Old 01-08-2011, 02:08 PM   #1
vickyvp
vickyvp has a spectacular aura aboutvickyvp has a spectacular aura about
2009 AURA XE
Default 09 Aura Check Engine light
Can anyone tell me where the port is to plug in the odb2 reader for this car? The check engine light came on a little over 50,000 miles. Yes, already know about the gas cap issue and have checked. Just want to get the code before I take it in to the shop on Monday and NOT get blown away...
Vicky
95 Saturn SL1 with 220k...replaced engine with 99 w/66k Jan '11
09 Saturn Aura 60,000
07 Dodge Ram 2500 Laramie Diesel 33k
Add to vickyvp's Reputation
Rate the quality of this post and help vickyvp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vickyvp is offline   Reply With Quote
Old 01-08-2011, 02:48 PM   #2
Default Re: 09 Aura Check Engine light
Unless your Aura is different from any other USA car or suv, the DLC is always located next to the steering wheel column under the knee bolster when you look under. Some expensive cars will hide theirs behind an access cover that needs to be popped off. Most are visible. Most Autozone clerks know where to plug in their store readers so watch them as they retrieve the error codes for free. Just be sure to read the display and write down any codes as they suggest some parts to replace. Kindly ignore their suggestions if they're not ASE certified in diagnostics, troubleshooting, and repairs of any make or model of car or suv.
Old 01-08-2011, 06:52 PM   #3
greenman
2009 AURA XE
Write down the code/s & post back with it/them. More than likely we can point you in a direction that would save you money. Depends on your level of car experience.
Add to greenman's Reputation
Old 01-08-2011, 08:23 PM   #4
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
also can get code by pushing the blue button on the mirror
Add to onefunkar's Reputation
Old 01-08-2011, 09:46 PM   #5
greenman
2009 AURA XE
Only true if you are paying for onstar right?
Old 08-31-2011, 08:09 PM   #6
rosen123
rosen123 is on a distinguished road
My light just came on as well, have 52000.00 miles. auto zone said dirty fuel injectors and told me to use cleaner with a full tank of good gas. let the tank go dry and refilled but light is still on so does mechanic have to reset or will it go out on its own?
I did notice that I got better mileage on that tank of gas.
Add to rosen123's Reputation
Rate the quality of this post and help rosen123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rosen123 is offline   Reply With Quote
Old 08-31-2011, 09:04 PM   #7
greenman
2009 AURA XE
What was the exact code/s & which engine?
Old 09-01-2011, 04:11 PM   #8
greenman
2009 AURA XE
There is no code for dirty fuel injectors so that is some store clerk's interpretation of the code/s. I would encourage you to be wary of any advice you get at an Autozone. Don't assume they know what they're talking about. The code/s itself is the thing you need to give us along with your best attempt at describing the symptoms & the details of your car. With that info we can usually help point you in the right direction.
Old 01-06-2017, 02:49 PM   #9
burttoast
burttoast is on a distinguished road
2009 ION-2 Sedan
2007
My 2009 Aura (70,000 miles) on a really damp and humid day the CHECK ENGINE LIGHT came on and stayed lit (not blinking) I drove it after OnStar told me to wait a few days to see if it goes out,,,, and yes after I filled it up and drove it for a little while the light went off,,,,,,
Now weeks later it is BITTER COLD here and the check engine light came back on but this time my TEMPERATURE GAUGE did not move off of COLD even though I had driven miles,,,, called OnStar and they said it indicated something wrong with my coolant system = I chuckled and said that's probably it but they thought maybe the gauge was reading HOT ,,, well after going in to warm up I decided to drive to the dealership but in a short distance the temp gauge went to normal and stayed there, so I looped around and went and fillled it up with premium SHELL once again and drove it home and let it sit....Im sure there are a lot of places that will check it out,,IF NEED BE but I will wait a few days first hoping for warmer weather
Add to burttoast's Reputation
Rate the quality of this post and help burttoast reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burttoast is offline   Reply With Quote
Old 01-06-2017, 05:18 PM   #10
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
maybe thermostat sticking
Old 03-07-2017, 11:19 PM   #11
kknobl
kknobl will become famous soon enough
kknobl's Avatar
2009 AURA XE
2008 Outlook XE
Take it to AutoZone. They'll give you the code, then you can Google it to find out what it's pointing to.
Right around 50K is when one of the VVT solenoids went on mine. Replaced both since I had the cover off. Fairly easy DIY job.
Add to kknobl's Reputation
Rate the quality of this post and help kknobl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kknobl is offline   Reply With Quote
Old 03-08-2017, 07:02 PM   #12
mmtphoto
mmtphoto is a jewel in the roughmmtphoto is a jewel in the roughmmtphoto is a jewel in the rough
mmtphoto's Avatar
2007 AURA XR
ok this is 5-6 years old BUT-
let the tank go DRY...? Is the 'Auto Zone' guy going to BUY YOU A FUEL PUMP. since gas keeps the pump cool...now I think I've heard everything, along with endangering your pump, the garbage in the bottom of your tank gets sucked up into your fuel line, hopefully gets filtered by the fuel filter then to your injectors which also could be damaged by such advise. Glad it 'runs better' though I doubt anything that genius said helped in the long run.
Add to mmtphoto's Reputation
Rate the quality of this post and help mmtphoto reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mmtphoto is offline   Reply With Quote
Check Engine Light 07 Aura XR lovegunxr Aura General 8 10-06-2013 12:41 PM
Engine stall with check engine light dumez Ion General 1 07-31-2010 01:52 PM
check engine light and antitheft light 2004 L300 jonus311 L-Series Tech 2 01-31-2009 08:55 AM
Check Engine Light/ Temperture light storm_amoure S-Series Tech 3 07-28-2007 10:07 PM
Check Engine Light W/ Reduced Power light saturnfreak01 L-Series Tech 5 01-24-2004 11:04 PM
