Old 10-19-2010, 01:51 AM   #1
PlasticCarsRock
PlasticCarsRock's Avatar
Default How does the brake fluid level sensor work?
I'm just curious--I recently discovered that the sensor for the low brake fluid warning doesn't actually go into the reservoir at all (there is no direct contact with the fluid to operate a float or anything, it's just in a channel sealed off from the fluid). So... how does it work?
Old 10-19-2010, 08:48 AM   #2
jcscheer
jcscheer is on a distinguished road
1997 SW2
Default Re: How does the brake fluid level sensor work?
I would suspect there are contacts integral with the brake reservoir and some manner of connection to the sensor. Perhaps a FSM owner could enlighten us all.
Add to jcscheer's Reputation
Rate the quality of this post and help jcscheer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcscheer is offline   Reply With Quote
Old 10-19-2010, 09:06 AM   #3
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
Pretty sure this is exactly how the Saturn one works,
Google is your friend!
http://www.meder.com/fileadmin/meder...pplication.pdf
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
Add to mattelderca's Reputation
Rate the quality of this post and help mattelderca reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattelderca is offline   Reply With Quote
Old 10-19-2010, 09:39 AM   #4
jcscheer
1997 SW2
EXACTLY what I was thinking... not
Very cool though
Old 10-19-2010, 09:45 AM   #5
mattelderca
1998 SC1
1996 SL
Very cool though
That is exactly how it works. It is the same as the float in the coolant tank as well. Except that coolant loss can happen if the seal fails where the sensor enters the coolant tank. You would not want that chance on the braking system, so they do away with the seal and fit the sensor in a cavity instead.
Old 10-19-2010, 01:13 PM   #6
PlasticCarsRock
Yeah, that's it (exactly what it looks like, at least). So basically the sensor is just a gaussmeter that reads the magnetic field of a magnet that floats on top of the fluid level... clever.
Old 10-19-2010, 01:55 PM   #7
mattelderca
1998 SC1
1996 SL
No fancy Gauss doo-hicky, just a reed switch.
Old 10-19-2010, 02:06 PM   #8
PlasticCarsRock
Well, a reed switch is just a very simple (digital) gaussmeter (magnetometer). Typically, they're voltmeters (analog) that measure the Hall effect (the voltage difference between the edges of a wide conductor, created by the magnetic field through it.
Old 10-19-2010, 02:33 PM   #9
jcscheer
1997 SW2
I was just being silly as that is not what i envisioned. I thinks it a cool design and relatively simple one at that. Dont want you to think i was being critical or derisive in any way
brake light on, fluid level good dorisSL S-Series Tech 0 08-10-2010 04:25 PM
Brake fluid level - Wheres the line the cap speaks of? foo S-Series Tech 2 05-03-2008 03:06 PM
Low level in brake fluid reservoir neilpilot 2008 Vue 2 03-17-2008 08:18 AM
Brake fluid level? turbobuick33 S-Series Tech 3 05-14-2007 12:41 PM
Brake light comes on at WOT--fluid level o.k. newt Miscellaneous Tech 2 12-07-2004 08:41 AM
