Old 12-22-2010, 02:02 PM   #1
twelvewheels
twelvewheels is on a distinguished road
Default Erratic Speedometer
My 1992 SL1 with approx. 120k miles is fairly new to me. When I got it the speedometer was working properly but the odometer wasn't. I replaced the two broken (expensive) gears in the odometer and everything was fine for a time.
Now the speedometer will peg at 110mph as soon as you start moving then after a time will settle at 75 to 85mph pretty much independent of actual speed. When stopped it will read either 0 or 110 mph. The odometer is still working properly.
I have disconnected and re-connected the instrument panel connector but no change. Has anyone run into this? Bad connections at speedo board? Bad board? Thanks, Tom
Add to twelvewheels's Reputation
Rate the quality of this post and help twelvewheels reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twelvewheels is offline   Reply With Quote
Old 12-19-2011, 12:24 AM   #2
_Highliner
_Highliner is on a distinguished road
Default Re: Erratic Speedometer
My speedometer only shows the correct speed or it shows zero even at speed. A couple of taps above the speedometer on the dashboard and it always pops back into place and shows the correct speed. I also had one of the dashboard lights start working again after I rapped the top of the dash a couple of times.
196,000 miles, 1.9L, 1994 Saturn SL. Rebuilt motor and transmission, 190lbs. compression.
Add to _Highliner's Reputation
Rate the quality of this post and help _Highliner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
_Highliner is offline   Reply With Quote
Old 12-19-2011, 10:40 PM   #3
Midnight13
Midnight13 is on a distinguished road
Midnight13's Avatar
1998 SL
Mine will show speed as i'm getting up to speed, then will drop down to zero even moving. If I lift up from behind the clutch and hold it there, it reads right again, I have no idea what's doing it. If I have long trips, it's a pain, but doesn't even bother me otherwise.
"Not for human consumption!" - Peas in the Pod
http://www.facebook.com/#!/pages/Peas-in-a-Pod/160649663950771
Add to Midnight13's Reputation
Rate the quality of this post and help Midnight13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Midnight13 is offline   Reply With Quote
Transmission and Erratic Speedometer saturndaniel L-Series Tech 2 11-03-2010 08:26 PM
very erratic shifting bannasc1 S-Series Tech 6 10-28-2009 03:16 PM
Erratic Idle Tom64 S-Series Tech 2 12-02-2007 10:59 PM
Erratic Speedometer beensmoked L-Series Tech 0 09-19-2007 07:03 AM
Erratic Shifting 95 Sl2 jegg403 S-Series Tech 12 04-16-2007 11:05 PM
