Old 11-05-2010, 02:53 AM   #1
PlasticCarsRock
PlasticCarsRock's Avatar
Default Dual intake cam mod--worth it?
I have a '95 SL2 automatic with short ram intake, 2.25" stainless mandrel bent exhaust, '92 OE header, WBO2, SAFCII. I'm contemplating the dual intake cam mod (where you replace the exhaust cam with an intake cam, rotated 180 degrees). I couldn't find much by searching--what are the pros and cons? I don't want to sacrifice low-end power so I think all aftermarket cams are out of the picture--how much do the dual intake cams hurt the low end, if at all? How much of a gain can I expect, and where in the power band? Any idle quality issues? Other issues?
Thanks for your input!
Old 11-05-2010, 04:54 AM   #2
Default Re: Dual intake cam mod--worth it?
Idle feels/sounds the same. Low end power feels lower. Kicks in like Red Bull at ~4.3k rpm's though. MPG seems to be higher too but I'm not sure the mod did it. You'll get more out of it then me with that SAFC II setup.
Old 11-05-2010, 06:33 AM   #3
PlasticCarsRock
Thanks!
Is there a write-up somewhere on how to replace the cam? A search turned up nothing other than advice that it should be done with the engine out of the car... why? Does the sprocket need to be rotated, or can the new cam be installed rotated, with the sprocket still in place, in the original position? The FSM is pretty clear on everything (except rotating the sprocket, if that's necessary)...
Old 11-05-2010, 08:46 AM   #4
Mgg4591
Mgg4591 is on a distinguished road
Mgg4591's Avatar
Default
Originally Posted by PlasticCarsRock View Post
Thanks!
I believe there is a writeup with photos on sixthsphere.
Add to Mgg4591's Reputation
Rate the quality of this post and help Mgg4591 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mgg4591 is offline   Reply With Quote
Old 11-05-2010, 09:14 AM   #5
+1 on sixthsphere.
I think they added to it recently that if your careful it won't unbalance the cam enough to hurt anything by grinding the offending ring off the cam instead of grinding a tab off the head. That's why they say to do it with the head off...don't want metal shavings getting into the works.
Old 11-05-2010, 11:10 AM   #6
PlasticCarsRock
+1 on sixthsphere.
Ahh... so there's something that must be ground. I didn't realize that. I'll search more, over there. (I already searched a bit on 6s before posting, but the search feature isn't all that great. I'm sure I can find it eventually.)
Old 11-05-2010, 01:25 PM   #7
Leafy
Leafy is on a distinguished road
Leafy's Avatar
yeah ring needs to be ground off the cam, balance shouldnt be too much of an issue since the cam's only spin at half the speed as the crank.
1994 SL2 HCE auto 113 hp 113 lbft (wheel) backup car
2002 Chevy Cavalier SS
For Sale: FlyWheel, Shifter assembly, Clutch Hydros, 1st gen 5 spd PCM. PM me for prices.
WPI class of '12 ME
Add to Leafy's Reputation
Rate the quality of this post and help Leafy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leafy is offline   Reply With Quote
Old 11-05-2010, 01:57 PM   #8
saturnsl293
saturnsl293 is on a distinguished road
saturnsl293's Avatar
1993 SL2
from my understanding the later heads (00-02 maybe) don't need grinding etc like the earlier one as the tab isn't there.
car bought 12/15/07
car MIA as of 7/29/09, recovered 8/5/09
Add to saturnsl293's Reputation
Rate the quality of this post and help saturnsl293 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnsl293 is offline   Reply With Quote
Old 11-05-2010, 01:59 PM   #9
Leafy
Leafy's Avatar
correct, but the op has a 1g in his avatar so I figured he didnt need that tidbit.
WPI class of '12 ME
Old 11-05-2010, 02:00 PM   #10
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
Or just pull the head, grind the nub, machine .02" off of the head for higher compression...
I can't wait to get my car up here, Deebs rebuild, plus decking the head and intake cam.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 11-05-2010, 02:04 PM   #11
saturnsl293
1993 SL2
true its a 1g but what if a 3g engine was dropped in at some point for whatever reason? also figure if someone with a 3g or has a 3g engine stumbles across this who's considering the same mod they can find out they don't have to grind anything
car bought 12/15/07
Old 11-05-2010, 06:13 PM   #12
You put the cam in a nice big lathe to cut the ring off. If you have an early head with the lump you can cut it off with a air die grinder if you think about what you are doing and cover and properly prep the work space.
Pictures and instructions. http://forums.plastikhosting.net/viewtopic.php?t=1373
Old 11-06-2010, 02:04 AM   #13
Leafy
Leafy's Avatar
if someone put at 3g engine in a non 3g car they need to be slapped for their dumbassism.
WPI class of '12 ME
Old 11-06-2010, 02:31 AM   #14
PlasticCarsRock
What's wrong with the 3g engines? It is the original gen1 ('95) engine, though, with 103k miles (decent compression, about one quart/3k miles oil--no signs of any trouble).
How much work is it to remove/reinstall the head, if I wanted to take off .02"? What kind of gains could I expect? If I'm not mistaken, there's also a valve swap (flat-faced '91 to '93 OE) that would increase my compression slightly--would it be worth doing that in addition (while taking slightly less off the head) or instead of cutting the head?
Taking that ring off the cam wouldn't be any trouble--I have easy access to a good lathe. I also have access to a full machine shop (NC, CNC, etc) so cutting the head wouldn't be too hard, if it's worthwhile; what about porting/port-matching, while I'm at it?
Old 11-06-2010, 06:58 AM   #15
From the little I've read:
Can't put the good/cheap '91-/92 header on it.
Intake manifold doesn't flow as well as the older ones, can't put the good ones on it.
Don't have the stuff & paitence to do the port matching myself but every little bit helps and you might as well do everything you can while its apart.
Have to take the timing chain off to get the head off. Have to also take exhaust and intake manifolds off, well the exhaust at least. Don't forget to get new head bolts if you do take it off, they're torque to yeld (1 use only).
Old 05-12-2011, 10:47 AM   #16
Jess Lookin
Jess Lookin is on a distinguished road
Jess Lookin's Avatar
2002 VUE 3.0L
Can the dual intake mod be done on 3rd gen heads ? Can't seem to find the answer.
01 SC2 - Miss Parker - a work in progress
00 SC2 - hibernating
Add to Jess Lookin's Reputation
Rate the quality of this post and help Jess Lookin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jess Lookin is offline   Reply With Quote
Old 05-12-2011, 11:35 AM   #17
A bit less work on 3rd gen DOHC heads. No nub to grind off.
Old 05-12-2011, 11:48 AM   #18
Jess Lookin
2002 VUE 3.0L
Ok, so which year cam do I need ?
Old 05-12-2011, 06:27 PM   #19
PurdueGuy
PurdueGuy's Avatar
1999 SC1
'99-'02 (9 bolt exhaust head)
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 05-14-2011, 10:05 AM   #20
Jess Lookin
2002 VUE 3.0L
I guess I should have figured that one out myself, fairly obvious. Thanks Purdue !
dual intake cam ----- can't tell :( fetchitfido S-Series Mods 4 06-02-2010 09:10 AM
dual/tripple stage intake? PlasticCarsRock S-Series Tech 10 01-07-2009 01:55 PM
Fujita dual filter cold air intake bronzestarvue Sky Mods 24 07-02-2008 06:11 PM
Dual Air Intake Idea... jkbreazeale S-Series Mods 32 05-29-2006 10:09 PM
dual diameter intake or single? mars_volta S-Series Mods 22 05-14-2004 10:46 PM
