Old 10-15-2010, 09:13 PM   #1
Dan400Man
Dan400Man is on a distinguished road
Default Oil in spark plug well
So, I went to replace the spark plugs and wires on my '97 SL2, figuring to be done in 15 minutes. I pulled the boot off of the plug to my left, and came up with oil. Took about 5 paper towels to "sponge" it out.
The other three wells were dry.
What am I dealing with here? Is it just the cam cover gasket?
1997 Saturn SL2
Add to Dan400Man's Reputation
Rate the quality of this post and help Dan400Man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dan400Man is offline   Reply With Quote
Old 10-15-2010, 09:18 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: Oil in spark plug well
Yup, valve cover gasket. Fairly common problem, not hard to fix. Get the pre-formed gasket. Do a search on here & read up on putting a dab of RTV on the joint between the timing chain cover and the head.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 10-15-2010, 09:34 PM   #3
hholbein
1997 SW2
Seems like that #1 cylinder, closest to the timing chain, is the first one to strike oil in every case. It won't be too too long before the Valve Cover Gasket starts leaking elsewhere -- another 2-5 K miles....
Add to hholbein's Reputation
Old 10-15-2010, 10:46 PM   #4
Dan400Man
"Pre-formed"? Is that what I ask for? Will the parts stores carry this or only the dealer?
Once I have the cover off, is it SOP to clean the entire cover, or just the gasket contact surface? (I didn't see a Richpin video for that.)
Are razor blades the preferred tool to get the old gasket off?
1997 Saturn SL2
Old 10-16-2010, 11:37 AM   #5
The only gasket for the gen-2 DOHC is "pre-formed", so you don't have to ask for anything special. You shouldn't need more than an opposable thumb to remove the old one. There might be a bit of RTV to remove at the two points where the timing cover meets the cylinder head.
Add to madpogue's Reputation
Old 10-16-2010, 01:00 PM   #6
Dan400Man
Does "timing cover" = valve cover???
If not, the reference to "two points"... I presume this would be IN ADDITION TO the block it sits on?
Sooooooo... what am I going to see when I remove the valve cover? Anyone know of a picture online?
TIA!
1997 Saturn SL2
Old 10-16-2010, 01:48 PM   #7
The timing cover is the vertical flat piece in the front of the engine.
valve cover = cam cover
diagram of the cam cover, gasket (note 4 circular grommets for the spark plug well) attached
diagram showing top of timing cover attached, red circles show where it would meet the head and where you put the dab of RTV
The "how to" http://www.differentracing.com/tech_.../camcover.html Note the torque is in INCH pounds
I used acetone to clean the surfaces, cuts right through the grime and dries quickly without residue.
You can get the felpro gasket at advance auto. the numbers on the side of my box are VS 50454,
UPC is 84113 56432
Old 10-29-2010, 11:57 PM   #8
Dan400Man
Thanks to everyone for all the advice! Additional question below:
UPC is 84113 56432
Picked up the gasket tonight. When I asked for RTV, the guy at Advance Auto suggested I didn't need it for this gasket. I bought a tube anyway. Will I use the RTV along then entire surface of gasket or just at certain points you provided?
Thanks again!
1997 Saturn SL2
Old 10-30-2010, 05:31 AM   #9
If you put it all along the mating surface on the head you really don't need the preformed gasket. It just goes on the joint between the head and timing cover because it's a joint that may not be filled in with the preformed gasket. You'll also have a heck of a time getting the valve cover off in the future with RTV everywhere.
Be glad you don't have a SOHC. Despite what everyone on here says and what the part description says on the order page at each parts store all I ever got was a tube of RTV and a couple grommets for my '97 SC1.
Old 10-30-2010, 11:10 AM   #10
You ALWAYS use a preformed gasket with the composite cover. Therefore you only use the RTV at the two joint points. This accounts for the possibility of the level of the top of the head and the top edge of the timing cover being slightly different.
Old 10-30-2010, 09:48 PM   #11
^ ^ ^ +1, what madpogue said. Just a dab will do ya
Skip the RTV if you believe:
1) the guy at Autozone knows more than the Saturn engineers, and
2) the guy at Autozone is right and the Saturn Field Service Manual is incorrect, and
3) the guy at Autozone is right and all the fine folks here at Saturnfans, which includes former Saturn technicians, professional mechanics, and experienced DIYers, are wrong
Old 10-31-2010, 02:42 AM   #12
Dan400Man
Well, that was a lot easier than I imagined it might be. The hardest part was cleaning the baked-on oil residue.
The old gasket came off easy and the new one went on easy. There were dabs of RTV at the two points described earlier in this thread. (BTW, thanks for that graphic, alordofchaos!) I removed those, of course, and put new dabs on before putting the valve cover with the new gasket on.
This mid-novice declares this to definitely be a DIY project.
BTW, remember how this started out as a quick spark plug and wire change? I did that as well after I got the valve cover back on. One surprise with the Bosch Platinum Plus plugs was that each plug came with an extra tip, seemingly identical to the one already on the plug. I called 3 different parts stores; no one had a clue. I've done numerous spark plug changes before, but this is the first time I'd seen this. Anybody know?
This was my first experience with a torque wrench. I wondered why alordofchaos emphasized INCH pounds. The torque wrench I have has SAE (specifically INCHes) and metric units of measure. When I installed the spark plugs, the Bosch box spec'd 21 Ft Lbs torque. But the Ft Lbs didn't click in my brain, and I first tightened to 21 INCH Lbs, which wasn't much after I had hand-tightened the plugs. I immediately knew that wasn't tight enough, and I had to look at the Bosch box again before the Ft Lbs clicked. Did the math (21x12) and tightened to 252 INCH Lbs. I mention all this for the benefit of any other novices who might miss a Ft Lbs spec while using a wrench with inches and metric measurements.
1997 Saturn SL2
Old 10-31-2010, 07:23 AM   #13
Sorry for the confusion - the 89 inch lb spec is for the cam cover, not spark plugs. Several first-timers have stripped the threads by missing the torque, or by using the spec in the Haynes manual for this (which has a typo for the DOHC engine, iirc, something like 22 ft/lb)
You may want to do a search on platinum (or any fine-wire) spark plugs on this site... most people who have used them end up with misfiring down the road.
Switching back to copper (NGK BKR5ESA-11 is the recommended plug for the DOHC engine, having a wider heat range than the autolite and champions)
Old 11-01-2010, 09:22 AM   #14
Dan400Man
Actually, *you* didn't confuse me. I just didn't understand the emphasis on INCH pounds. I thought you emphasized this so I wouldn't use the metric measurements. "FOOT pounds" did not click until I realized that 21 INCH pounds was way too light.
Would it be too much to expect the Champion Plats to last until spring? Or do they go pretty quickly? I really want to avoid an emergency plug change when it's 20 degrees outside.
1997 Saturn SL2
Old 11-01-2010, 12:23 PM   #15
I have no experience with using platinum plugs in the Saturn.
There does not seem to be a pattern that I could tell... some people experience problerms fairly quickly, others go for a while without... though I don't recall off hand any longterm (e.g., two years) people saying they had no problems.
Here's a more extreme, recent case
http://www.saturnfans.com/forums/sho...d.php?t=160263 Note the poster does not say there were any problems withe the way the car ran, which I thought was interesting.
Old 11-01-2010, 01:52 PM   #16
Dan400Man
Don't know where I came up with Champion on that last post. As mentioned previously, these are Bosch Platinum Plus plugs.
But point well taken. Thanks for the linky to the other thread. I noted this from OldNuc:
Originally Posted by OldNuc View Post
Hmmm, wonder why the center electrodes all went away? Do not use platinum plugs. Do not use Bosch plugs either.
Figures I got Bosch Platinums!
1997 Saturn SL2
Old 07-06-2011, 06:53 PM   #17
paulclawson3
paulclawson3 is on a distinguished road
2001 SW2
Hey guys should I replace the cam cover gasket AND the cam cover? Not sure I have the same exact problem as this guy.
Add to paulclawson3's Reputation
Rate the quality of this post and help paulclawson3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paulclawson3 is offline   Reply With Quote
Old 07-06-2011, 08:55 PM   #18
Dan400Man
I replaced only the gasket. I can't imagine that you'd have to replace the cam cover unless it was somehow bent such that the gasket couldn't seal.
- Dan
1997 Saturn SL2
Old 07-06-2011, 09:22 PM   #19
Year and model?
Edit - '98 SC2, as per your other thread? When you remove the cover, get all of the old gasket out, incuding the rings around the spark plug holes, make sure it's clean of any old RTV, and find a super-duper-flat surface on which to lay it. Move it around, lay it down in different positions. See if the area aroudn that #1 spark plug hole doesn't quite sit flat with the rest of the cover. If it doesn't, then the cover may be warped. Preferred fix is to replace it with a '93-'95 aluminum cover, and a gasket to match.
Old 07-06-2011, 09:24 PM   #20
ehunter
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
Paul,
Insert the gasket in the grove then place the cover on a perfectly plane table and look for areas where the cover might be bowed. The more pronounced bowing you have, the higher the chance you will experience leaking.
If you have bowing, and leaking, consider replacing the cover with one that perfectly plane. The bowing may also affect the oil you do or don't get in any of your cylinders.
Add to ehunter's Reputation
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 07:29 AM
Dealer pricing on spark plug wires and spark plugs. KeithR S-Series General 25 05-19-2011 11:52 PM
1998 sl2- oil where the spark plug boot meets the spark plug in 1st cylender scrapmedallord S-Series Tech 7 08-14-2009 11:31 PM
Oil on a spark plug Don Brewer S-Series Tech 2 07-03-2008 10:18 PM
Oil ABOVE spark plug Bent_SL2 S-Series Tech 9 08-06-2004 06:45 PM
