Old 11-10-2010, 05:53 PM   #1
tgferg67global
tgferg67global will become famous soon enoughtgferg67global will become famous soon enough
tgferg67global's Avatar
Default Photo of new power steering pump leaking from hole in casting. Bad pump?
Hi,
I replaced a power steering pump which seemed to be leaking form the front seal. Now, after putting in a new pump from Oreilly's I noticed there is a leak and found it to be coming from a small hole in the casting.
Did I get a bad pump or is there possibly something wrong with my rack causing the leak?
It leaves a spot like this overnight
Add to tgferg67global's Reputation
Rate the quality of this post and help tgferg67global reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tgferg67global is offline   Reply With Quote
Old 11-10-2010, 06:11 PM   #2
Default Re: Photo of new power steering pump leaking from hole in casting. Bad pump?
That is the pump cover retaining ring access hole. It is used to aid in the removal of the locking ring that holds the end cover in the pump. The rear cover is leaking. Not good. Take it back.
Power Steering Pump ppeSC2 S-Series Tech 3 04-29-2009 03:31 PM
Need quick help - replacing power steering pump and water pump on V6Ö. Emanresu2 L-Series General 6 05-18-2006 05:38 PM
power steering leaking, and faulty fuel pump? fetchitfido S-Series Tech 15 05-08-2006 09:57 PM
Has anyone had a prob with a leaking power steering pump on the v6 Saturn 6 L-Series General 2 03-29-2005 10:56 PM
Steering pump leaking VTHokie00SL2 Miscellaneous Tech 4 09-07-2000 09:39 AM
