Old 10-03-2010, 01:46 PM   #1
magteix
magteix is on a distinguished road
Default owners manual Saturn SL2 1998 / fluid trans
Hello to all,
anyone know where I can download the owners manual Saturn SL2 1998? another question. Which fluid should I put in the transmission? Thank you all!
Add to magteix's Reputation
Rate the quality of this post and help magteix reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magteix is offline   Reply With Quote
Old 10-03-2010, 01:52 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: owners manual Saturn SL2 1998 / fluid trans
1. junkyard or e-bay are good choices
2. 2.5 quarts (manual transaxle) to ~5 quarts (automatic transaxle) of any DEXRON-III synthetic automatic transmission fluid (mobil seems to be the most recommended one though).
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 10-03-2010, 01:54 PM   #3
quantumech
quantumech is on a distinguished road
check out Ebay for the manual, there are a couple other places, but I do not recall where they are.
Trans. is best with mobil-1 ATF at the low end, or if you can find it, royal purple or amsoil ATF. If you really want the best, find Amsoil torque-drive or Castrol trans-synd. Those last two are a little more difficult, as they come in gallon jugs and are for big rigs, but has the exact specifications that the original DEX-III fluid had. Do not believe other who say they are backward compatible, they are too thin.
Sasha: 2000 SL1, Manual, 130,500 miles 5-18-2014.
I learn from my experiences. If I screw up, I'm sorry.
Add to quantumech's Reputation
Rate the quality of this post and help quantumech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quantumech is offline   Reply With Quote
Old 10-04-2010, 07:34 AM   #4
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
What is too thin?
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is online now   Reply With Quote
Old 10-04-2010, 10:51 AM   #5
adventureoflink
Originally Posted by underthehood View Post
What is too thin?
Dexron-VI is too thin for our cars.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 10-04-2010, 12:07 PM   #6
quantumech
What is too thin?
The transmission fluid has too low of a viscosity to adequately lubricate the transmission gears. It's like when you've run the oil too long and breaks down.
Old 12-05-2010, 10:54 AM   #7
underthehood
2004 VUE 2.2L
I recently changed the manual trans fluid in the car my daughter bought to (IIRC Valvoline Max Life Dex III). Since than the shifting has become progressively "notchier" the only way I can describe it. It just does not "snick" gear to gear. So I have been lurking and researching fluid info.
I have seen recommendations for Castrol Trans-Synd and Amsoil Torque Drive. So digging even more deeply landed me to some Allison forums and this info. One is a GM document regarding Dex VI and backward compatibility the other is information for those of you who live in far northern IL (central and NW area) it's a link to Allison dealers in case you'd like to buy trans synd. Oddly if you go to a GM dealer they will sell you Dex VI for an Allison trans! http://www.allisontransmission.com/l...oint/index.jsp so this is the Allison link.
BTW not wanting to open can of worms just found some of this interesting. Personally I am going to find the Amsoil or the Trans Synd for the manual car as I am just not happy with how the shifts "feel" unless someone has a better recommendation that is easier to find and performs as well.
File Type: doc DEXRON_VI_Service_Fill_Release_30NO07.doc (104.0 KB, 17 views)
Old 12-05-2010, 11:34 AM   #8
+1^^^^
Dexron - 6 is not any good in the manual. Nor is it going to play well long term in the automatic. The S-Series is out of warranty coverage and GM could care less what goes into either one.
Allison spent lots of $$ developing Transynd and Amsoil spent a bunch developing their equivalent, Torque-Drive. They just might know what they are doing. Notice that neither company has gone broke and come running to Uncle Sugar for a handout.
For the manual you can use a Dexron/Mercon universal ATF, Torque-Drive/Transynd, or Manual Synchromesh Transmission Fluid 5W-30.
The automatic seems to do well on the Dexron/Mercon universal ATF.
Old 12-07-2010, 03:40 PM   #9
underthehood
2004 VUE 2.2L
Originally Posted by OldNuc View Post
+1^^^^
I see Royal Purple has a product meeting the Allison 295 spec but additionally one for manual units called Synchro Mesh that seems like it too would be well suited. Any input on that? The Castrol and Amsoil are a little high and hard to find but I did find the Automatic fluid at Advance Auto today. Looking at the RP web site I found the manual fluid.
Old 12-07-2010, 04:07 PM   #10
Either RP product works. The synchromesh is a GM spec product and is a 5w-30. It will prove a bit thick in real cold climates and is better suited for the desert southwest. Just about any full PAO synthetic universal ATF, Allison 295 spec, or GM synchromesh will work. The order is from thin to thick. The good news is you can fill the manual and forget it but if you use a synthetic in the automatic you should change the filter and run an oil sample to gauge fluid life.
Old 12-07-2010, 05:04 PM   #11
underthehood
2004 VUE 2.2L
Cool. I just can't get my head around the new manuals with basically auto fluid in them. Used to the old 80/90w stuff. Have not owned a (well I really don't own this one) manual since my old Ford truck top loader. I just want this one to shift well since it's the kid's car (though she has kinda stuck it on me since she can't figure out driving it). Like I indicated everything works well enough just the shift feels "notchy" is the best way to describe it like it sometimes wants to fight the synchros. I know it's a Saturn not a BMW just that it shifts more like my old Ford truck than the BMW I had years ago. Guess I'll try the RP Auto stuff since it's on the shelf and meets those Allison specs I've seen thrown around here.
Old 12-07-2010, 05:35 PM   #12
Go to your local gun shop and get some powdered mica. Dust it on the shifter ball, blow some down the cables and dist a bit on every pivot point.
Old 12-07-2010, 09:15 PM   #13
Signmaster
Signmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to behold
This link might give you some more options to try to find the TES 295 approved fluid. A lot of the commercial truck places, or maybe the John Deere place, carry it.
Allison Web Site TES 295 fluids
Old 12-07-2010, 09:22 PM   #14
Signmaster
Even Amsoil admits they reverse engineered the Torque Drive from the Castrol product. The research they did was lab analysis. Maybe some day they will quit claiming that Allison won't allow anything other than Transynd to be approved, and just admit they are too cheap to deal with the approval process.
Old 12-07-2010, 09:23 PM   #15
SLCraig
I vote Amsoil or PetroCanada DuraDrive MV if you are in Canada or you are in the US and have a distibutor near you (they do sell it in the US)
It is a synthetic DexIII fluid, and works awesome.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1st gen SC2 manual trans fluid VUEmaniac S-Series Tech 16 11-30-2010 01:34 PM
Manual Trans Fluid sea2seajt S-Series Tech 7 12-23-2009 11:24 PM
Whats trans fluid does everyone use in their manual trans? turbobuick33 S-Series Tech 14 11-07-2007 01:11 PM
1998 Manual Trans - Shifting problem SL1_Owner S-Series Tech 8 02-11-2005 12:25 AM
Manual Trans Fluid dano92 Miscellaneous Tech 12 01-07-2002 10:42 PM
