Old 10-25-2010, 06:58 PM   #1
Atlas
Atlas is on a distinguished road
Default Replace catalytic converter
I am looking for some advice on how to replace the catalytic converter on my 2003 Ion. I already purchased a direct-fit OEM Eastern catalytic converter online. My questions pertain to the removal process of the old converter:
I don't have access to a lift, so would it be easier to complete the job with the car on four stands?
What is the easiest way to remove the bolts/nuts (fasteners)?
Does anybody know the size of the bolts/nuts (fasteners) so I can purchase them before doing the repair?
Once the bolts are removed, is there some type of adhesion material that holds the flanges together or will it separate easily?
Add to Atlas's Reputation
Rate the quality of this post and help Atlas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Atlas is offline   Reply With Quote
Old 10-26-2010, 02:04 AM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Replace catalytic converter
Put the front on jack stands. The easiest way to remove the bolts is to turn them (most of the time they turn better left to grrrrrr them off). No, I do not know the size. They cone apart pretty easy, but you will want new gaskets.
Add to 2006 ion2's Reputation
Old 10-26-2010, 06:34 AM   #3
brapple
brapple is on a distinguished road
chances are the bolts are going to be rusted up. make sure you use some penatrating oil and let the bolts soak. if you are pacient you should be able to get them out.
if you happen to break one of the bolts the easiest thing to do would be to drill the bolt out and just use a bolt and nut to bolt things back together. at that point the bolt can be anything you want, suggest stainless, that fits in the drilled out hole. note it might take burning the old bolt out.
should need anything but new gaskets to install the cat.
2004 Ion 3 Sedan
2k Ford SVT Contour
99 Ford Contour - 3L+turbo
99 Ford Contour Se Sport
Add to brapple's Reputation
Rate the quality of this post and help brapple reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brapple is offline   Reply With Quote
Old 11-03-2010, 10:09 AM   #4
chilipepper1327
chilipepper1327 will become famous soon enough
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
Always replace bolts/nuts with this work.
Add to chilipepper1327's Reputation
Rate the quality of this post and help chilipepper1327 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chilipepper1327 is offline   Reply With Quote
Old 11-03-2010, 10:32 AM   #5
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
dont forget if under 8 yr 80k its warranty
Add to onefunkar's Reputation
how to replace oxygen sensor before catalytic converter? seasonedcat Vue Tech 3 07-30-2010 07:28 PM
Catalytic converter already?? nhlkent11 Aura General 2 11-05-2009 10:44 AM
catalytic converter packer_rich Vue Red Line 1 12-21-2008 07:09 PM
catalytic converter underthehood S-Series General 13 11-01-2008 10:44 AM
Time to replace the catalytic converter David 93 SL2m S-Series Tech 8 01-28-2002 10:51 PM
