTI question/stuck in park
Im going through the same problem with the Brake Transaxle Shifter Interlock (BTSI) System, I have a haynes repair manual for all S-Series Models from 91-02. According to the book the BTSI system is not tied to the Transaxle Neutral Safety Switch, Therefore You Are Having Two Separate Problems. The BTSI prevents the car from being shifted out of park. The Neutral Safety Switch tells The PCM which transaxle gears to allow depending on your Shift Lever Position such as P R N D 3 2. If your gears are slipping most likely its a valve body issue, search forum for slipping transmission or reverse slam cure.
1995 Saturn SL2 DOHC 1.9 L
Add to chingondearmona's Reputation
Rate the quality of this post and help chingondearmona reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chingondearmona is offline   Reply With Quote
96 sl2 automatic getting stuck in park sdowney717 S-Series Tech 12 11-30-2009 01:06 AM
Park Brake Stuck?? My95Sl2 S-Series General 7 04-07-2009 11:32 AM
SC2 is stuck in park! tggroo7 S-Series Tech 7 03-12-2009 05:29 PM
Sw2 Stuck In Park! Donny S-Series Tech 6 12-05-2004 09:32 PM
Automatic tranny question:Stuck in Park buddywolf5 Miscellaneous Tech 1 10-07-2003 10:24 PM
