Old 01-03-2011, 03:19 PM   #1
diplomat1
diplomat1 is on a distinguished road
diplomat1's Avatar
Default Best thermostat and best spark plugs/wires?
I am replacing both of them soon and i wanted to know which where the best for each of them. I read there is a 185f and 195f or something like that thermostat which is better for my 94 saturn sl2? Also what are the best spark plugs and spark plug wires too for my car. Thanks
Prince
Add to diplomat1's Reputation
Rate the quality of this post and help diplomat1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
diplomat1 is offline   Reply With Quote
Old 01-03-2011, 03:57 PM   #2
acfortier
acfortier is on a distinguished road
2000 SL2
Default Re: Best thermostat and best spark plugs/wires?
Stant Thermostat 14279 and NGK Copper BKR4ESA-11 plugs. I also bought the Xact wireset from Advance Auto (where both of these parts can be obtained), but I don't think that is much of an impact.
Add to acfortier's Reputation
Rate the quality of this post and help acfortier reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acfortier is offline   Reply With Quote
Old 01-03-2011, 04:44 PM   #3
For the DOHC, you'll want BKR5ESA-11.
BKR4ESA-11 is recommended for the SOHC engines
edit: it's a difference in heat rating - slightly colder for the DOHC engines
Old 01-03-2011, 05:33 PM   #4
adventureoflink
adventureoflink's Avatar
+1 to acfortier and alordofchaos.
I personally use AC-Delco plug wires.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 01-03-2011, 05:59 PM   #5
diplomat1
diplomat1's Avatar
Is it nickel or copper? Because when i look up BKR5ESA-11 only nickle comes up. (i know im stupid and this is a stupid question ) Thanks. Also does spark plug wires differ in quality?
Edit: Also i already bought 4 AC DELCO spark plugs (41-627) a while back. My question is which one is better the NGK BKR5ESA-11 or AC DELCO 41-627. Thanks again.
Prince
Old 01-03-2011, 06:12 PM   #6
adventureoflink
It's a copper core plug. don't worry.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 01-03-2011, 06:26 PM   #7
SLCraig
NGK are the OEM plugs, but AC Delcos work fine. I've also personally used Champions with no problems, just make sure they are coppers and gapped properly, and you should be good to go.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-04-2011, 05:11 AM   #8
diplomat1
diplomat1's Avatar
I found the thermostat at a local pep boys same part number but this is what it says
188 DEG THERMOSTAT
* LIMITED ONE YEAR WARRANTY
* SEAL INCLUDED - OE TEMPERATURE
14279 STANT THERMOSTATS 1 $21.99
When i go into more detail it says this:
Part Number 14279
Type Regular Thermostat
Temperature 195 Degree F
Design Thermostat Kit
Jiggle Pin No
Number of Check Valves 0
Number of Seals 1
So is this the right thermostat even thou it says 188 Deg thermostat in the beginning. Thanks
Prince
Old 01-04-2011, 05:39 AM   #9
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
thats it.
Old 01-04-2011, 07:33 AM   #10
Baron5867
Baron5867 is just really niceBaron5867 is just really niceBaron5867 is just really niceBaron5867 is just really nice
1994 SC1
Yes, particularly if you maintain the car and pull them on & off the plugs.
I prefer the AC delco wires. I actually installed the Xact wires from Advance Auto in a rush when I purchased the car, and I wasn't impressed. I've installed the stant 14279 thermostat mentioned here. I've used NGK, AC-Delco and Autolite copper plugs, and noticed no difference; I usually just install the Autolites out of habit.
These items are best purchased off of RockAuto if shipping works out for you, particularly the AC Delco wires. You may want to order a couple of Wix oil filters as well.
Add to Baron5867's Reputation
Rate the quality of this post and help Baron5867 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Baron5867 is offline   Reply With Quote
Old 01-04-2011, 09:17 AM   #11
SLCraig
I have not used AC Delco wires myself (pulled some from JY for spares) but my Belden premiums (Napa) have been working well on my 96 for 35K KMs or so.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
Old 01-05-2011, 05:14 PM   #12
Frankd1
Frankd1 is on a distinguished road
1998 SL1
I have standard motor products (SMP) wires from Rock Auto - $15, so far they have been working good, I plan to change them though when I change the plugs..
Add to Frankd1's Reputation
Rate the quality of this post and help Frankd1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Frankd1 is offline   Reply With Quote
Old 10-27-2012, 01:31 AM   #13
1996SaturnSL2
1996SaturnSL2 is on a distinguished road
188 DEG THERMOSTAT
Part Number 14279
Jiggle Pin No
Number of Seals 1
I live near LA, lots of highway and heavy stop and go traffic. Would not a lower temperature (185 degree) thermostat open sooner, create less back pressure in the cooling system since the thermostat opens up sooner and also let your car run just a bit cooler? I am worried about blowing out my old radiator and water pump seals if I use a 195 degree thermostat.
Add to 1996SaturnSL2's Reputation
Rate the quality of this post and help 1996SaturnSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SaturnSL2 is offline   Reply With Quote
Old 10-27-2012, 10:56 PM   #14
Signmaster
Signmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to behold
Back when that '94 was built, AC Delco actually still produced their own plugs, and they shipped in many Saturns. NGK was but one of several OEM plug manufacturers, and I don't think they were ever the exclusive supplier for the OEM plugs.
It's one of the misconceptions often repeated on these forums, and was clarified by someone that works for NGK.
Old 10-27-2012, 11:00 PM   #15
Signmaster
I've seen more posts than I can count that state the cooler thermostats will destroy MPG, cause issues, etc. But our car shipped with a cooler thermostat from the factory and ran just fine with it. It actually got slightly better MPG with the cooler thermostat as well.
There may be units that run too cool, but personally I think a lot of it is paranoia. Our factory unit ran not much above 1/4 on the gauge (keep in mind earlier models like our '95 have a different gauge calibration) and never had issues. My personal opinion is that if I had to change thermostats again I would seek out the cooler one vs the warmer running unit that I replaced the OEM with.
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 07:29 AM
Dealer pricing on spark plug wires and spark plugs. KeithR S-Series General 25 05-19-2011 11:52 PM
Changed spark plugs and wires, look at old plugs (pics) Chingon S-Series General 12 03-30-2005 02:42 AM
Spark plugs/wires viperssaturn S-Series Tech 7 03-27-2005 11:15 PM
Spark plugs and wires SC2racer S-Series Tech 2 11-26-2004 12:54 AM
