Old 09-17-2010, 01:28 PM   #1
custardspie
custardspie is on a distinguished road
custardspie's Avatar
1994 SC2
Dizzy Looking for a ECU/PTC 1994 SC2
This is my original thread.
(1994 SC2 Relay auto trans/cool fan. car dont drive)
The Shop has tested all grounds, the trans shift sensors, all is good. Now they have be waiting for some junk yard for 3 days to locate and drive the new Computer to the shop. My car has been there for 4 days and now they say maybe tues next week. I'm gonna loose my job, due to no transpertation. Anyone know where I score an ecm/ecu/ptc with numbers 210222768 service # 21022423 for my 1994 saturn SC2. I love this car and dont want to junk it.
thanks
Add to custardspie's Reputation
Rate the quality of this post and help custardspie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
custardspie is offline   Reply With Quote
Old 09-17-2010, 01:56 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Looking for a ECU/PTC 1994 SC2
I seriously doubt your cars problems are due to a faulty PCM. I looked at your other post and it soulds like an electrical or sensor problem.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 09-17-2010, 02:09 PM   #3
custardspie
1994 SC2
I told the shop the same thing. The said they check all grounds,wiring, and the trans solenoids. The computer shows an error with these 2,3,4th trans solenoids but they checked them and they were fine. so they tracked this back to the PCM and are going to try to replace the old one and hope it works. If your right I've got some bigger problem since they said they check all of this out. This is a very good shop with a lot of experience.
Old 09-17-2010, 04:31 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
Charging system problems can cause solenoid issues to be seen by the PCM. Testing the solenoids wont show much, because proper voltages from the test equipment will show proper results.
Did they check from proper amperage as well as voltage from the alternator? Even if it puts out the correct 14.4 volts, if its isnt putting out enough current, it cant power all the electronics. And the transmission valvebody requires a fair amount of current to operate properly. The first signs of alternator failure on these cars is a wacky acting transmission if its equipped with an automatic. If allowed to continue, you'll not only get the tranny acting weird, but the engine will start to cut out when the brakes are applied.
Mike
-2000 Saturn SC2
Old 09-17-2010, 05:09 PM   #5
custardspie
1994 SC2
Ok you were right about the PCM. The used one they put in changed nothing. I told them that I could get my car to drive fine on the hwy after removing the power from the Junction box (relay fuse center). After exiting the off ramp my car would bog down with no power and I think its stuck in 4th gear. The shop just said that we should check out the tranny. I read on other threads that others have had this same problem spent much money to replace all these things for it to be a ground issue. I just told them about the Alternator being a possible issue. Do you know what the amp specs are for the alternator? it sound like everything read through their tests the way you said. If all this is due to a bad alt I'll be happy but also pissed. Its something that I could have taken out of my car to autozone and had tested. Replaced for half of what I'm being charged to be told my car dont work.
Old 09-18-2010, 01:00 PM   #6
custardspie
1994 SC2
Wrench Re: Looking for a ECU/PTC 1994 SC2
Ok today the shop checked the alternator. It's putting out 14.4 volts and 90+ amps. They said this is good. On a test drive the car got stuck in reverse. They had to manually place it into drive and then it was still stuck in 4th. They are going to send it to the transmission shop to check out the internal workings of the trans. Does anyone one else have any suggestions before monday that might help me out it would be great.
PCM = Good
All Grounds = Good
Alternator = Good
Trans solenoids = Good
relay/fuse center (Junction box) = Good
I don't know what this is but my car still wont drive right
WHATS NEXT?
MACMAC
Old 09-18-2010, 01:16 PM   #7
Low Saturn
Low Saturn's Avatar
2000 SC2
There could be issues with the transmission valvebody. Thats a known thing with these cars that have automatics. But its usually not a sudden thing. Its something that starts as an annoyance and gets worse over time.
Mike
-2000 Saturn SC2
Old 09-18-2010, 01:20 PM   #8
Valve body.
1994 sc2 samjack56 S-Series General 11 05-23-2010 10:12 PM
1994 sc 2 quickie5 General Saturn Discussion 2 04-15-2008 11:39 PM
Using E-85 in my 1994 Sat Sw1 colosat S-Series Tech 16 05-12-2006 04:21 PM
1994 Sl1 $200 Obo RangerRover Classifieds 3 03-23-2006 12:03 AM
1994 sc2 HELP kangel900 S-Series General 10 01-21-2006 10:50 AM
