Old 09-19-2010, 10:58 AM   #1
adventureoflink
adventureoflink's Avatar
Default Heater Control Valve, wherefore art thou?
So yes, as the title says, where is the heater control valve in a Saturn S-series, made around 1997?
How easy is it to replace, and is it accessible? Just curious.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 09-19-2010, 11:15 AM   #2
Default Re: Heater Control Valve, wherefore art thou?
Like most cars built since the macarena, there isn't one.
Add to madpogue's Reputation
Old 09-19-2010, 11:17 AM   #3
adventureoflink
And this Saturn is part of that era... wonder what made the HCV get axed...
thanks for the info, sir.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 09-19-2010, 12:08 PM   #4
Heater control valve? If you mean the thermostat, it may be interpreted as the closest thing to describing heat control - for the engine. If you truly mean a valve to manually shut off coolant flow to the heater core, it doesn't exist. The HVAC box has two blend doors; one that directs air flow to the various vents and the other to modulate air temperatures for temperature control. One door selects how air flows to control the amount of heat wanted into the cabin from plain unheated air to fully heated air directed onto the heater core. The coolant is always flowing and no shut off valve exists.
Madpogue, ever had to replace a heater shut off valve? In the passenger side? Not fun when it leaks.................its one less troublesome part to deal with.
Old 09-19-2010, 12:15 PM   #5
Because eventually, they leak and you get to replace it with a 1/2" gate valve under the hood or in the glove box. That is because when they die there is no longer a replacement that will work.
There is a bunch of linkage on the drivers side of the heater box, make sure it is all working correctly. Don't oil it either.
Old 09-19-2010, 01:18 PM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
Don't listen to these guys. The heater control valve is located between the distributor cap and carburetor.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 09-19-2010, 02:10 PM   #7
I'm still having trouble looking for my distributor cap and carb for my L300. I'm wondering if I can upgrade and forget about supercharging or tutbocharging, head right to flux capacitors. Of course I'll need some help acquiring some plutonium for version 1.0 as I don't think I can afford the improved versions........
Old 09-19-2010, 02:49 PM   #8
Low Saturn
Low Saturn's Avatar
2000 SC2
Forget the plutonium.
Mike
-2000 Saturn SC2
Old 09-19-2010, 02:58 PM   #9
I can't afford that upgrade. I heard that the Russians have some back room dealers for plutonium. I'ma gonna try this way thru the CVT belt seller over there........ And mine'll glow in the dark. Don't need no stinkin' HID's!?
Old 09-19-2010, 03:09 PM   #10
Low Saturn
Low Saturn's Avatar
2000 SC2
Just don't deal with Libyans. They'll come after you in a VW van with RPG launcher.
I'm going on vacation soon and traveling through time. I'll be returning last week and I'll bring back a Mr Fusion. They cost less than a Saturn S-Series in the future.
Mike
-2000 Saturn SC2
Old 09-19-2010, 03:29 PM   #11
[voice="Majel Barrett"]Warning - thread hijacked.[/voice]
Old 09-19-2010, 08:07 PM   #12
off-track
off-track's Avatar
But.. I've got a BUNCH of old pinball parts to spare!
http://www.youtube.com/watch?v=MBucwjIcc3s
2:30 in
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 09-19-2010, 08:40 PM   #13
saturnsctwo
there is none in a saturn i believe. the heater core gets a flow of coolant all the time...
Old 09-19-2010, 08:45 PM   #14
saturnsctwo
tell me about it! i replaced more of these dam things than i can remember & they were not cheap! they tend to leak through the rubber vacuum diaphragm...
Old 09-19-2010, 10:10 PM   #15
I remember opening the glove box on a 52 Chevy to open the valve so there would be a bit of heat.
Old 09-19-2010, 11:07 PM   #16
adventureoflink
OK OK, fair enough guys...
but still, thanks for the info all the same.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 09-20-2010, 08:23 AM   #17
DonP
Isn't it just above the magneto where the spark advance control rod attaches.
Add to DonP's Reputation
a/c heater control shady310 S-Series Tech 3 05-02-2007 08:38 PM
1997 Heater Control Valve? acman L-Series General 2 04-30-2006 10:54 PM
Heater control problems fasslerb Vue Tech 0 04-01-2006 08:57 PM
Heater control lever..'93 SL2 Denis Twosaturn S-Series General 1 03-08-2006 11:02 AM
A/C - Heater Control new TedL Classifieds 0 09-14-2003 09:13 AM
