Old 12-04-2010, 12:57 PM   #1
VolvoDude
VolvoDude is on a distinguished road
Dizzy Voltage under the hood... No voltage in cabin? What to check?
I'm posting this for my friend, but I'll tell it like it was me driving.
Driving home in my 98 SL1 I noticed the radio would cut out when I hit the brakes and come back on when I let off. I got home and shut off the ignition and everything inside went off. Radio, lights, door chime, everything. Put the key back in and nothing. No lights, not even dash lights. Turn the key - nothing, no starter click.
Jiggled the battery cables. Checked the battery for voltage - 12.5 or so. Checked the fuses in the under-hood fusebox - voltage.
Checked the inside fuse box for voltage... nothing! Is there a connection that could have come loose between the two fuse boxes or a fusible link that could have died or ... Where do I start??
The battery's 2 years old and wasn't that cheap. I didn't try to jump start it because I should at least have some kind of lights or door chime if the battery had enough to keep the car running and the stereo on. I can't check anything else till monday, I took my other car out of town.
I own 2 Volvos (740Ti and 240) and have friends and family with SL1's. One's 94, one's 98
Add to VolvoDude's Reputation
Rate the quality of this post and help VolvoDude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VolvoDude is offline   Reply With Quote
Old 12-04-2010, 01:06 PM   #2
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
Default Re: Voltage under the hood... No voltage in cabin? What to check?
The large GREEN fuse. IP BAT feeds the always powered items on the I/P Panel and the remainder is from the ignition switch.
These are the ignition switched power.
http://www.saturnfans.com/photos/sho...pg-1/cat/12963
http://www.saturnfans.com/photos/sho...pg-2/cat/12963
http://www.saturnfans.com/photos/sho...pg-3/cat/12963
As a wild guess, the ignition switch has failed.
DRL voltage? XRL Vue Tech 10 10-11-2010 10:01 PM
How do you check for voltage issues? Joshua S-Series General 9 05-14-2008 09:37 AM
ects low voltage Carlyle S-Series Tech 8 04-16-2007 12:45 AM
Voltage going to headlamps danburridge Ion General 14 05-31-2006 07:11 PM
Do I disconnect all the low voltage wires from coil pack to do an compression check? rwagen Miscellaneous Tech 3 11-03-2002 01:41 PM
