Old 10-25-2010, 06:33 PM   #1
Major_Tom
Major_Tom is on a distinguished road
Default Gas Gauge doesn't work - What to check first?
Gas gauge on my 98 Saturn SL2 stays right around three-quarters of a tank no matter what.
What should I check first? How do I get to the fuel pump on this car? Theres no chance theres is an access plate under the back seats, is there?
Add to Major_Tom's Reputation
Rate the quality of this post and help Major_Tom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Major_Tom is offline   Reply With Quote
Old 10-25-2010, 08:34 PM   #2
off-track
off-track has a spectacular aura aboutoff-track has a spectacular aura about
off-track's Avatar
Default Re: Gas Gauge doesn't work - What to check first?
Even when the car is turned off?
No chance (unfortunately). Only way to get to it is to drop the tank.
http://www.saturnfans.com/forums/sho...d.php?t=142900
IIRC it would even be pretty tough to get to the FP connector to test that way without (at least partially) dropping the tank?
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 10-26-2010, 12:26 AM   #3
Major_Tom
Yes, the gauge stays in the same spot even with the car off. what does that mean?
Its ok, my mom has a lift in her garage, so dropping the tank isn't a huge deal, but I was hoping it would be as easy as it is on my Honda Accord.
Old 10-26-2010, 12:29 AM   #4
lost_wreckage
lost_wreckage is on a distinguished road
lost_wreckage's Avatar
1996 SL1
Your mom has a lift in her garage? That's pretty cool.
Add to lost_wreckage's Reputation
Rate the quality of this post and help lost_wreckage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lost_wreckage is offline   Reply With Quote
Old 10-26-2010, 12:58 AM   #5
Major_Tom
Its actually her boyfriends, but yeah, its a 2 post lift. He got it a few years ago out of a catalog, I think he paid like $1800 for it. Its paid for itself several times over by now, I'm sure.
For some things its great, like pulling a gas tank or for when I did the timing belt on my honda. But others, like oil changes, its just faster to do it on the ground. Getting the arms lined up can take 10 - 15 minutes of horsing around and moving the car back and forth just the right amount.
Old 10-26-2010, 07:44 PM   #6
off-track
off-track's Avatar
You're looking at the wrong end of the car! It should flat line with the power off so the gauge itself is stuck. You could pull it and see if you can free the needle but have no experience there.. otherwise, I'd scout the local JY for a replacement IPC?
Ok, so we're all jealous. Don't post the location in your profile or you'll have a line-up at Mom's in no time!
Added OEM CC
Old 10-26-2010, 11:00 PM   #7
Major_Tom
Thats good news! A new gauge cluster is only $30 shipped off ebay. Much better than having to drop the tank and horse around with the fuel pump and tank level unit.
Old 10-26-2010, 11:46 PM   #8
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Huh? On a '98? I thought the gauge dropped on power-off only on the gen-3 cars.
Add to madpogue's Reputation
Old 10-27-2010, 12:35 AM   #9
Jake-Sl2
Jake-Sl2 is on a distinguished road
Guage drops when i kill the key on my 94. Hmm
1994 Saturn SL2
Add to Jake-Sl2's Reputation
Rate the quality of this post and help Jake-Sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jake-Sl2 is offline   Reply With Quote
Gas gauge doesn't work. Ideas? aaron7 S-Series General 5 07-22-2009 12:25 PM
93 Saturn Gas Gauge Dont Work XxRizzLexX L-Series Tech 1 01-29-2007 07:52 PM
Gas Gauge doesnt work? XxRizzLexX S-Series Tech 4 01-29-2007 07:45 PM
removed odometer from gauge cluster, now gas gauge & oil pressure gauge don't work DJboozeAlot S-Series Tech 18 04-06-2005 02:59 AM
Gauge work Sattyman Miscellaneous Tech 3 06-13-2002 08:05 PM
