Old 09-20-2010, 09:45 PM   #1
edgrmndz
edgrmndz is on a distinguished road
Default "security" blinking on dashboard, the car won't start
My 2002 sl1 won't start when in the dashboard the "security" yellow light is blinking,, I don't have an alarm to activate or disactivate the alarm, in order for me to start the car I simply wait for the "security" to stop
blinking and then the car will start..the car does this whenever it feels like sometimes once a day maybe twice a week maybe more so I have no control over this issue,, I just wait when it happens sometime maybe 3 mins other times up to 10 minutes. any sugestion would be appreciated.
Add to edgrmndz's Reputation
Rate the quality of this post and help edgrmndz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edgrmndz is offline   Reply With Quote
Old 09-20-2010, 10:00 PM   #2
Default Re: "security" blinking on dashboard, the car won't start
Your remote simultaneously Locks and enables the factory theft deterrent system (Passlock). Pressing Unlock opens doors and disables Passlock. Search for the 30-minute relearn procedure. This may correct the issue or else the Passlock components surrounding the ignition lock cylinder are flaky. Hopefully the relearn works and you won't have to tear apart the steering column.
Old 09-20-2010, 10:18 PM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
+1^^
Follow the steps below to perform the Passlock relearn procedure.
1. Turn ignition switch to RUN position.
2. Momentarily rotate ignition switch to START position and return to RUN position. DO NOT start vehicle.
3. Wait ten minutes.
4. When SECURITY indicator light changes from a flashing or on state to an off state, turn ignition to OFF position.
5. repeat steps 1-4 two more times (for a total of three times)
If the ignition switch is turned OFF before the SECURITY indicator light changes state, the relearn procedure must be restarted.
The car should start on next ignition cycle.
2007 Ion 2 Quad Coupe 5-speed manual 176K miles
2007 Chevy Equinox LT 175K miles
Add to ruley73's Reputation
Old 09-20-2010, 10:37 PM   #4
edgrmndz
Thank you. I will try that procedure tomorrow morning. I don't have a remote control that's what I meant when I said I don't have an alarm, but I guess not having a remote doesn't matter.
Old 09-20-2010, 11:38 PM   #5
If the SECURITY light is coming on, you DO have the factory RKE/Security system. You can get remote fobs for it via eBay pretty cheap, but unfortunately, it being a gen-3 car, you have to take it to a dealer to program the fobs.
Perhaps the BCM (which contains RKE functionality) is occasionally resetting itself, and in doing so is assuming the car was locked with the remote, and is thus tripping the security mode when you unlock the car. Not sure how you would diagnose that, though. Are you having any other charging system issues? Radio presets disappearing, anything like that?
Add to madpogue's Reputation
Old 09-21-2010, 01:13 AM   #6
edgrmndz
I have no other issues with this car. today in the morning I took it to a saturn dealer since I have a saturn remote that someone gave me and the guy at the dealer hooked up the machine ( he was going to set the remote for free!! I could not beleive it) but of course there was a problem,, the dealer guy told me that the computer was not comunicating with the vehicle and that I had to leave the vehicle and have more test done,( but just to run diagnostic would cost me $90) so I decided to ask you guys.
Old 09-21-2010, 01:18 AM   #7
edgrmndz
And then in the afternoon I took it to an alarm shop and they were going to
bypass the originall alarm and hook up theirs and give me two remotes that were going to be able to unlock the door and of course set the alarm all this was going to cost me $125.00,,but then after being there for half an hour, the technician told me that they could not do it, simply they could not do anything with this car and I had to take it to the dealer.
Old 09-21-2010, 02:57 AM   #8
Before you get caught up in the confusion, try the relearn first. This doesn't require the remotes at all. If this works then you can decide if its worth the money for having remotes programmed. Beware of dealers taking advantage of Saturn's demise..........to cash in on any opportunity. You were given a hint already whe the dealer suddenly changed attitude.
Old 09-21-2010, 03:00 AM   #9
^^^^ +1; and since it's a factory security system, an "alarm shop" won't be much help.
Old 09-21-2010, 05:58 PM   #10
edgrmndz
Originally Posted by ruley73 View Post
+1^^
I have a problem with the step number two where it says " DO NOT start the vehicle" but when I rotate the ignition to the START position; the car starts right away since the START position on my car is where it cranks and starts.
Old 09-21-2010, 08:12 PM   #11
If you can't do it fast enough to avoid starting the engine, you could disconnect the ignition module. Or pull all the spark plug wires at the coils (a bit of extra work with the gen-3 hold-down clips).
Old 09-21-2010, 08:35 PM   #12
edgrmndz
Ok, I will remove the wires and try again.
Thanks
Old 10-23-2011, 11:05 PM   #13
jsdeschaine
jsdeschaine is on a distinguished road
We are in the same situation, we replaced the battery to a new one and now the sec light blinks and we cant start car, we have tried relean, but no avail, the reduced power and air bag light are on as well, and ive only owned itr three days: cant wait to drive it lol. let me know what works now they say the might have to reprogran bcm $600 i dont know what to do
Add to jsdeschaine's Reputation
Rate the quality of this post and help jsdeschaine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jsdeschaine is offline   Reply With Quote
Old 10-24-2011, 12:53 AM   #14
ruley73
ruley73's Avatar
Originally Posted by jsdeschaine View Post
...the reduced power and air bag light are on as well...
Are you sure you have an S-Series Saturn? The S-Series do not have a reduced power light. So if you don't have an S-Series, the relearn procedure posted earlier won't work on your car.
Old 02-26-2016, 03:22 PM   #15
lleonard199
lleonard199 is on a distinguished road
Dizzy Re: "security" blinking on dashboard, the car won't start
Hello,
I am having this same issue described on my Saturn L300. Does this same method work on the L Series?
Add to lleonard199's Reputation
Rate the quality of this post and help lleonard199 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lleonard199 is offline   Reply With Quote
Old 02-26-2016, 06:05 PM   #16
lleonard199, as a new member and L300 owner, your car is not an S-series but an L-series model. Two different animals. It would be better if you; update your profile to reflect your car stats under your name, repost again but in the L-series tech forums, and add additional background history that may help anyone here to have a better perspective about your car and problems.
Old 02-26-2016, 11:34 PM   #17
seac
seac has a spectacular aura aboutseac has a spectacular aura aboutseac has a spectacular aura about
seac's Avatar
When I had a similar problem, I tried the passlock relearn and it didn't work. It turned out to be an F5 issue (look it up here). If it is an F5 issue, use a voltmeter on the inside fuse box to see if there is 12v going into it when the car is not starting. Just stick the lead into any +12v fuse socket. I had to run a new +12v wire into the fuse box from the underhood fuse box, because the original +12v wire had an intermittent connection and I could not get the fuse box apart to fix it. I stuck the new +12v wire into an unused fuse +12v socket.
Saturn 2002 SL2
Still under 85K miles.
Add to seac's Reputation
Rate the quality of this post and help seac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
seac is offline   Reply With Quote
Old 02-26-2016, 11:41 PM   #18
seac, if you are replying to lleonard199's question, his L300 does not have the F5 problem because he has an L300, not an S-series car.
Old 02-27-2016, 07:04 PM   #19
seac
seac's Avatar
I am replying to the OP SL1 problem here. My car had the same blinking security light and no start. It was a difficult problem to diagnose because sometimes the car would not start and then a few minutes later it would. After finding the intermittent power at the inside fuse box, I fixed it for good. It has been a couple of years now and the problem has not come back.
Saturn 2002 SL2
Old 02-27-2016, 07:37 PM   #20
The OP hasn't replied with a solution in five years but your comments did (to me anyway) appear as replying to a recent post. Its great that you were able to use info, correct a recurring problem and share your results.
car won't start when "security" shows on dashboard edgrmndz S-Series Tech 5 09-21-2010 02:59 AM
Vue wont start Security light blinking Powellak Vue Tech 2 01-15-2007 11:02 PM
The "Christmas Tree" Dashboard Flicker- 2002 SL1 x-angel S-Series General 26 12-14-2006 05:32 PM
[Wolfman] Continaully blinking "Low Coolant Light" HELP! TIMSPEED S-Series Tech 17 10-26-2005 11:10 AM
03/04 ION no start/blinking "service vehicle" smoothrider Ion General 14 02-19-2005 10:04 AM
