Old 12-10-2010, 02:02 AM   #1
ingledum
ingledum is on a distinguished road
2003 ION-1 Sedan
1999 SL
Default ignition switch replacement
My 2003 ion is having the passlock starter issues in cold mornings. On a different post I've seen pictures of the electrical pcb which interacts with the key tumbler to enable/disable the passlock security system. From what I can rtell, I figure the root cause is the small pcb and not the key tumbler itself. Where can I find instructions on how to replace the pcb? Anyone have a part number for the pcb for a 2003 Ion?
Add to ingledum's Reputation
Rate the quality of this post and help ingledum reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ingledum is offline   Reply With Quote
Old 12-10-2010, 03:24 AM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: ignition switch replacement
you replace the switch, not the lock cylinder. your local GM dealership can get you the switch. you cannot buy parts of the switch assembly, just the assembly.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Need help with Ignition switch replacement spynet Ion General 3 12-21-2009 06:09 PM
99 SL ignition Switch replacement Q's matt93&04 S-Series Tech 2 04-03-2009 09:18 PM
Ignition switch replacement Toby Windsor S-Series Tech 2 05-17-2008 10:34 PM
ignition switch replacement AmericanImport S-Series Tech 4 03-06-2008 04:45 PM
Ignition Switch Replacement Tips? Leadsled Coupe S-Series General 7 03-02-2007 02:03 PM
