Old 10-05-2010, 11:20 PM   #1
hotrod205
hotrod205 is on a distinguished road
hotrod205's Avatar
Wrench 2002 SL2 Getting SES P0410
My 2002 SL2 has had a P0410 code for a while, which is a problem with the AIR pump. I followed Richpin's video for troubleshooting the system and quickly figured out that my pump is working just fine, but I replaced the two little vacuum lines anyway just because they were rock hard and likely to leak soon. So the culprit was a blocked tube and/or passages in the exhaust manifold.
I'm posting a few photos here of my cleaning effort for the future benefit of others. This only pertains to the 2000-2002 DOHC engines although I think some 99's also had the air pump. Not sure if the SOHC had them or not. My car has 209K miles on it and has been burning a lot of oil for a long time.
First photo: air pump end of the tube, doesn't look too bad...
Second photo: exhaust manifold end of the tube, uh oh...
Third photo: opening in exhaust manifold, yep, that's not good...
Fourth photo: what the pipe should look like.
I didn't get an after photo of the exhaust manifold opening, but I wasn't able to completely clean it either since I didn't remove it. That will be another weekend. Hopefully these will be of some use or amusement to someone with the same problem.
Add to hotrod205's Reputation
Rate the quality of this post and help hotrod205 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hotrod205 is offline   Reply With Quote
P0410 Secondary Air Injection System Malfunction on 2002 SL-2 HotCookCpl S-Series Tech 20 02-23-2013 11:35 PM
Dtc P0410 Claude S-Series Tech 12 11-02-2009 07:39 PM
P0410 Huskerville S-Series Tech 5 08-23-2009 09:47 AM
P0410 beensmoked L-Series Tech 0 04-19-2008 06:32 PM
Dct P0410 Claude S-Series Tech 6 11-29-2005 09:24 AM
