Old 01-15-2011, 10:59 AM   #1
ALAK
ALAK is on a distinguished road
Dizzy 96 sl2, we replaced many parts and still have idle issues..
96 SL2 1.9 DOHC- We replaced the head gasket, intake gasket, exhaust gasket, exhaust flange, TPS, fuel pressure regulator, PCV valve, air filter, spark plugs, the belt, belt tension, valve cover gasket, and the battery. The car starts and whenever you put it in park or neutral it idles up to 2000 then drops back down to anywhere from 500-800. If you are stopped at a light and you let your foot off the brake it will go on its own and get up to 25mph without giving it any gas. We had the purge solenoid hoses mixed up and finally have them on right. Right before we fixed the hoses and replaced the throttle position sensor, the rpms would drop really low and sometimes it would even stall while in park. I think there might be a vacuum leak somewhere and we just can’t seem to find it. There is a bolt broken off in the exhaust manifold but we are unable to get it out. Would this cause the problem or is this only going to increase the noise? I don't know what else to try....??
Add to ALAK's Reputation
Rate the quality of this post and help ALAK reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ALAK is offline   Reply With Quote
Old 01-15-2011, 11:07 AM   #2
bluesl2
bluesl2's Avatar
Default Re: 96 sl2, we replaced many parts and still have idle issues..
If you put this in the s-series section you will get more responses. Check the vacuum booster hose and see if that is hooked up.
Add to bluesl2's Reputation
Old 01-15-2011, 11:13 AM   #3
ALAK
Where is that hose? How do I move this? Or do I retype it?
Old 01-15-2011, 12:04 PM   #4
Partymmudasti
Partymmudasti is on a distinguished road
Partymmudasti's Avatar
You either PM a Moderator to move it, or retype it in the S-Series forums.
The engine in the S-Series is totally different than our engines in our L-Series cars. Have no idea what you are talking about.
Add to Partymmudasti's Reputation
Rate the quality of this post and help Partymmudasti reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Partymmudasti is offline   Reply With Quote
Old 02-07-2011, 12:23 PM   #5
isosceles
isosceles is on a distinguished road
this might seem like a long shot, but are you sure you have a thermostat in your car and that the motor is operating within the specified temps.
My car used to idle about 1200-1500 even after driving it for a while.
Here is why I suggest that: While taking a long trip this weekend, on the way home I noticed the coolant temp was barely above the "C". That is too cold for these cars to continualy operatate. The ECU will keep the mixture too rich, etc.
I suspected that the previous owner had removed the thermostat. Yesterday, I bought a replacement T-stat from Napa. When I took the water outlet off the block, sure-enough there was no T-stat.
After I replaced the T-stat, the engine is operating at the correct temp and the car does not idle fast anymore.
Mark
99 SL2 5 sp. bone stock
“When the only tool you own is a hammer, every problem begins to resemble a nail.” .Abraham Maslow
Add to isosceles's Reputation
Rate the quality of this post and help isosceles reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
isosceles is offline   Reply With Quote
Old 02-07-2011, 12:56 PM   #6
solorider
solorider is on a distinguished road
2000 SL2
Im having the same problem with my 2000 sl2. The problem went away 3 days ago and started acting up again this morning the only thing i didnt replace was my TPS because it doesent seem like it was related . Ive searched this site up and down and cant seem to find a solution. Any and all advice would really help u guys!
Add to solorider's Reputation
Rate the quality of this post and help solorider reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
solorider is offline   Reply With Quote
Old 02-07-2011, 01:38 PM   #7
Partymmudasti
Really guys? Do you read the thread AT ALL before you post?
Myself and another member said right away that this is the L-Series forum and you arent going to get many (if any) responses here. You need to post in the S-Series forum, or go through the member list of the site and private message a Moderator to move the thread completely.
The L-Series and S-Series are two totally different beasts with completely different powertrains, built on completely different platforms.
What parts have you replaced..... mgordon1100 S-Series General 40 09-07-2009 04:12 PM
Replaced bad injector idle improved a little nmsaty S-Series General 8 03-19-2009 08:02 AM
P0341 after a lot of parts replaced nikita_mobile S-Series Tech 14 03-21-2007 02:35 PM
95 sc1 overheating replaced quite a few parts, little help here? niftynico S-Series General 18 07-24-2006 10:34 PM
motor mount replaced - issues JS593 S-Series General 7 09-29-2005 06:37 AM
