Old 12-06-2010, 11:14 PM   #1
nichitect
nichitect is on a distinguished road
Default Rusted fuel lines
Anyone else's fuel lines rust out in just one 8" section about a foot away from the rear tire at the clip?
This weekend as I was taking the wife's 03 4-door around for errands I could smell gas when I got out of the car I notched a puddle and gas dripping out to the ground. Brought it to my garage and it turns out both the vent and fuel lines are completely rusted through.
The strange part is the remainder of the line looks perfect...
So just as a heads up if you smell some gas, check your lines..
Add to nichitect's Reputation
Rate the quality of this post and help nichitect reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nichitect is offline   Reply With Quote
Old 12-06-2010, 11:26 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Rusted fuel lines
it's not a common topic on the forums, so I'm going to say it's uncommon, if not unheard of.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 12-07-2010, 07:17 AM   #3
IMkenNY
IMkenNY is on a distinguished road
Do you live in a high use road salt environment?
Add to IMkenNY's Reputation
Rate the quality of this post and help IMkenNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IMkenNY is offline   Reply With Quote
Old 12-07-2010, 10:29 PM   #4
nichitect
The car has been in New England since she bought it brand new, and mostly southern New England. Salt use, but I wouldn't say highly salted....
There is a surprising amount of rust throughout this car actually, especially for a plastic car! Pop the hood and there is rust galore...
Yeah, my first clue that it was an uncommon issue was when the parts had to be ordered from GM and there was a 2-3 day lead time for them....
Anyway, here are some pics of the fuel lines.
Old 12-08-2010, 06:41 AM   #5
Diesel_Clatter
Diesel_Clatter is on a distinguished road
2007 ION-2 Sedan
Thanks for the pics. I will have to try to spray that area with some Corrosion X or Fluid Film or Boeshield (anybody else have all three!?)
When I am working on the car I try to keep a spray can handy and squirt the rusty bits I see.
Great Minds Think alike...
So do we!
Add to Diesel_Clatter's Reputation
Rate the quality of this post and help Diesel_Clatter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Diesel_Clatter is offline   Reply With Quote
Old 12-08-2010, 07:47 AM   #6
IMkenNY
Out of the three products you mentioned above, what one do you like the most? Have you found these products available at a major autoparts retailer? (I dont own any of them but would like to procur at leat one of them)
Old 12-08-2010, 11:33 PM   #7
Diesel_Clatter
2007 ION-2 Sedan
I currently like Corrosion X the best for treating existing rust. It is some mystery chemistry that is supposed to leave a thin film. I got mine with an internet order through Amazon from Corvette Central as they had the best price at the time. It seems the most agressive/penetrating of the three for existing rust.
I use the Fluid Film more for lubrication of things like my manual transmission shift linkages and the steering shaft joint. It is lanolin based and does not contain much solvents. It stays liquid over time and creeps to keep a surface coated. It is probably also good for preventing/treating rust. I bought three cans of Fluid Film on ebay.
Boeshield is good as well. I got mine from Mcmaster Carr. It is primarily paraffin wax dissolved in some solvent and leaves a waxy film. I had problems with the spray cans leaving large quantities of product stranded in the can. I have a jar full of Boeshield I rescued from a dead spray can that I can brush on things.
I think they are all three good products and wish I really knew which one is best. I do think the Fluid Film is probably the most benign of the three with regards to contact with plastics/rubber because of the low solvent content.
So do we!
Old 12-17-2010, 04:31 PM   #8
phillthy
phillthy is on a distinguished road
2003 ION-2 Quad Coupe
the lines on my 03 rusted out in the same spot as the pictures.. ended up cutting that section out and replaced it with fuel injection hose and 2 clamps on each side. been like that for a year now and its holding up fine!
Add to phillthy's Reputation
Rate the quality of this post and help phillthy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
phillthy is offline   Reply With Quote
Old 01-03-2011, 01:11 PM   #9
Bill Carey
Bill Carey is on a distinguished road
2003 ION-2 Sedan
2005 ION-3 Quad Coupe
Have 03 Ion 2 and i just had the same thing happen with mine. Never heard of fuel line rusting and neither did my mechanic. Only have 105K and really did not expect this for a car made of plastic and sold in the Northeast with a "never rust" sales incentive.
Add to Bill Carey's Reputation
Rate the quality of this post and help Bill Carey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bill Carey is offline   Reply With Quote
Old 01-03-2011, 04:19 PM   #10
lgodave
lgodave will become famous soon enough
2003 ION-3 Sedan
Originally Posted by Bill Carey View Post
Never heard of fuel line rusting and neither did my mechanic. Only have 105K and really did not expect this for a car made of plastic.
Where did your Mechanic hale from? Desert SW? Unfortunately Saturn never did achieve making a Car out of Plastic. Only the polymer outer panels were plastic. All the metals was/is susceptible to rusting and oxidizing.
I've got several spots under the hood that are showing signs of rust. One are in particular does seem particularly exposed to moisture and yet it rusts... If that is the case, I'm sure there are plenty of places on the undercarriage of my 2003 ION-3 that aren't fairing well in the WI winters here.
Next time I'm getting it serviced I'll have them look at it's Fuel Line condition. I've had my two previous vehicle's Gas Tanks need replacement and some Fuel Line attention... so it isn't something new to me.
Add to lgodave's Reputation
Rate the quality of this post and help lgodave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lgodave is offline   Reply With Quote
Old 09-01-2011, 05:51 PM   #11
opit
opit is on a distinguished road
Surprise my 04 saturn sprung same leak. recall number gm 03068. nhtsa campaign id # 04v003000. have no idea of either but states in the year 03 to 04 2.2l engine had fuel filters premature rust out on the ion series. 80000 miles on mine it happened. call saturn and found out my vin was just 50,000 numbers out of recall range so oil them up boys and girls.
Add to opit's Reputation
Rate the quality of this post and help opit reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
opit is offline   Reply With Quote
Old 09-01-2011, 07:57 PM   #12
lgodave
2003 ION-3 Sedan
I'll have to check that out as I've developed a fuel line leak recently. I had the original filter changed under recall/warranty (around 2004).
Old 09-02-2011, 07:34 AM   #13
kaviation
kaviation has a spectacular aura aboutkaviation has a spectacular aura aboutkaviation has a spectacular aura about
kaviation's Avatar
Same issue here. I noticed it about a year ago, been spraying it down with KROIL since, just a matter of time before they go.
Another issue on mine is the brake line coming out of the ABS pump/module. The ones that are painted look o.k., but the ones out of the bottom look pretty bad, they do sit lower, so I would imagine that thats where most of the salt lays, so I guess it took its tool on that line as well. Anyone else ever check their brake lines?
TWM Short Shifter
Progress springs with Cobalt SS suspension
Vibrant cat-back exhaust system!
RK Sport Fiberglass Hood
LONG LIVE THE BEECH 1900D
I ENJOY WHAT I DO- I DO WHAT I ENJOY
Add to kaviation's Reputation
Rate the quality of this post and help kaviation reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kaviation is offline   Reply With Quote
Old 09-02-2011, 11:15 AM   #14
lgodave
2003 ION-3 Sedan
Has the KROIL been used as a preventive for additional rust and/or to possibly reduce leakage? Might have to try it either way, but would like more info. on what you or others have tried for short/long term care during a leak OR as a preventative after a fix.
RE: Recall
From what I read of the GM Recall # I guess the Fuel Line Rusting out isn't covered... the filter had already been replaced.
Old 09-02-2011, 11:41 AM   #15
kaviation
kaviation's Avatar
RE: Recall
Not sure of the exact chemestry here, but I do know ,it's temporary it may,. help slow down any additional formation, but the surface is already rusted, and nothing can stop it now. Unfortunately rust is like a cancer for metals, gotta grind it all the way out.
I did use the KROIL for my intermediate steering shaft which freed it up quite a bit. I had a stiff steering issue.
TWM Short Shifter
Old 09-02-2011, 01:27 PM   #16
lgodave
2003 ION-3 Sedan
Yeah. KROIL isn't a miracle substance... but I was thinking someone might have posted their personal "bubble gum" fixes/experiences. Like, maybe some "fuel resistant" Duct Tape and some Rubberized Underbody coating(?) for example. Might be messy during a repair (so keep the "cut" areas clean) and cause unexpected issues if left unfixed too long. But it might reduce the need for a rushed/expensive fix.
Old 09-06-2011, 01:28 AM   #17
lgodave
2003 ION-3 Sedan
Might be time to try out my "Bubble Gum" fix. Actually getting a noticable puddle now. (But not particularly wet/heavy... So that is good at least.)
Think/Hope I just need a few 3/8" Compression fittings/Unions, Several lengths of Steel Fuel Line, and some patience. (Do all the Saturn IONs from 2003-2007 use the same size/type of Fuel Line? Ideally I'd prefer replacing with something that isn't going to rust... But I suspect splicing in Nylon or Aluminum Fuel Line is a No Go. Nylon maybe because of high pressure and possible degrading later? Aluminum for, I'm not sure, Ethanol compatibility(?) and no fitting adapters? Will have to check at the parts store.)
Biggest issue I'm worried about is safely cutting/prepping the lines after pulling the fuse on Fuel Pump to release pressure. Would hate to cause a worse leak.
Old 09-09-2011, 03:51 AM   #18
lgodave
2003 ION-3 Sedan
Mechanic patched in some fresh steel fuel line where it had rusted out.
Will probably coat down the remaining rusty bits with some WD-40 (etc.) to help keep the rest of the line(s) in better health longer.
Old 09-09-2011, 10:32 AM   #19
kaviation
kaviation's Avatar
I've been thinking about coating them with a corrosion preventative, but it's probably too late. Something that needs done when new.
When I replace mine, I'll do it then.
TWM Short Shifter
Old 09-09-2011, 11:13 PM   #20
lgodave
2003 ION-3 Sedan
Haven't had a chance to see how much was repaired. But when I saw it earlier before I had it fixed... it was basically that back section (around the Driver's Side Wheel to the Fuel Filter) that didn't seem to be taking the Road Debris/Salt/Water Test very well.
Personally I would have just swapped out the two lines from the Filter to just forward of the Wheel. (Probably gets plenty of spray from the Rear Wheels and relative openness of those areas.) The rest I think will be just fine with a little TLC from the WD-40 every once and a while.
Rusted Brake Lines!!! Please Help!!! cola S-Series Tech 23 03-14-2016 03:34 PM
Rusted rear brake lines fredsfix S-Series Tech 0 04-11-2009 06:38 AM
Fuel Lines for '95 DOHC mjo S-Series Tech 7 07-05-2006 01:58 AM
Do I need to replace fuel lines W/ fuel Filter? donisaacs S-Series General 2 11-16-2003 07:23 PM
Rusted trans lines to Radiator. Hodado Miscellaneous Tech 2 08-14-2002 08:26 PM
