Old 10-01-2010, 11:13 AM   #1
Cjohns8792
Cjohns8792 is on a distinguished road
Default 1997 Saturn SC2 2Dr Coolant Problems?
I just bought this car the other day and it has recently been showing some lights flashing on the dash. One is the coolant temp light and one is the coolant fluid low light, I believe. It only does it shortly after the car is started and will go away after driving for a few minutes. Any help would be awesome, thanks. I have a video uploaded on photobucket but I can not post it with a full link unless I have 15 posts. I can PM someone the link or email it to them. Thanks. Also I checked the coolant and it does not look low.
Add to Cjohns8792's Reputation
Rate the quality of this post and help Cjohns8792 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cjohns8792 is offline   Reply With Quote
Old 10-01-2010, 11:33 AM   #2
Chazberry
Chazberry's Avatar
Default Re: 1997 Saturn SC2 2Dr Coolant Problems?
Could be a gunked-up level sensor. For reference . . .
http://www.saturnfans.com/forums/sho...d.php?t=157462
http://www.saturnfans.com/forums/att...1&d=1281749874
Add to Chazberry's Reputation
Old 10-01-2010, 11:34 AM   #3
That's one light. Blinking means coolant is low, or it thinks it's low. There's a float in the reservoir that sets the light, and it sometimes sticks, turning the light on even when your coolant level is good. To fix, drain enough coolant into a clean tub to drain the reservoir. Remove and clean out with a low-suds soap like dishwasher detergent. Rinse thoroughly. You should now hear the float rattling when you shake it. Reinstall the reservoir and refill with the drained coolant, top off as needed.
Add to madpogue's Reputation
Old 10-01-2010, 11:58 AM   #4
2NDSOUT
2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough
2NDSOUT's Avatar
1999 SL
In addition; it may be a good idea to check the driver's side top of the radiator for an extremely small half inch pinhole leak. Also; what is the condition of the water pump.
If the float is okay; then move to check the radiator and/or water pump as these would be your next line of replacement. Check the pressurization on the coolant resevoir cap as well.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
1997 SC2 isn't overheat but still pukes coolant M&WC S-Series Tech 11 06-19-2010 04:51 PM
Coolant Loss???? Where is this coming from???1997 Sl2 josh7282 S-Series General 3 05-19-2009 07:43 AM
1997 SW2 Losing Coolant Bkaza S-Series General 6 08-25-2008 10:02 AM
HELP!!! 1997 Saturn SL2 Problems jdipp S-Series Tech 8 07-20-2004 10:32 PM
1997 SL2 Coolant problem gary078 S-Series Tech 11 03-08-2004 08:34 AM
