Old 10-18-2010, 05:33 PM   #1
Matthewstamp22
Matthewstamp22 is on a distinguished road
Attention 1996 Saturn SC2 Coupe
i have a 1996 Saturn SC2 Coupe and i need to find where the horn is please help where is the horn located on this model i cant find it!! i have looked and looked please help!!
Add to Matthewstamp22's Reputation
Rate the quality of this post and help Matthewstamp22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Matthewstamp22 is offline   Reply With Quote
Old 10-18-2010, 05:37 PM   #2
2NDSOUT
2NDSOUT's Avatar
1999 SL
Default Re: 1996 Saturn SC2 Coupe
IIRC; I *think* the horn is under the hood latch in the front. Either there or it's up and behind the driver's side headlight.
Kind of drawing a blank, but check one of these two locations.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 10-18-2010, 05:43 PM   #3
Matthewstamp22
Attention Re: 1996 Saturn SC2 Coupe
i have checked them both it has the flip headlights so im not sure it that changes thing please anyhelp
Old 10-18-2010, 06:32 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
You have to remove the plastic fender liner to get access to it. Its under the drivers side headlight and behind the metal bumper support bolted to the framerail.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 10-20-2010, 09:24 PM   #5
Matthewstamp22
well i am stupied and couldnt find it so i brought it to the garage and they came back out and said your not stupied there is no horn in the car it fell out or some one took it out
Old 10-21-2010, 02:57 AM   #6
Mine was bolted to an added on strip of metal bolted to the strut tower with power being taken from the stock harness run through an added on switch. I've been told these have a 3 wire horn, can't find the switched wire to put a stock horn back in. I did move the horn forward to just below the air intake horn, makes the hack less noticeable at least.
Old 10-21-2010, 03:52 AM   #7
boboman
boboman is on a distinguished road
2000 SL2
Happy Re: 1996 Saturn SC2 Coupe
I sure hope that a mechanic would be able to spot even an aftermarket/hacked horn, either way its about 15-20$ part and a decently simple install job if you have the time space and tools. (I am assuming you started this post because the horn doesn't work(aka doesn't exist))
Good Luck! Let us know how it goes
Add to boboman's Reputation
Rate the quality of this post and help boboman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
boboman is offline   Reply With Quote
Old 10-21-2010, 11:02 AM   #8
saturnsctwo
on my 2001 sc2 the horn is right under the driver's side headlight. easy to get at just remove your headlight. yours is probably the same..
Old 10-21-2010, 11:12 AM   #9
Low Saturn
Low Saturn's Avatar
2000 SC2
Its not. Removing the pop up headlight assembly on a first gen coupe isn't as easy as a second or thrid gen.
Besides, removing the headlamp requires some of the same steps needed to gain access to the horn.
Mike
-2000 Saturn SC2
Old 10-21-2010, 11:14 AM   #10
saturnsctwo
oh i didn't know his car had those headlights. mine is also accessible underneath... i would just drive the car on ramps to get at it....
Old 10-21-2010, 11:23 AM   #11
Low Saturn
Low Saturn's Avatar
2000 SC2
Did the person at the garage fully remove the fender liner and stick their head up inside the wheel well? If not, its not suprising that they didnt find the horn.
If you remove the fender liner, remove the parking light then look through the opening where the parking light was with a flashlight, thats where it will be.
Mike
-2000 Saturn SC2
1996 Saturn SC1 eburgpilot S-Series General 7 04-24-2009 11:45 PM
1996 saturn sl1 help jrb47 S-Series Tech 6 05-18-2008 02:03 PM
1996 Saturn SL2 nobledippy S-Series General 0 06-26-2006 09:07 AM
Selling: White 1996 SC2 Coupe Norcalguy Classifieds 8 01-05-2006 12:18 AM
1996 Saturn SC2 coupe for sale David 93 SL2m Classifieds 23 11-24-2003 10:06 PM
